Old 07-21-2017, 02:29 PM   #1
JayChris
Drives: looking at BRZ
Thinking of getting a BRZ
I am new to this group and i currently do not own a BRZ, I drive a newer E350 Mercedes coupe. I wouldn't consider myself a car expert because I am used to driving newer cars with no custom work or anything but any advice is greatly appreciated. I am still keeping the Mercedes but I am looking to buy a used BRZ and do some custom work to it. I would most likely be putting a body kit on it (like a matte grey wrap), i am not to fond off slamming it and making it super low, although if it gets slightly lower i am okay with that. I realize the speed is a lot slower, but i am thinking of a Cossworth stage two supercharger to add to it, making the speed a little better. I am wondering everyones thoughts on that and if there are a lot of problems with the supercharge and BRZ in general. I am doing BRZ because i love the look and for 15-18k i can get a slightly used one and have budget left over for custom work
JayChris is offline   Reply With Quote
Old 07-21-2017, 02:34 PM   #2
improvius
Drives: 2017 series.yellow BRZ, 2015 X1
How much time have you spent driving one? Serious question, because I wouldn't make plans for performance upgrades until after you've been behind the wheel for a while. You might even be satisfied with the stock power.
improvius is offline   Reply With Quote
The Following 3 Users Say Thank You to improvius For This Useful Post:
Dadhawk (07-21-2017), spike021 (07-21-2017), Tcoat (07-21-2017)
Old 07-21-2017, 02:36 PM   #3
spike021
spike021's Avatar
I have no problems getting up to 80 at least and I could easily push it further.
If anything the acceleration can be "slow" if you're in the torque dip range. But the car itself isn't slow.
spike021 is offline   Reply With Quote
Old 07-21-2017, 02:51 PM   #4
Azzudien
Drives: 2017 Series Yellow BRZ
It is a good project car and there is a large aftermarket available which is nice. Highly recommend getting one and then driving it for awhile before you spend any money on modifications.
I bought one new and had several thoughts on things I wanted to do, but after I actual started driving it that list changed quite a bit. Thoughts of power and engine mods all changed to suspension and brakes.
My car is quickly turning into a track car. Just hit 3000 miles, and already has 5 Track days on it and 1 autox. Ideas put on back burner for now that where some of the first things I wanted to dobefore buying car.
1. Forced Induction
2. Exhaust
3. Tune/Flex Fuel
Actual Mods that have happened instead
1. Camber bolts/Alignment
2. Ferodo DS2500 pads
3. Wheels and tires (ordered not on yet)
As you can see, after driving the list changed dramatically and also got way way cheaper.
Azzudien is offline   Reply With Quote
The Following User Says Thank You to Azzudien For This Useful Post:
Tcoat (07-21-2017)
Old 07-21-2017, 02:57 PM   #5
JayChris
I have test drove them and have drove friends BRZ's. My brother owns a 2017 C63s so i am used to driving the power. I would most likely get the BRZ in the next week or two and order the kit too. if you type BRZ in google and go to images, you will see a matte grey one with custom accessories, that is sort of what i am among for look-wise. I am assuming i would have to buy the Kit and matte wrap it and the car then apply it. but as far as the supercharger i could drive it stock for a while and then add it. Is the cossworth the easiest way to gain HP and speed?
Old 07-21-2017, 03:01 PM   #6
The Following 8 Users Say Thank You to Tcoat For This Useful Post:
BaatLuk (07-21-2017), extrashaky (07-21-2017), JMon85 (08-04-2017), JonRZ (07-22-2017), Somerandom18 (07-21-2017), spike021 (07-21-2017), Spuds (07-21-2017), Veloist (07-22-2017)
Old 07-21-2017, 03:04 PM   #7
Azzudien
I am definitely not going to open that can of worms as to what is easiest way to gain HP, so I will kindly point you in this direction
http://www.ft86club.com/forums/forumdisplay.php?f=78
Old 07-21-2017, 03:26 PM   #8
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
This car is definitely a good project car. It is a good basis, and with plenty of FI options available and MANY different setups running around you should be able to find the answers to your questions. The cosworth kit is not the most common kit out there, and if you're planning on that anyways....look in to the edelbrock. Supercharging is not the easiest way to make power though, most "high hp" setups are turbo. You have got to determine what your priority is.... high hp, reliability, ease of install, etc, etc.
Bodykits right off the bat, lame. Power mods right off the bat, almost a requirement.... Do the right mods the first time. Don't waste money on stupid shit.
Old 07-21-2017, 04:05 PM   #9
JayChris
Thank you for the advice, but would it be pointless to add a turbo if i eventually do a supercharge? because i would hate to spend the money on a turbo or two and realize I need more and have to get rid of turbo's. Generally what do turbo's add vs supercharges?
Old 07-21-2017, 04:12 PM   #10
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Civic Type R /endthread.
Current DD: M235i
8RZ is offline   Reply With Quote
The Following 2 Users Say Thank You to 8RZ For This Useful Post:
DaBoBo21 (07-21-2017), weederr33 (07-21-2017)
Old 07-21-2017, 04:15 PM   #11
JD001
JD001's Avatar
Drives: Subaru BRZ
Forget the BRZ as it will be too slow for you. If I was you I would go for the Toyota GT86 as the car is much, much, much quicker due to it having more aerodynamic badging, more aggressive front spoiler that acts as a vortex/vacuum thingy creating a air flow bubble just in front of the Scion/Toyota badge hence helping it cleave a clean shape through the air... and GT on any car adds kudos!
The Following User Says Thank You to JD001 For This Useful Post:
Old 07-21-2017, 04:43 PM   #12
extrashaky
Drives: 2014 BRZ Limited
Not a requirement unless you're trying to race Mustangs red light to red light. In which case, you're doin' it wrong.
The Following User Says Thank You to extrashaky For This Useful Post:
Old 07-21-2017, 05:01 PM   #13
Ernest72
Drives: 16 Silver BRZ, 04 Silver WRX wagon
Having done these types of project cars many times, here is my advice.
Buy car and drive stock for a few months. Then upgrade one thing at a time so you can feel or not feel the difference. If its just a DD and some spirited driving, the stock suspension may be fine. Probably get better tires, that makes the biggest difference.
As for power - I would do a stage 1 plus exhaust of your choice depending on noise level, drive awhile then stage 2 with a header (UEL for subie rumble and low/mid torque, EL for HP.) After that maybe FI - supercharger or turbo.
This could take years or months depending on how crazy you get. The mod bug is a terrible disease and many of us are afflicted.
Ernest72 is offline   Reply With Quote
Old 07-21-2017, 05:12 PM   #14
Summerwolf
Panda Trueno
Summerwolf's Avatar
Why is that the only situation this car can benefit from added power?!?!?
Thinking of getting an FR-S, but is it for me? Granovsky Scion FR-S / Toyota 86 GT86 General Forum 49 03-11-2015 07:48 PM
I been thinking... Can we do this? sweetfrs Cosmetic Modification (Interior/Exterior/Lighting) 12 05-21-2014 09:51 PM
Thinking about doing this grill mod ML Cosmetic Modification (Interior/Exterior/Lighting) 11 10-25-2012 02:45 PM
Thinking of the FR-s dun3 Southern California 17 10-22-2012 12:29 PM
Any 1 thinking that they may not get either car? Shora BRZ First-Gen (2012+) — General Topics 40 04-06-2012 09:59 PM
