Old 06-22-2018, 01:20 AM   #15
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Originally Posted by DarkPira7e View Post
I only suggest not going thick because you're asking about the winter grade. Your oil is still lubrication on a cold start. A 5 winter oil is thicker when cold than a 0. When cold. Cold. When your oil heats up, it has the viscosity of an SAE grade 30 oil were it a 0w30 or a 5w30.
If the turbo doesn't affect your cold temps (which it doesn't) you wouldn't want to make cold oil thicker right?
**EDIT**
just realized you changed the 20 to a 30. That's the only place you'll find merit is increasing the warm grade. A 0w-30 would be ideal..
Still, and yet, Subaru recommends 5w30 on their turbo engines. Why do you think that is? I mean really, why?! I don't know. Is it because 0w30 is hard to find or is more expensive?
Old 06-22-2018, 08:03 AM   #16
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Well, to be frank, adding a turbo does not change the clearances in the block or other things they may have fine tuned with our unique high compression fa20 block. Could really just be because Toyota had a say and wanted better emissions, it's likely something far less worth our speculation than we could imagine. As I had said, the FA20 was far different than the EJ motors and maybe they just decided to try a light oil
Old 06-22-2018, 10:12 AM   #17
Irace86.2.0
The FA20DIT in the Forester XT and WRX and the EJ in the STI run 5w30. The newer (?) fb20dit (?) runs 5w30. Every NA engine in their current lineup like the Crosstrek, Imprezza, etc including the BRZ run 0w20.
Old 06-22-2018, 12:02 PM   #18
gtengr
Drives: 2017 BRZ
The increased torque negatively impacts the design oil film thickness.
gtengr is offline   Reply With Quote
Old 06-22-2018, 12:23 PM   #19
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
all turbo subarus run 5w30 all NA subarus run 0w20
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 06-22-2018, 12:51 PM   #20
DarkPira7e
DarkPira7e's Avatar
Huh. Yeah I don't pay attention to Subarus, wasn't aware of the trend. Guess you've come to your own conclusion then
Old 06-22-2018, 02:32 PM   #21
Turbo
Drives: FR-S Turbo
I've read (but I can't remember where) that oils tailored to perform better at temperature extremes break down faster. ie That a 0W-50 oil fill breaks down to be something more like 10W-30 pretty quickly due to long-chain hydrocarbons shearing.
So I wonder if Subaru's thinking is along these lines - that a 5W-30 has greater longevity than a 0W-30?
Turbo is offline   Reply With Quote
The Following User Says Thank You to Turbo For This Useful Post:
Irace86.2.0 (06-22-2018)
Old 06-22-2018, 02:47 PM   #22
Turbo
Drives: FR-S Turbo
Originally Posted by Hags86 View Post
This is a scatter plot of my car of oil pressures (Y axis) vs revs (X axis) where the colour is oil temp. The data is a shakedown run on my turbo setup, maybe 5 or 6 laps with just two hot laps. Stock bottom end, 10W-40 synthetic oil, 240rwkW on e85 with an oil cooler.
What this data tells me is 10W-40 is barely thick enough. The cross is showing sample of 52.9psi at 7335rpm with oil temps of 115C. This is too low a pressure.
This graph is quite interesting.
One thing I see is that in addition to the pressures at high RPM/high temp being too low (under the target of 10psi/1K RPM) the pressures at lower RPMs with lower oil temps seem to be excessively high.
From what I've read, my guess is that dropping to a 0W-40 oil (that has a comparable 100 deg C viscosity) will drop the low temp data points to a more acceptable level.
I'm also a bit shocked that pressures were recorded in the 75-90 psi range. I figured the stock oiling system would have a bypass valve that limited excess pressures, but perhaps it doesn't?
In reality, these excess low temp pressures (on their own) would likely only be a concern on a street-driven or dual-use car. And even that could be mitigated by letting the car thoroughly warm up before driving.
HOWEVER, changing oil weight to drop these pressures could also work in concert with a new gear/oil pump drive designed to provide greater oil flow, and therefore oil pressure.
Hmmmm.
Old 06-22-2018, 08:10 PM   #23
Hags86
Drives: Toyota GTS 86
The previous data was on a track with a min oil temp of 90C or so.
This data is some daily driving. The scales of the pressure and colour have changed as oil temps here are a minimum of 17C. Lots more pressure. I wouldn't worry about too much pressure. Seeing 200psi on a cold morning isn't uncommon.
I'm having an engine built now and they'll modify the oil pressure relief valve to hold more pressure before it opens.
Hags86 is offline   Reply With Quote
Old 06-23-2018, 11:36 AM   #24
Turbo
Drives: FR-S Turbo
Do you mean modify it to have it hold more pressure or less? I do not think the relief valve opening is limiting your pressure on track.
My thinking is that having the relief valve open SOONER would allow you to run -50 or -60 weight oil, boosting high-temp high-RPM oil pressures while limiting pressures at the colder temps. It would essentially help "flatten" the pressure vs RPM curve.
In the reading I've done the last few days I did come across articles that talked about excess oil pressure 'washing' out the bearing surface.
Old 06-23-2018, 05:14 PM   #25
Hags86
Shimming the relief valve makes the spring stiffer, keeps the relief valve closed longer. Holds more pressure. You can see how the pressure raises nicely with RPM and then flattens out. Stiffening this spring should move that transition to a higher perssure/rpm point.
The 10psi per 1000rpm is a rule of thumb for minimum pressure, not a target. High pressure is not a problem.
At cold temps those thick oils don't flow and allow engine wear. Even with a lower pressure on the relief valve. You want the thinnest oil you can that holds sufficient pressure.
My engine will be finished in two days and back in the car within a week. I guess we'll know for sure then.
The Following User Says Thank You to Hags86 For This Useful Post:
Turbo (06-24-2018)
Old 06-25-2018, 05:33 PM   #26
Turbo
Drives: FR-S Turbo
Looking forward to seeing the results !
Any recommendations for shops to install turbo kit? Junbug Northern California 6 03-31-2018 07:04 PM
How many quarts of engine oil for cars with oil coolers toby714 Engine, Exhaust, Transmission 8 12-11-2014 07:16 PM
future engine configurations...and the cars they go into cdrazic93 Other Vehicles & General Automotive Discussions 1 10-07-2014 11:42 PM
Engine Swaps and Kit Cars! merlin2111 Other Vehicles & General Automotive Discussions 27 01-27-2012 05:18 PM
1.6L DI TURBO ENGINE quik1987 BRZ First-Gen (2012+) — General Topics 39 11-30-2011 06:01 PM
