Old 07-05-2018, 10:52 PM   #1
Geese1
Geese1's Avatar
Drives: 2018 BRZ w/ PP - WRB
Alignment recommendations
I have my car set to get an alignment Monday morning, and I'm just looking to get a little advice on what settings I should ask the shop to go with.
I have the car lowered on RCE Yellow Springs, but I have SPC camber bolts installed (with moving the lower bolt to the upper position and then using the SPC camber bolts in the lower hole), and I should be getting some SPC lower control arms added this weekend. So hopefully I'll be all set to have the shop be able to set the car up properly.
While the car is my only car, I work from home and my wife and I usually take her car whenever we go out anyplace together, so in reality this is more of just a fun, weekend toy that does need to have the ability to drive it year round as needed.
While I'm hoping to get some track time at some point, it will most likely be only a couple of times a year. However, I love finding some twisty back roads and driving those in anger (withing reason ).
So, any suggestions on what I how I should have the car set up?
Geese1 is offline   Reply With Quote
Old 07-05-2018, 11:21 PM   #2
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Also going to tack a sub-question on as I'm in the beginning stages of thinking about the same setup for pretty much the same use.
Are LCAs necessary to get the suggested settings?
Old 07-05-2018, 11:33 PM   #3
new2subaru
Weight Weenie
Drives: 15 FR-S
I have RCE Yellows installed with front Camber bolts.
I'm 1.5 Front and 2 Rear. So far, it seems fine and have had it at the track twice. I don't think anything else needs to be done.
Tires make the biggest difference IMHO. I run the stock tires, 225/50 R16 Firehawk 500's and recently 205/55 R16 Hankook RS-3's.
The 205's RS-3's with RCE Yellows are amazing on the street! The ride is much more composed than stock and the extra sidewall makes daily driving much more comfortable. I'll be on track with them in a couple of weeks.
Old 07-06-2018, 08:40 AM   #4
cjd
cjd's Avatar
Drives: 2017 BRZ
-3°/-2.3° f/r. Or as close to -3° as your wheel/tire setup allows. Zero toe.
No less than -2.5°/-2°.
Old 07-06-2018, 11:49 AM   #5
tyler_win_photo
tyler_win_photo's Avatar
Drives: 2014 Scion FRS (Asphalt)
With a mild drop LCAs may not be necessary. The rear camber on our cars vary greatly from the factory. So you may be in the -2 range or -1.5 range after your drop. Best to get an alignment check prior and see where to go from there.
Personally as a daily I like to run -1.5 rear and -2 to -2.5 front camber. With 0 toe all around.
tyler_win_photo is offline   Reply With Quote
Old 07-06-2018, 12:45 PM   #6
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
My car is a DD with a splash of autox.
-2 F and -1.5 R.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 07-06-2018, 01:29 PM   #7
DarkSideFRS
Drives: 2013 pearl white FR-S
-1.7F and -1.3R
as long as the front has more negative camber, the car will be more responsive
DarkSideFRS is offline   Reply With Quote
Old 07-06-2018, 04:46 PM   #8
Horrid_Funk
Horrid_Funk's Avatar
Drives: 2017 DGM BRZ PP
The other camber suggestions seem pretty good. There's a limited amount of camber you can get in the front with bolts so that's your limiting factor. Try to max out front camber with the bolts you have, and have rear camber be about -0.5 below it. So if you can get -2.0 do the rears at -1.5. That seems pretty common and it feels good on track to me.
As for toe, 0 toe all around is a common recommendation. My shop recommended the slightest toe-in rear. Apparently as the car squats during acceleration it will slightly toe-out under the load so having a little toe-in will make the car more stable under acceleration.
Horrid_Funk is offline   Reply With Quote
Old 07-06-2018, 04:53 PM   #9
ZDan
ZDan's Avatar
Drives: '23 BRZ
Maximize front camber with bolts, zero toe all around, done.
I disagree with the idea that front camber *must* be greater than rear. It probably won't be with camber bolts and lowered ~1", but that's fine. No need for LCAs...
Old 07-07-2018, 12:00 AM   #10
Geese1
Geese1's Avatar
Thanks for all the suggestions!
I was thinking something like -2.0 front camber / -1,5 rear camber, with 0 toe up front and 1/16th in the back.
Would that be a good setting? I'm not interested in the stance look, and instead looking to get good performance while also retaining the ability to drive it on normal, non-spirited runs as necessary.
Old 07-07-2018, 03:33 AM   #11
churchx
churchx's Avatar
Drives: 2014 GT86
Sounds good and rather commonly chosen performance alignment for those that mostly daily drive. You should be ok.
churchx is online now   Reply With Quote
Old 07-07-2018, 06:36 AM   #12
ZDan
ZDan's Avatar
Drives: '23 BRZ
I wouldn't fixate on trying to hit specific camber numbers as long as it's left/right symmetrical within reason (~0.25°). Just max the front with bolts and run whatever natural camber you get in back from lowering. Zero to 1/16" (0.14°) *total* rear toe should be fine.
Old 07-07-2018, 03:29 PM   #13
carlovestela
Drives: 2015 Firestorm FRS
How about mine?
-0.4 front -2.2 rear
Running stock suspension with trd springs
Daily drive only
carlovestela is offline   Reply With Quote
Old 07-07-2018, 03:37 PM   #14
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
-1.5 rear and -2 front. it will fell nice for daily and stuff.
Recommendations for alignment in Bay Area Surj_brz Northern California 9 06-09-2017 12:26 PM
Need alignment spec recommendations 8RZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 05-10-2017 09:53 PM
Alignment recommendations for my setup? sqd Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-19-2016 01:33 PM
Alignment shop recommendations? (SEA) Koa Northwest 7 02-16-2015 07:18 PM
Recommendations for alignment in Socal anewprelusion Southern California 18 01-13-2014 02:36 PM
