Old 06-20-2018, 07:17 PM   #1
Turbo
Drives: FR-S Turbo
Engine oil recommendations for turbo cars
What weight and brand oil would the experts recommend for a turbocharged FRS? It's a stock bottom end, boosted to ~300HP. I'm running a Skunk2 racing oil cooler setup, but am mindful of increased temps given I'll be using the car on track. Mileage will be 50% track / 50% street getting to the track.
I'm in Canada, but the car will never see winter use.
I'm thinking I should run something with a bit more weight at high temps then the stock 0W-20 fill - especially to help maintain acceptable oil pressure at idle once hot.
Would a full synthetic like Amsoil or Royal Purple in 15W50 work? Or do the oil passages/clearances in the stock motor require a thinner oil?
Turbo is offline   Reply With Quote
Old 06-20-2018, 09:41 PM   #2
stock engine? stock weights.
Old 06-20-2018, 10:14 PM   #3
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I agree with Mike. These are not EJ motors, stay stock or a 5w-30 if you feel compelled to be racecar. You've got an oil cooler so you should be OK. If you're really concerned with oil pressure, look into an accusump
Old 06-20-2018, 11:01 PM   #4
max20s14
Drives: 14' Raven M/T - 02' is300
mobil 1 makes a 0w-30 for what its worth but idk much
max20s14 is offline   Reply With Quote
Old 06-21-2018, 01:25 AM   #5
Turbo
Drives: FR-S Turbo
I'm asking about oil weight because I had read about ppl having trouble with oil pressure under 2 situations with these cars, once the oil was hot:
1) Difficulty maintaining at least 10psi oil pressure at idle; and
2) pressure dropping at high RPM on track.
Are these not problems with these cars? And are they not exasperated when you're running a turbo?
What I don't know, is what kind of oil temps these guys were running when experiencing those problems.
So - what is the safe temp range? And at what temp should I be immediately pulling into the pits?
I will be running full synthetic - either Mobil 1 or Royal Purple.
Old 06-21-2018, 07:08 AM   #6
steve99
If your pil cooler can keep oil temps below about 115C you should be ok . With low viscosity oils
Most guys with FI usually run 5w30 or 0w30 or 5w40 0w40
Old 06-21-2018, 07:29 AM   #7
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Mobil 1 5w-30. Ran it for 3+ years boosted of hard driving on a hot climate. I wouldn't get caught up in all the amazing (and extra expensive) oils out there unless you plan to track it heavily.
Old 06-21-2018, 03:38 PM   #8
Hags86
Drives: Toyota GTS 86
The answer is the thinnest possible oil that gives sufficient oil pressure. Get an oil pressure gauge.
This is a scatter plot of my car of oil pressures (Y axis) vs revs (X axis) where the colour is oil temp. The data is a shakedown run on my turbo setup, maybe 5 or 6 laps with just two hot laps. Stock bottom end, 10W-40 synthetic oil, 240rwkW on e85 with an oil cooler.
As you can see oil pressure drops away steeply as oil temps increase. The rule of thumb is you want 10psi of oil pressure per 1000 rpm. E.g. 70psi at 7000rpm. The more power the engine makes the more oil pressure you need.
What this data tells me is 10W-40 is barely thick enough. The cross is showing sample of 52.9psi at 7335rpm with oil temps of 115C. This is too low a pressure.
I think an xw-30 will be too thin at elevated temperatures on a track after a few laps. A 40 weight is the minimum on a stock bottom end. I'd have no hesitation running a 50 weight if you were happy to do an oil change before and after track days as you mentioned.
An oil cooler and oil pressure gauge are both essential items if you are tracking this with a turbo.
Hags86 is offline   Reply With Quote
The Following 4 Users Say Thank You to Hags86 For This Useful Post:
chaoskaze (06-21-2018), flippy (10-03-2022), Irace86.2.0 (06-21-2018), Turbo (06-21-2018)
Old 06-21-2018, 03:59 PM   #9
Turbo
Drives: FR-S Turbo
This is a scatter plot of my car of oil pressures (Y axis) vs revs (X axis) where the colour is oil temp. The data is a shakedown run on my turbo setup, maybe 5 or 6 laps with just two hot laps. Stock bottom end, 0W-40 synthetic oil, 240rwkW on e85 with an oil cooler.
Thanks, Hags for your very thorough reply! May I ask what brand/line of 0W-40 you were running?
I've been looking up specs on various oils, focusing mainly on the Viscosity numbers @ 100 deg C and @ 40 deg C. What I'm finding is there is quite a variance brand-to-brand within a given spec'd oil weight.
My thinking is that if 2 oils have a comparable viscosity at 40 deg C (meaning they will pump similarly when 'cold') the one with the higher viscosity at 100 deg C would maintain pressure better as temps increase.
I already have an oil cooler and oil temp gauge, but will now look at installing a pressure gauge as well. Finding a place to put it could be a bit of a challenge, though!
Old 06-21-2018, 04:56 PM   #10
Hags86
It is Penrite 10 Tenths Racing 10W-40 (I know I said 0W-40 in the post but when I went to check it was actually a 10W-40. I have edited my post to reflect that.
Maybe there is differences between brands with the same rating. I've never looked. The first number is the cold temp but this is below freezing temps, not at 40C. The second number is the viscosity at 100C. So a 10W40, 0W40 or a 20W40 should be the same viscosity at 100C.
The Following User Says Thank You to Hags86 For This Useful Post:
Turbo (06-21-2018)
Old 06-21-2018, 05:17 PM   #11
Hags86
The place to learn about this stuff is the Bob the Oil Guy "motor oil university" page
https://www.bobistheoilguy.com/motor-oil-101/
Turbo (06-21-2018)
Old 06-21-2018, 05:54 PM   #12
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
OEM turbocharged Subarus use 5w30--not 0w20. Why would 5w30 not be the minimum? Then he could use thicker oil if there are serious track days.
https://www.patriotsubaru.com/synthetic-oil.htm
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
Turbo (06-21-2018)
Old 06-21-2018, 07:33 PM   #13
Hags86
I really like this logic. OEM's are forced to make so many compromises with their recommendations and design it is impossible to get one recommendation for everyone.
A 0W-20 is great for a car that isn't tracked, doesn't have a turbo and the associated heat it generates, needs to protect the engine when starting the car and driving 1km to the shops to buy some milk, whilst optimising fuel economy. 0W-20 might also be just OK for a NA car doing a hot lap or two in the overall balance of "best oil".
It's a hard compromise for the Toyota and Subaru engineers to balance all these requirements. But that doesn't mean follow the OEM book when you have a turbo and are driving hard for extended periods.
Interestingly the GT86 OEM Toyota race series in Australia a lot of the competitors use 0W20. That is because it is a fixed spec race series (oil weight is free spec) and very thin 0W20 sucks less engine power that pumping a 50w. Those extra few HP are whats needed to win and they just accept the fact they will destroy engines doing it. If you are in a competitive form of motorsport where 5HP is the difference between winning and not, then protect the engine and make sure there is enough pressure when the oil is hot.
The Following 3 Users Say Thank You to Hags86 For This Useful Post:
Irace86.2.0 (06-21-2018), Limitless_BRZ (05-22-2021), Turbo (06-21-2018)
Old 06-21-2018, 10:02 PM   #14
DarkPira7e
DarkPira7e's Avatar
I only suggest not going thick because you're asking about the winter grade. Your oil is still lubrication on a cold start. A 5 winter oil is thicker when cold than a 0. When cold. Cold. When your oil heats up, it has the viscosity of an SAE grade 30 oil were it a 0w30 or a 5w30.
If the turbo doesn't affect your cold temps (which it doesn't) you wouldn't want to make cold oil thicker right?
**EDIT**
just realized you changed the 20 to a 30. That's the only place you'll find merit is increasing the warm grade. A 0w-30 would be ideal..
Any recommendations for shops to install turbo kit? Junbug Northern California 6 03-31-2018 07:04 PM
How many quarts of engine oil for cars with oil coolers toby714 Engine, Exhaust, Transmission 8 12-11-2014 07:16 PM
future engine configurations...and the cars they go into cdrazic93 Other Vehicles & General Automotive Discussions 1 10-07-2014 11:42 PM
Engine Swaps and Kit Cars! merlin2111 Other Vehicles & General Automotive Discussions 27 01-27-2012 05:18 PM
1.6L DI TURBO ENGINE quik1987 BRZ First-Gen (2012+) — General Topics 39 11-30-2011 06:01 PM
