Car Nut
Drives: BMW 335d, Toyota Echo RS, FRS
Best bang for the buck camber bolts and rear LCAs?
Ordered me up some Eibach Sport Line springs and Eibach sway bars, but still need to decide on camber bolts and rear LCAs to keep the camber in check as my car is a all year round daily driver as well as sees some track/ auto x use. I need something that isn't going to break the bank, any suggestions? I think SPC rear LCAs are the cheapest I have found so far, but how will they stand up? Are there any camber plates out there that cost less than $400?
TIA |
#2 | |
Drives: Subaru BRZ Limited
I went with SPC camber bolts and rear LCA's also. Once they're installed you really won't ever think about them again. They've worked just fine for me the 5 months that they've been installed. Great product for the price.
| The Following User Says Thank You to ericmpena For This Useful Post: | BRZZZZZZZZZZ (02-12-2014) |
Whiteline camber bolts are the exact same product as SPC. It's actually just SPC hardware in a Whiteline bag, so save yourself a few bucks and get SPC camber bolts.
As for rear LCA, go with whatever fits your budget. Since you're in Canadia, though, you may want to go with something that won't rust to bits. I think SPC's arms are stamped and coated (paint? powder? idk) steel. Others should have aluminum arms, but at a higher cost. |
| The Following User Says Thank You to sshole For This Useful Post: | BRZZZZZZZZZZ (02-12-2014) |
Car Nut
Went with the SPC bolts and arms, they will be tied in with Eibach Sportlines and Eibach sway bars, and 16X7 Volk TE37s with 225/50/16 Hankook RS-3.
Pegasus White
Drives: 86
Looking forward to hearing your results.
Driving: Pegasus White Manual GTS 86.
| The Following User Says Thank You to DriftEightSix For This Useful Post: | BRZZZZZZZZZZ (02-17-2014) |
Drives: 2012 Toyota 86
Canada Eh!
Drives: '13 FRS
Drives: 2013 Premium White, 2006 TL
Why are you doing both bolts and LCA? Just a question. I only have the Whiteline bolts coming in the mail soon.
Drives: 2013 MT Asphalt FRS
Can someone educate me on how I will benefit from getting lca?
![]() Thanks
#10 | |
We recommend the SPL, but the SPC is a much less expensive (mostly) replica of the SPL. Last edited by CSG Mike; 02-18-2014 at 02:33 AM. |
| The Following 4 Users Say Thank You to CSG Mike For This Useful Post: |
#11 |
Pegasus White
Drives: 86
where can i see the SPL stuff?
#12 |
Car Nut
#13 |
Car Nut
#14 |
Whoops. I thought "Bang for the Buck" was talking about camber bolts verse LCA for the rear. I'm SO confused!
So I bought the camber bolts for the upper control arm of the REAR. They are on there way. But should I change my tune and go for LCA's if I am planning on 1-1.5" drop for a DD car? What's your thoughts. I'll save $300-400 with the bolts verse the LCAs. Sent from my iPhone using Tapatalk |
| Camber Bolts in Rear | DIE1000DEATHS | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 34 | 05-13-2015 10:19 AM |
| Eibach sportline, SPC rear LCAs, Whiteline front camber bolts | Shad0ez | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 11-17-2013 11:52 PM |
| *FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! | Corner3garage | Mechanical Maintenance and Tools | 6 | 10-31-2013 03:40 PM |
| Most bang for the buck? | GIMMICK | Scion FR-S / Toyota 86 GT86 General Forum | 24 | 05-07-2013 07:10 PM |
