Old 07-10-2018, 11:35 AM   #29
Vital
Drives: 2015 BRZ
Originally Posted by Geese1 View Post
Ended up going with -2.0 camber and 0 toe up front, and -1.5 camber and 1/16th toe in rear. Of course, the shop didn't hit some of those numbers exactly, but everything was close enough that it shouldn't make a difference.
Don't forget as well, I had SPC camber bolts up front, and SPC lower control arms in the rear in addition to the RCE Yellow Springs.
Car was severely in need of an alignment after the parts install, especially the lower control arms, but luckily I work from home now so I don't need to drive the car on a daily basis.
Nice, that is pretty solid. How did you manage to get -2 camber from just camber bolts up front?
Old 07-10-2018, 11:46 AM   #30
churchx
churchx's Avatar
Drives: 2014 GT86
Vital: Single set of camberbolts is "worth" aproximately upto -1.5. if one uses camberbolts at both holes, it's possible at stock height to get -2.3 camber total, if lowered, then upto -2.5.
churchx is online now   Reply With Quote
Old 07-10-2018, 05:40 PM   #31
Geese1
Geese1's Avatar
Drives: 2018 BRZ w/ PP - WRB
Don't know if this makes the difference, but I had watched a video where they installed the camber bolt in the lower of the 2 holes, and then moved the lower bolt to the upper bolt position, and this is what I did. Supposedly, this gives you a little more adjustment capability.
Geese1 is offline   Reply With Quote
Old 07-11-2018, 01:44 PM   #32
Horrid_Funk
Horrid_Funk's Avatar
Drives: 2017 DGM BRZ PP
That's the recommended way of doing it. Churchx I think is using the numbers I got out of using camber bolts in the lower and upper holes, -2.3 each side. I've gotten recommendations against doing it this way, but it's held up to 2000 miles and two track days, with plenty of hard curb hits and getting dropped off track a couple times. No slipping so far, so it's at least mildly viable. I've read that WRX's with two sets of camber bolts won't hold up to even 1 track day without slipping, so I guess the 86 can handle it better. I'll post updates on how it continues to go.
Horrid_Funk is offline   Reply With Quote
Old 07-16-2018, 03:30 PM   #33
Qwimby1
Drives: 14 FRS Monogram, 05 Mazdasped Miata
Is there a preferred set of alignment specs for a bone stock '14 FRS DD which will get a few track days per year? I will run separate track wheels and rubber.
Qwimby1 is offline   Reply With Quote
Old 07-16-2018, 06:51 PM   #34
kch
Senior Misanthrope
kch's Avatar
Bone stock? You won't really have much to work with for adjustments. If you want to get the most life (and grip) out of those track tires, you'll need -3 to -3.8 front and -2ish rear. You can get Raceseng camber plates that work with the stock front struts, and SPC RLCAs are inexpensive. Otherwise, say goodbye to your tire shoulders.
edit: you can DD with those settings, too. I DD mine at -3.5/-2.2.
Old 07-17-2018, 12:02 PM   #35
Qwimby1
What kind of tread wear do you get on the street with those numbers?
Old 07-18-2018, 03:29 PM   #36
kch
Senior Misanthrope
kch's Avatar
No issues. I DDed on Dunlop Z2SS with those alignment settings and they lasted me 30k+ miles plus two track days, which is great for a 200tw tire.
Old 07-18-2018, 05:21 PM   #37
Overdrive
Sittin' Sideways
Overdrive's Avatar
Drives: 2016 Toyota FR-S
-O/D
2016 FR-S, Hot Lava
Overdrive is offline   Reply With Quote
Old 07-22-2018, 05:19 PM   #38
Qwimby1
I would certainly say so! I've been tracking Miata DDs and front-engine Porsche DDs for a long time with -1.75 front and haven't had excessive shoulder wear on street or track tires. The last time I aligned the Miata I went from 5.0 to 6.4 caster, and directional stability increased significantly. The FRS will get it's first alignment under my ownership next week.
Old 07-22-2018, 07:07 PM   #39
Lakitu
Lakitu's Avatar
Drives: 2017 Halo 86
I installed suspension, wheels, tires and it seems to drive perfectly straight-line.... I'm wondering if I should even bother to get an alignment done, have had a car come out of shop worse than when I took it in...
Build Thread / Daily Driver
OFT Stage 2+, GrimmSpeed CAI, JDL Ultra Quiet FP, Perrin 2.5" Resonated CBE, Enkei 18x8.5 +45, 245/35 Continental ExtremeContact
Lakitu is offline   Reply With Quote
Old 07-22-2018, 08:17 PM   #40
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
Yes, get it checked out.
Trueweltall is offline   Reply With Quote
Old 07-22-2018, 09:03 PM   #41
Racecomp Engineering
Your car can drive straight and still have a bad alignment.
- Andrew
Recommendations for alignment in Bay Area Surj_brz Northern California 9 06-09-2017 12:26 PM
Need alignment spec recommendations 8RZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 05-10-2017 09:53 PM
Alignment recommendations for my setup? sqd Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-19-2016 01:33 PM
Alignment shop recommendations? (SEA) Koa Northwest 7 02-16-2015 07:18 PM
Recommendations for alignment in Socal anewprelusion Southern California 18 01-13-2014 02:36 PM
