Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
07-12-2018, 05:10 PM | #1 |
Drives: Some rust bucket
Strut spring perch clearance
I have about the width of my index finger gap between the spring perch and the OEM 215/40/18 Michelin Pilot 4 tires. I would like to get some 17x8 +48 wheels and 225/45/17 tires. I also realize not all tires have the same width even if they’re the same size specificstion. Only modification is OEM crash bolts. Do you think this will be too close?
https://imgur.com/gallery/eHjZWCM |
07-12-2018, 07:09 PM | #2 |
When In Doubt...
Drives: Slowww
No
Join the Galaxy Blue Silica BRZ registry below: https://docs.google.com/spreadsheet/...2c&usp=sharing |
The Following User Says Thank You to Laika For This Useful Post: | Leonardo (07-12-2018) |
07-12-2018, 09:34 PM | #3 |
I had 225/45/17's on 17x8 +45's, running -2.3* of camber up front with camber bolts and slotted stock struts. It was close, but no rubbing on the spring perch.
Similar Threads | ||||
Spring perch clearance check | iyoiyo | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 07-22-2017 10:45 PM |
Raceseng CasCam - Caster + Camber Plates with Spring Perch | RJasonKlein | Brakes, Suspension, Chassis | 3 | 01-26-2017 07:14 PM |
Vorshlag Upper Spring Perch | Wusaa | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 09-06-2016 02:36 AM |
smallest OD coil over / spring perch | BadBRZ | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 06-27-2014 12:56 PM |
Clearance to spring perch | Gearhead1 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 03-07-2014 05:56 PM |
