Old 06-25-2018, 08:42 PM   #1
Ricks919
Drives: 2014 BRZ brand new!
thinking out loud...
so I ended up getting a 2015+wrx factory turbo for free the other day, in good condition no less. anyway, im thinking of making a "custom" turbo kit out of it as a long term project.
model is GARRETT MGT2259S, cute little twin scroll unit.
I like that its a smaller, twin scroll turbo for spooling purposes.. even if it is all at awkward angles as far as air in/out/exhaust side etc.
i bet i could get a custom turbo manifold made up, something similar to JDL's uel manifold for rumbly noises (is a MUST lolol)
everything else could pretty much be tuned via ecutek like any other turbo kit i imagine.
for pump gas probably run it around 8-10 psi or so.
anyway, just sharing my idea in hopes of sparking discussion, wondering what you all think? i know a few people here have made their own kit and im sure most of you know more on the subject than i do.
Ricks919 is offline   Reply With Quote
Old 06-25-2018, 08:53 PM   #2
Ricks919
particularly wondering what you all think about running this turbo at about half the boost levels as the wrx it was designed for.. you guys think that would cause any issues ?
Old 06-25-2018, 08:56 PM   #3
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
I'm not sure if it would fit, but some kits use Garrett turbos, so you might be able to get a kit minus the turbo since you already have one.
Seems that the cost in labor with making a custom kit would negate any savings. You might be best off trying to sell this turbo that someone gave you, and then buy a used kit. The combination would make for decent savings.
Old 06-25-2018, 09:18 PM   #4
Ricks919
its not really about saving money, its more about intentnionally using a smaller turbo for spooling / response reasons. im sure physically it would fit with the right manifold, few turbo kits run twin scroll to begin with and most turbo kits are using larger turbos than this one
im a technician and would be doing all the install myself, would need custom turbo manifold and down pipe, intercooler kit and that about it really. already have ecutek so would just need to pay my preferred tuner, just the cost of custom dyno tune.
but again, the goal isnt to save money, the goal is turbo responsiveness
Old 06-25-2018, 09:34 PM   #5
valtore101
Drives: 2016 FR-S
That turbo will run out of juice at around 6500 rpm.
valtore101 is offline   Reply With Quote
Old 06-25-2018, 09:48 PM   #6
Ricks919
Hmm... Where can I look up specs/ info on that?
Are you just basing that on the WRX redline? I'm not sure how that would work considering AVO uses a smaller turbo and seems to work fine up intil our 7 & 1/4 whatever redline
Old 06-26-2018, 01:09 AM   #7
Turbo
Drives: FR-S Turbo
Sometimes you can unbolt the compressor housing from the center section, re-orient it, apply new sealer and bolt it back up.
This could improve the 'awkward angles' issue a bit
Turbo is offline   Reply With Quote
Old 06-26-2018, 10:18 AM   #8
Sarang
Drives: 2010 LGT
https://www.cobbtuning.com/dyno-database/
Cobb seems to be able to hold ~15psi up to ~6700rpm, therefore if you want less than that at redline, this might be a good turbo for you.
Sarang is offline   Reply With Quote
Old 06-26-2018, 10:35 AM   #9
yelsew
Little Member
yelsew's Avatar
Drives: Bloo - The 13' BRZ
I dont know how well that turbo will play with a UEL header configuration. The 2015 WRX switched to equal length runners because of the twin scroll turbo so it could receive equal exhaust pulses through the two different exhaust paths. The two halves of the twin scroll housing need to be driven symmetrically.
This has been discussed for latest gen WRX aftermarket UEL headers ad nauseum before and it has pretty much ruled no-go.
<--- My Journal
People just need some #drivermod in their life.
yelsew is offline   Reply With Quote
The Following User Says Thank You to yelsew For This Useful Post:
Irace86.2.0 (06-26-2018)
Old 06-26-2018, 11:58 AM   #10
Irace86.2.0
I think when you look at the stock torque curve of the WRX you see the torque peak early then drop pretty quickly and fizzle out around 6500. This could be because the WRX engine fizzles out anyway. I don’t know if you run less boost with higher compression that things will balance out or if the turbo will fizzle out even sooner.
https://www.roadandtrack.com/new-car...ru-wrx-vs-sti/
Old 06-26-2018, 12:06 PM   #11
CSG Mike
CSG Mike's Avatar
My WRX would disagree with that.
perrin catback resonated - loud enough or too loud? theflathead Engine, Exhaust, Transmission 33 01-22-2018 05:46 PM
Thinking of getting a BRZ JayChris BRZ First-Gen (2012+) — General Topics 30 07-22-2017 07:24 AM
Thinking of getting an FR-S, but is it for me? Granovsky Scion FR-S / Toyota 86 GT86 General Forum 49 03-11-2015 07:48 PM
Thinking out loud. . . cycleboy Cosmetic Modification (Interior/Exterior/Lighting) 4 03-10-2015 11:04 PM
Thinking of the FR-s dun3 Southern California 17 10-22-2012 12:29 PM
