Old 07-01-2018, 06:39 PM   #351
Tactrix cable see tactrix link below or i just bought a kess v2 clone and it works fine as well
Would it be possible to search through a ROM backup with a hex editor? Maybe edit them manually? If you found all four of those values close together in the file...
Old 07-02-2018, 01:22 AM   #352
steve99
Drives: FT86
Originally Posted by TheStig85 View Post
Just harassing James Martin (tuner in Florida) and he says it's mostly likely a sensor or OCV that's bad. He says its a PID system, so it has a learned value.
He's recommending to just swap sensors and/or OCVs. Pull the battery, wait a few minutes to reset it.
Sent from my Pixel 2 XL using Tapatalk
Thats what i think is logical , and i agree with james but havent you already chamged all that stuff once ??, Id check the sensor clearances as per tsb as well
Old 07-02-2018, 01:26 AM   #353
steve99
Drives: FT86
The rom area is fixed values any variable data is storred in ecu ram which is reset when you remove power from ecu. But their may be some other memory on ecu thats non volitile that may only be reset on a reflash but im jist guessing. Thier is other stuff storred in ecu like the vin number thats not in the main microcontroller. And it isnt reset with reflash or when you remove power you have to specifily address that area.
Old 07-02-2018, 11:41 AM   #354
TheStig85
Drives: 2013 Subaru BRZ
Just out of curiosity... Doesn't these CELs plague the early 2013 models of our cars? If that's the case, what changed between 2013 and 2014 models?
I'm in a chat group with local owners, and they all said to just swap the engine as that's the only fix. I think that's ridiculous and there has to be a fix, but as we don't know the root cause, it's hard to repair it.
TheStig85 is offline   Reply With Quote
Old 07-02-2018, 12:37 PM   #355
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
My early 13 still doesn't have teh plague at 67k miles.
Old 07-02-2018, 01:22 PM   #356
kinghurl
Drives: BlueBurz
Is your car modded at all? Ecu, rev limiter, pre cat exhaust?
Is it driven in anger....on weekends? Not like an angry jockey, but more like GTA? Oil change intervals? Perhaps built by old German engine builders with their signatures under the manifold...
Seriously, some of the above may matter.
Sent from my SM-G930V using Tapatalk
kinghurl is offline   Reply With Quote
Old 07-02-2018, 01:37 PM   #357
bcj
Geo Tyrebighter Esq
bcj's Avatar
Stock.
Though I use it to go for moderately long drives to places with more livestock than people.
Usually at the posted speed.
Could it be the hard parking that many seem attracted to?
Old 07-02-2018, 01:43 PM   #358
Stock.
I still think the secret failure is from shit jamming the main valve. The one I worked on came back. He's been driving it without issue for months now.
kinghurl (07-02-2018), TheStig85 (07-02-2018)
Old 07-02-2018, 01:46 PM   #359
TheStig85
Which main valve?
Old 07-02-2018, 01:49 PM   #360
And it isnt reset with reflash or when you remove power you have to specifically address that area.
Is the procedure to reset or write to those other areas of NVRAM known outside the big house? Some jumpers, or a bench test system of some sort?
Old 07-02-2018, 01:53 PM   #361
Which main valve?
The one that the OCV solenoid operates. I think it's a matter of getting to it in time, before that ECU table goes too far out of whack.
All I have is my one success story, though. My friend got in touch with me as soon as his car threw the code, and we dug into it right away.
edit: It's number 3 on this exploded view, the 'spool valve.'
Old 07-03-2018, 04:52 AM   #362
steve99
Drives: FT86
I dont think so.
Way to test would be to get one of the ecu from a car thafs had cam issues then use that ecu in a knwn good car jist reflashed to correct calid
Ultramaroon (07-03-2018)
Old 07-03-2018, 04:29 PM   #363
SLVRSRFR
Drives: 2013 BRZ 6MT, 2007 WRX Wagon 5MT
FINALLY got my most recent code scanned, the one that keeps flipping on and off, and thankfully it seems to have nothing to do with P0018 or P0016.
Code I'm getting is P0351, which is Ignition Coil related. It's just weird that this code only started to pop up AFTER having my P0018 repair performed, but it is what it is.
@bpennerz
SLVRSRFR is offline   Reply With Quote
Old 07-04-2018, 12:13 AM   #364
rusty959
Drives: DGM BRZ limited
I dont think so.
I haven't been keeping up with this thread so I may have missed something, but if anyone wants to test this, I'd probably give up my original ECU. Still haven't sold my BRZ but I don't much have a use for my old one.
rusty959 is offline   Reply With Quote
P0016 fixable without new ECU? Mr.Jay Issues | Warranty | Recalls / TSB 8 02-06-2022 05:15 AM
P0016/P0017 cause AVOturboworld Issues | Warranty | Recalls / TSB 18 04-16-2021 11:09 PM
P0016 Code Shady195 Engine, Exhaust, Transmission 30 02-21-2019 02:31 PM
p0016 need help asap lol Issues | Warranty | Recalls / TSB 25 10-30-2018 03:49 PM
OFT P0016 and TSB question mmmcambelsoup Software Tuning 10 05-24-2017 09:24 AM
