Drives: 14' Raven M/T - 02' is300
possible to convert outside temp sensor to water/oil?
is it possible to convert outside temp sensor to water/oil?
Ive heard of this being done on other cars before. |
#2 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
Just get a Bluetooth dongle and the torque app.
#3 |
Drives: none
I don't see why not. The sensor is mounted in front of the A/C condenser, if you found a voltage compatible sensor for water or oil you could definitely wire it in. AFAIK nobody has done this on our car yet.
#4 |
Drives: 2017 Ice Silver BRZ Limited
What's the range on the readout for the outside temp gauge? If it doesn't read above 200º (unless you're working in ºC!) it wouldn't be of any use. Also, is the OT sensor used by the engine management system? (I don't know the answer, just brainstorming..)
#5 |
not sure. I guess we could try putting a heat gun to it to see if it goes over 200
#6 | |
Drives: 2017 DGM BRZ PP
As far as if the engine management system uses it, that could be a problem but I highly doubt that it does. It should only care about intake temperature, not outside temperature. |
| The Following User Says Thank You to Horrid_Funk For This Useful Post: | Williampreza (07-18-2018) |
#7 |
Drives: 2016 ZC6
Interesting idea. Would definitely make for a stealthy, oem looking temp monitor. An OBD BT dongle + Torque works too but has its own issues like always having to wait for pairing, bad pairing, battery drain depending on BT adapter, etc. Enough issues wasting my time and with the frequency of me using torque just for temp read outs that I switched to manual gauges. OP I hope you try this temp sensor conversion and I hope it works.
My build thread: Pointmutation's WRB BRZ build
#8 |
I have no clue if it does anything other than display the temperature on the dash but I would want to make bloody sure it isn't sending a signal to any other system in the car before messing with it.
May be fine on a manual HVAC control but I do know that it plays a part in the automatic HVAC systems.
#9 |
Drives: BRZ 2017 Pure Red, MT
The HVAC probably use that temperature reading to know if it needs to start the AC compressor when you use the windshield defrost vent.
| The Following 2 Users Say Thank You to nico_rsx For This Useful Post: | Horrid_Funk (07-18-2018), Tcoat (07-18-2018) |
#10 |
Good call!
| The Following User Says Thank You to Tcoat For This Useful Post: | nico_rsx (07-19-2018) |
#11 | |
https://demos.starbase7.net/t3Portal...02LJ403UX.html
#12 | |
#13 | |
Was relieved when I saw that you were offline.
#14 |
Drives: 2014 GT86
How about this project to use display place where clock is to show oil/coolant/intake temps, voltage, a/f ratio?
| FS: BNIB Prosport Guages (Water Temp / Exhaust Gas Temp) | AtlasMick | Interior Parts (Incl. Lighting) | 2 | 03-31-2015 05:47 PM |
| Water temp. | Reaper | Engine, Exhaust, Transmission | 7 | 08-28-2014 10:20 PM |
| STRI DSD SLM II Gauges (boost/oil temp/oil press/water temp/egt) BNIB | ziptiedae86 | Interior Parts (Incl. Lighting) | 0 | 10-29-2013 11:50 PM |
