Old 06-16-2018, 01:16 AM   #337
steve99
Drives: FT86
@Ultramaroon
tried techstream 9 no go up dated to techstream 12 still no vvt initial function, had to change to North america version as euro version doent have that function weird
Ultramaroon (06-16-2018)
Old 06-16-2018, 01:31 AM   #338
@Ultramaroon
Wow! We are peeling back layers of the secret onion. That's very interesting.
Notice how our numbers match pretty well except for Stig's bank-1 intake.
steve99 (06-16-2018), TheStig85 (06-16-2018)
Old 06-18-2018, 10:18 AM   #339
TheStig85
Drives: 2013 Subaru BRZ
I'm willing to change whatever's necessary, but this is mostly beyond me. Any advice you guys have I'll try it.
TheStig85 is offline   Reply With Quote
Old 06-18-2018, 11:01 AM   #340
Keep clearing codes and watch to see if "vvt initial position learning value #1" changes over time. If it stays at exactly 45.52 every time you read it, then your ECU is toast.
If it rises at all, it's re-learning. Roll with it.
That's my best guess at this point.
Icecreamtruk (06-18-2018)
Old 06-18-2018, 11:11 PM   #341
kinghurl
Drives: BlueBurz
This!
Monitor and see the rate of change of the learn values. Allegedly it's SLOW....that's what prompted me to change my ecu....again.
Sent from my SM-G930V using Tapatalk
kinghurl is offline   Reply With Quote
Old 06-29-2018, 10:14 PM   #342
TheStig85
Originally Posted by kinghurl View Post
This!
Well...... I haven't said anything on here as I was just driving my car daily. Not sure if it matters or not but I've been clearing the codes every time I entered my car.
Just checked the Learning VVT Values and they are basically identical. Only things that were changed were the Exhaust VVT values, and only by 0.10 or so.
What's left to do ? Lol. Change the ECU, again?! Ugh...
The Following User Says Thank You to TheStig85 For This Useful Post:
Ultramaroon (06-30-2018)
Old 06-29-2018, 10:55 PM   #343
steve99
Drives: FT86
If the learn value or values dont change it may also be that the ecu isnt seeing correct info from cam position sensors as per pist here
http://www.ft86club.com/forums/showp...&postcount=334
Old 06-30-2018, 12:36 AM   #344
TheStig85
I was going off the Learning values in Tech stream. You pull them when the engine is off.
Sent from my Pixel 2 XL using Tapatalk
Old 06-30-2018, 01:10 AM   #345
Or more likely, the valve timing is correct but, because the ECU "normal" initial position drifted off over time, it's now stuck interpreting the sudden shift to correct operation as abnormal.
Old 06-30-2018, 01:50 AM   #346
steve99
Drives: FT86
Maybe re flash ecu to hopefully reset vvt learned valies to initial settings
The Following 2 Users Say Thank You to steve99 For This Useful Post:
TheStig85 (07-01-2018), Ultramaroon (06-30-2018)
Old 07-01-2018, 05:16 PM   #347
TheStig85
Being the unexperienced one here, what's the easiest way to reflash it? I've never done it before.
Ultramaroon (07-01-2018)
Old 07-01-2018, 06:23 PM   #348
Me neither.
It would be great to find out otherwise but I believe if the issue could be fixed with a factory flash, basically a hard reset of the ROM, it would be the standard procedure. It's much quicker & cheaper than replacing the ECU.
This is where you have to make the choice between doing it for science, or just getting back onto the road. I respect the science-&-knowledge approach but it's your whip.
*popcorn gif*
Old 07-01-2018, 06:27 PM   #349
steve99
Drives: FT86
Me neither.
Tactrix cable see tactrix link below or i just bought a kess v2 clone and it works fine as well
Old 07-01-2018, 06:37 PM   #350
TheStig85
Just harassing James Martin (tuner in Florida) and he says it's mostly likely a sensor or OCV that's bad. He says its a PID system, so it has a learned value.
He's recommending to just swap sensors and/or OCVs. Pull the battery, wait a few minutes to reset it.
P0016 fixable without new ECU? Mr.Jay Issues | Warranty | Recalls / TSB 8 02-06-2022 05:15 AM
P0016/P0017 cause AVOturboworld Issues | Warranty | Recalls / TSB 18 04-16-2021 11:09 PM
P0016 Code Shady195 Engine, Exhaust, Transmission 30 02-21-2019 02:31 PM
p0016 need help asap lol Issues | Warranty | Recalls / TSB 25 10-30-2018 03:49 PM
OFT P0016 and TSB question mmmcambelsoup Software Tuning 10 05-24-2017 09:24 AM
