#57 |
Not a troll
#58 | |
Only users lose drugs.
Drives: All the time
"It is difficult to describe in words how an advanced multi-link rear suspension works." I wasn't the only one who noticed though..lol Ignoring from now on.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
#59 | |
Drives: 2017 BRZ
Why? What is the technical basis? I don't have a stance really except I don't think an oem Sachs shock that comes in a $1.1k package on a $25k car is going to be all that special. |
#60 | |
Persona Non Grata
Drives: '15 BRZ (WRB)
Edit: Actually, I kinda, sorta, "thought" I understood them a little, but with all the arrows flying around, I've become confused. Can someone offer a verbal description/explanation that makes sense to a lay person?
Slow is smooth, and smooth is fast
#61 | |
Drive upgrades. Don't buy them.
| The Following User Says Thank You to fatoni For This Useful Post: | venturaII (11-05-2017) |
#62 | |
All a multilink design does is allow for the wheel to change geometry along multiple axes as the suspension cycles through it's stroke, versus only one or two with simpler design like a MacStrut. It simply allows for more optimal alignment numbers in toe, camber, caster, etc. throughout a larger range of wheel movement/deflection while covering the spread between comfort and performance better. Increasing the area under the curve, so to speak. You can make ANY suspension type handle well simply by restricting movement - the wheel has more tendency to stay perpendicular to the road surface as a result. But that has a negative impact on comfort and compliance, both of which are important components of an overall suspension system which is capable of operating within a wide range of environmental conditions. It's not as important on a more focused car, where the expectation is already set that the car will be less of a 'multi-tasker'. But even enthusiasts today expect that nearly all cars should do nearly all things well. Multilink designs allow this to be accomplished easier and to a greater degree.
| The Following 2 Users Say Thank You to venturaII For This Useful Post: | Capt Spaulding (11-05-2017), TachyonBomb (11-06-2017) |
#63 |
Drives: 2014 GT86
McPherson also has it's pros, like being cheaper & simpler (good for cheap cars like ours), and being more compact/lighter vs multilink/double wishbone setups (a must, due our wide boxer engines, leaving limited space for suspension in front). Everything is compromise. Those "better" designs too.
And not as if it matters much what those other cars have for their suspension. Different cars for different owners discussing about them in different forums. And imho flaming/offtopic in last two pages starts getting a bit out of hands. |
| The Following User Says Thank You to churchx For This Useful Post: | strat61caster (11-06-2017) |
#64 | |
Drives: 2005 Toyota Camry
Comparing Showa Tuning shocks vs the OEM Sachs (Performance Package) or OEM Bilstein (STi/tS) cars, here's the benefits:
Comparing Showa Tuning shocks vs the OEM Showa shocks, here's the benefits:
All other comparisons vs aftermarket spring/shock, entry level coilovers, etc depend entirely on end user individual needs. -alex |
#65 |
Drives: 2016 Subaru BRZ
Recently purchased the Showa Tuning Evolution with 35/44 N/mm, -15/-15mm, going to install it within the next month along with a bunch of bushings. I haven't seen much on this forum about it so I am excited to get them installed.
| The Following 2 Users Say Thank You to Trueweltall For This Useful Post: | JMon85 (07-19-2018), TachyonBomb (07-13-2018) |
#66 |
Drives: 2015 BRZ
Please post pics if you can and let us know your thoughts on them. I am interested in these as well.
#67 |
Sure thing, I will do before and after.
| The Following 2 Users Say Thank You to Trueweltall For This Useful Post: | Horrid_Funk (07-11-2018), Vital (07-11-2018) |
#68 |
Drives: 2017 DGM BRZ PP
Yeah these look nice. I have a PP and when the shocks wear out from track use I think these may be a good replacement, especially since they have a nice conservative drop. I look forward to hearing your thoughts as well.
#69 |
Drives: #337 2017 Toyota 86
I'd take these over 95% of the coilovers in the same price range. Looks like a great option for a daily driver.
Sean Thomson | Instagram: @the_drivers_perspective / YouTube: The Driver's Perspective
Back To Basics Toyota 86: STX & 86 Cup Street Build |
#70 |
They have arrived.
![]() ![]() ![]() No idea if I put the right spring on the right strut, just threw it together for these pictures. After looking at the instructions(actually just all precautions and Japanese law about vehicle height) in Japanese, the only thing that stands out is that the warranty is only valid in Japan. Spring part number for the front struts are "V0491-3806" and the rear is "V0492-3806" so in my picture they are not correctly placed on the right struts. For anyone who also buys these kits the V0491 is always the front spring and V0492 is the rear. http://showa-tuning.com/_src/sc650/86_parts_list.pdf Last edited by Trueweltall; 07-17-2018 at 11:10 PM. |
| The Following 6 Users Say Thank You to Trueweltall For This Useful Post: | Horrid_Funk (07-18-2018), JMon85 (07-19-2018), new2subaru (07-17-2018), strat61caster (07-17-2018), TachyonBomb (07-18-2018), Vital (07-19-2018) |
| Suspension UPGRADE - Shock/Spring Pkg vs. Coilover System - Which to choose? | themajesticone | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 80 | 11-14-2014 07:01 AM |
| Rebuilding strut/shock dampers to be firmer than spring rates? | fooddude | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 04-16-2014 01:23 AM |
| Can shock-dynos tell you what the highest spring rate it can handle? | fooddude | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 42 | 02-16-2014 05:43 PM |
| Stock dampers on the BRZ are made by Showa. Same for FRS? | mrha | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 17 | 10-19-2012 06:40 PM |
