#10641 |
Drives: FR-S,GTI
Cool
Looks like this might be for real. I like how they put it on the Subaru with the oversized turbo to eliminate lag. I don't know about having lithium batteries under my hood though. |
#10642 |
Drives: NB2 1.6
Hello,
I am interested in this type of turbos. What size of motor and turbo are you using? Thank you very much. |
#10643 | |
Drives: NB2 1.6
#10644 |
Drives: Hot lava FRS Monogram Charizard
How well does the openflash tablet do at reading boost? I was doing some pulls with my car and noticed i'm only producing about 3.9psi max....I'm running the new battery configuration w/out the procede. Im wondering if with a little tweaking shiv can bump that number up a bit?
Sent from my SM-G935T using Tapatalk |
#10645 | |
Drives: 2013 Asphalt 6spd
I don't know if this will work, but I have my runs up on datazap that I recorded with the proceed and I topped out at 4.79lbs at 2991 rpms. https://datazap.me/u/target70/esc-du...1&zoom=504-691
Phantom ESC, OFH, OFT, K&N Drop in
#10646 |
Drives: 2017 toyota 86
The torqamp does seem very interesting, on the 2L Honda it was still making 1.3bar at 5k, would probably make 1.2 at 7k for us. However it’s 3400$ not counting shipping. About 1400$ more then the phantom esc, but this comes with the battery and everything looks pretty simple and plug n play. Should make 7psi tapering to around 2.5-3psi at redline. A bit better then the phantoms 5 tapered to 1.5psi. Hopefully someone will bite the bullet and post up their results for us.
#10647 | |
#10648 | |
Or is the display refresh rate too slow to catch the max readings. I would suggest you do a run and record it, then check the data to confirm.
#10649 | |
#10650 |
Anybody selling an auxillary charger?
#10651 | |
#10652 |
Does anyone know if we can go to like autozone to check if our batteries are still good?
#10653 |
Ultra Senior Member
Drives: 2014 BRZ Premium, WRB
Has anyone had cause to replace the controller for the Phantom ESC? I did a dummy move and arced my wrench across the battery terminals and got some sparks and smoke from the controller before I could break the connection. Other than that, been going strong with the Phantom ESC for four years now and loving every second of it!
#10654 | |
Lightning McQueen Driver
Drives: Limited Red 6MT BRZ
There's a good chance you destroyed the controller. Does it still work? Sent from my iPhone using Tapatalk
Installed Mods: Phantom Electric Super Charger | Open Flash Tune | Perrin OP/ HFC Front pipe | Invidia Q300 catback | ST Suspension | JDL Header | Flex Fuel |
| Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 04:45 PM |
| Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 06:43 PM |
| 86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 07:07 AM |
