| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Drives: 2015 FR-S
Replacing all 20 lug nuts. Will these be fine for track?
I'm finally sick of having to replace 1-2 wheel studs every time I take my wheels off to switch to track pads, so I'm going to make the switch to ARP racing studs all around.
http://www.ft86speedfactory.com/arp-...l#.W0OVWtJKhhE I want to replace my lug nuts at the same time so I'm not messing up the new studs with beat up nuts. I haven't done this before so I would love some advice. https://www.amazon.com/20pc-Black-Bu...x1.25+lug+nuts Am I correct to believe that these will work, even though they are a little longer than stuck nuts. Do you think they will stand up to track use? |
#2 |
Drives: 2014 Scion FRS (Asphalt)
They will work. They should be reliable too since they are steel. Stay away from aluminum lug nuts as they are too soft.
AVO Stage 2 Turbo Build Thread
https://wheelwell.com/tyler-nguyen-1...014-scion-fr-s |
#3 |
Drives: 2015 FR-S
#4 | |
Famous Potatoes
Drives: '15 ultramarine
The aluminum lug nuts that came stock on my 911 have worked fine for 40+ years. Oh yea, and Porsche (and Lotus) recommend anti-seize. Go figure. |
#5 |
StreetKart
Drives: 2014 Scion FR-S Monogram
aluminum lugnuts have their place. That place is not in the hands of someone who is asking if a regular steel lugnut will work on a forum. Generally aluminum lugnuts cause more problems than they really should but most people are not as diligent with maintenance with them as they should be.
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
#6 |
Drives: 13 FRS – Whiteout
Boy did I learn that the hard way 2 months ago. Should have learned when I removed the previous owner's aluminum lugs. After 6 months of use 2/3 were completely stripped.
I replaced them with an expensive Mishimoto set. Torqued to spec, I noticed they needed retightened literally every week. What I also didn't know was aluminum has a much lower modulus of elasticity, which means it will deform about 3 times as much as the same configuration in steel for any given load. With the radical temperature change moving from spring to summer I had 4 lugs and my entire wheel fall off pulling into a parking spot. All of the lugs were completely stripped due to the hot temperature change/expansion. Luckily it didn't happen 90 sec earlier on the interstate – I could have killed someone. |
#7 | |
Drives: 2015 FR-S
I didn't even know that having a lug nut strip so often was a thing until I started reading about it in these forums. The aluminum fatigues, galls, fuses to studs, stretches and strips when you change on and off and they even just break when not touched from heat/cold changes. It seems unless you like to gamble with your life and possibly others, only steel should be used and if weight savings is needed then titanium. |
#8 | |
That's what galls me when they say "well Ferrari has been using them on every track car for 38yrs so they're good enough for me blah blah" A daily driver with the continual stress and temperature changes it would encounter is a disaster waiting to happen with aluminum lugs. |
#9 |
The Dictater
Drives: '13 Red Scion FRS
Not all aluminums (the material) are made the same. Same goes for steel, or any other material.
#10 |
Drives: Track preped NA FRS
All the people here saying aluminium lugnuts are the problem, Im either really lucky, or I know a thing or two you guys dont, because after 35+ track days, taken off and putting on wheels several times each day, I havent stripped a single stud, and have had only a coupld of lugnuts stripped (which go on the trash can and you just put a new one in... woah such danger...).
All I see here is people who cant put in a lugnut without stripping it blaming it on the parts themselfs. Or how we say in my field, User Error. |
#11 | |
Previous owner of mine was probably 1-2 months away from a major accident. His aluminum lugs were "on" but you could loosen half of them with your fingers because most of the threads had been worn away. |
#12 | |
Drives: 2015 FR-S
#13 | |
#14 |
Realizing one of your lugnuts is stripped when taking it off or putting it on and throwing it in the trash can? What part of that is hard to compute? Do you think maybe that lugnuts do not have wear and tear and that one set will outlive the entire car?
| FS: 20 Black Wheel ACORN LUG NUTS and 5 Lock Nuts 12x1.25 and 19 MM Socket w/Sleeve | neilvosko | Wheels and Tires | 14 | 06-18-2018 09:47 PM |
| Something fine... | Porsche | Off-Topic Lounge [WARNING: NO POLITICS] | 2 | 12-13-2013 10:29 AM |
| Something fine... | Porsche | Off-Topic Lounge [WARNING: NO POLITICS] | 0 | 12-13-2013 10:14 AM |
| Looking for 2 - 12mm jam nuts with fine threading.... | MidLife&luvIt | Northern California | 18 | 06-17-2013 12:27 PM |
