Old 07-12-2018, 05:10 PM   #1
ayau
Drives: Some rust bucket
Strut spring perch clearance
I have about the width of my index finger gap between the spring perch and the OEM 215/40/18 Michelin Pilot 4 tires. I would like to get some 17x8 +48 wheels and 225/45/17 tires. I also realize not all tires have the same width even if they’re the same size specificstion. Only modification is OEM crash bolts. Do you think this will be too close?
https://imgur.com/gallery/eHjZWCM
Old 07-12-2018, 07:09 PM   #2
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
No
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
The Following User Says Thank You to Laika For This Useful Post:
Leonardo (07-12-2018)
Old 07-12-2018, 09:34 PM   #3
wparsons
wparsons's Avatar
I had 225/45/17's on 17x8 +45's, running -2.3* of camber up front with camber bolts and slotted stock struts. It was close, but no rubbing on the spring perch.
flickr
Spring perch clearance check iyoiyo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 07-22-2017 10:45 PM
Raceseng CasCam - Caster + Camber Plates with Spring Perch RJasonKlein Brakes, Suspension, Chassis 3 01-26-2017 07:14 PM
Vorshlag Upper Spring Perch Wusaa Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 09-06-2016 02:36 AM
smallest OD coil over / spring perch BadBRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-27-2014 12:56 PM
Clearance to spring perch Gearhead1 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 03-07-2014 05:56 PM
