Old 07-02-2018, 01:02 AM   #1
jfarkas
Drives: 2014 FR-S
Clicking/tapping noise from front suspension, coil bind?
Today while leaving for work I noticed a sort of clicking noise from what seems to be my left front strut. Car still has stock suspension, currently at 39k miles.
It's pretty much only audible at low speeds, under 30 miles an hour. I thought it was just the dust cover for the shock rattling around at first, as it has come loose, but it seems to be clicking when I turn at low speeds around turns in parking lots and such. I came to a full stop and could hear it still while turning lock to lock.
Is this a sign of coil bind, and if so, what would I do to fully diagnose/fix it? Thanks!
jfarkas is offline   Reply With Quote
Old 07-12-2018, 11:48 PM   #2
jfarkas
Drives: 2014 FR-S
Well, after a thorough investigation of everything connected to the suspension and steering rack, nothing was loose. Turns out, it was a much more stupid and simple issue: a bunch of the plastic undertray/splash guard was loose and a couple of the clips were broken/disconnected.
Re-clipped what I could and zip tied stuff together where clips were broken. Stuffed a few pieces of old rag between the bumper and undertray to dampen it and no more noise! Not sure how turning from lock to lock caused it to contact the plastic anywhere but its quiet as a mouse now. Just bumping this and updating in case anyone else runs across this.
The Following 2 Users Say Thank You to jfarkas For This Useful Post:
TheBRZsKnees (07-09-2023), Ultramaroon (07-12-2018)
DIY - Fix your Rear Deck "popping/clicking/tapping/ticking" noise. Mikepage DIY (Do-It-Yourself) Guides 54 10-21-2020 03:34 PM
Rear Deck "popping/clicking/tapping/ticking" noise. Sigh-on-Rice Issues | Warranty | Recalls / TSB 637 04-28-2020 05:55 AM
Clicking/Ticking Noise From Front Wheel immaculate Issues | Warranty | Recalls / TSB 8 05-18-2018 10:56 AM
Clicking / tapping sound + fuel pump noise + clutch grinding Mikeez Issues | Warranty | Recalls / TSB 11 04-27-2015 12:19 AM
clicking/tapping noise when shifting semi hard Skurge Issues | Warranty | Recalls / TSB 3 09-20-2013 05:37 PM
