Old 09-21-2015, 08:01 PM   #1
immaculate
immaculate's Avatar
Drives: 2017 Audi S3
Clicking/Ticking Noise From Front Wheel
I'm looking for some help on diagnosing a clicking/ticking type noise that I'm experiencing at my front left wheel. At low speeds, typically up to about 15 mph I'm getting the noise shown in the video. I've experienced it in 1st, 2nd and reverse. The noise is only coming from the front left wheel.
My wheel suspension setup is 18x9.5 +40 on ST Coilovers. There appears to be adequate clearance between the tire and strut. I ran this same setup last year without any issue, it only started this year when I put these back on in the Spring.
I also thought it may have been a noise coming from the coilover, but the car is on jack stands in the video and still making the noise with zero loading on the suspension.
The only threads I could find on here with a similar noise were axle related issues. The noise I'm experiencing doesn't seem consistent with the noises in those other videos, so hopefully that is not the issue here.
Any help would be greatly appreciated.
immaculate is offline   Reply With Quote
Old 09-21-2015, 08:38 PM   #2
RallybluBrz
RallybluBrz's Avatar
Drives: 2013 Subaru Brz Rally Blue
This may seem like a stupid question, but I've had issue with cheap lugs once... any chance something is up there? And in the video, it sounds like it's literally coming from the wheelwell, not further back, is it coming from the wheel or is it somewhere a bit back?
NTHEBRZ
RallybluBrz is offline   Reply With Quote
Old 09-21-2015, 08:54 PM   #3
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
It almost sounds as if the springs are moving or the sway bar? It's really hard to tell from that angle. Have you tried holding the end link while spinning the wheel?
Old 09-21-2015, 10:15 PM   #4
immaculate
immaculate's Avatar
NTHEBRZ
I don't think it's the lugnuts, they're Muteki's so it should be a decent quality. I torqued them to the recommended 90 ft-lbs when I changed the wheels, so I wouldn't expect a problem.
I'm pretty sure the sound is coming from within the wheel well, likely one of the suspension components but I didn't see anything obvious when I looked.
I looked for but didn't see any movement in the springs. I didn't try holding the end link. I can give that a shot the next time I have it on jacks and take some video from a few more angles.
Old 09-21-2015, 10:23 PM   #5
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Check clips on brakes.
Packofcrows is offline   Reply With Quote
Old 09-22-2015, 04:07 PM   #6
humfrz
Sounds like a cricket escaped from the HPFP and landed on the wheel..... ??
Seriously, I like the brake clip theory .....
Back in the day, I would suspect a dragging brake shoe or a lose/broken brake shoe return spring or a dry wheel bearing ........ sorry, it must be past my nap time .....
humfrz
Old 09-22-2015, 04:42 PM   #7
nickmerronesucks
Ned flanders
nickmerronesucks's Avatar
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
I had this, and it eventually went away. not sure what it was.
797Performance.com
nickmerronesucks is offline   Reply With Quote
Old 09-22-2015, 05:16 PM   #8
RallybluBrz
Have you looked way up to see where your spring is resting and if it is/trying to move? Are your coilovers adjustable and fully tightened?
NTHEBRZ
Old 05-18-2018, 09:56 AM   #9
shadowsnkx
Drives: 2015 BRZ
So I know this is an old thread, but what was the resolution to your issue?
shadowsnkx is offline   Reply With Quote
DIY - Fix your Rear Deck "popping/clicking/tapping/ticking" noise. Mikepage DIY (Do-It-Yourself) Guides 54 10-21-2020 02:34 PM
Rear Deck "popping/clicking/tapping/ticking" noise. Sigh-on-Rice Issues | Warranty | Recalls / TSB 637 04-28-2020 04:55 AM
Clicking / Ticking Rear Noise shellslinger Issues | Warranty | Recalls / TSB 19 07-20-2017 09:40 PM
Ticking/Clicking noise when accelerating? Pineapple Issues | Warranty | Recalls / TSB 3 08-28-2014 03:29 PM
Ticking/Clicking Noise front - passenger side PoRco Scion FR-S / Toyota 86 GT86 General Forum 9 05-06-2013 05:55 PM
