#15 |
I bent the " inductor ring" I believe it was called, which is what the wheel speed sensor monitors. I dont think you'll have any problems driving in limp mode, I never read anything about sporadic braking fits or unpredictable driveability, iirc the abs system either works or it doesnt, which should be why the lights come on shortly after startup and stay on until they're cleared or restart the car.
Sent from my SM-G950U using Tapatalk
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
#16 | |
Drives: scion frs
#17 | |
Drives: scion frs
[quote=humfrz;3102977]
| The Following User Says Thank You to kuyumoy For This Useful Post: | humfrz (07-01-2018) |
#18 | |
Drives: scion frs
| Broke a TPMS sensor, process with ATEQ Quickset and new TPMS Sensor? | Anthonyc77 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 03-19-2018 08:57 PM |
| So i broke my wheel speed sensor | bkblitzed | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 11-18-2016 04:04 PM |
| Broke Oxygen Sensor during Header Replacement - Can i run w/o one? | Adeel | Engine, Exhaust, Transmission | 7 | 05-20-2014 02:12 PM |
| Greddy informeter, boost sensor, boost sensor harness, info touch sensor apaptor | Supra2k | Audio/Visual, Electronics, Infotainment, NAV | 1 | 02-26-2014 08:11 PM |
