Old 06-24-2018, 04:02 PM   #15
wparsons
wparsons's Avatar
Originally Posted by BRZ.604 View Post
Hey Eric, thanks for the support. I live in Canada so sending it back and forth will takes to much time. Ft86speedfactory email me the bearing part number so I will get another set and replace it.
Do those bearings have to be pressed in? If so, I doubt you've got the tools at home to remove and replace the bearing.
flickr
Old 06-24-2018, 04:13 PM   #16
BRZ.604
BRZ.604's Avatar
Drives: Project BRZ
Yes it has to be pressed out and in. It has a circular clip holding the bearing in place at the bottom. I own a repair shop, so fortunately I have the tools to get the get the job done.
BRZ.604 is offline   Reply With Quote
The Following 2 Users Say Thank You to BRZ.604 For This Useful Post:
norcalpb (06-24-2018), wparsons (06-25-2018)
Old 06-25-2018, 09:51 AM   #17
wparsons
wparsons's Avatar
Ah, yeah... you'll be fine then!
flickr
Old 06-25-2018, 10:44 AM   #18
Racecomp Engineering
We've also seen a lot of improper installs of camber plates on these cars, often people forgetting to put a support washer or lower bushing under the bearing (between camber plate and upper spring perch. Not saying that's the case here, but it happens.
- Andrew
VerusEric (06-25-2018)
Old 06-25-2018, 11:22 AM   #19
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
Let us know if you have any questions. Sales@verus-engineering.com
- Andrew
Andrew,
We've seen the same thing a handful of times.
Eric
VerusEric is offline   Reply With Quote
The Following 2 Users Say Thank You to VerusEric For This Useful Post:
Racecomp Engineering (06-25-2018), wparsons (06-25-2018)
Old 06-25-2018, 01:50 PM   #20
Roadcone
StreetKart
Drives: 2014 Scion FR-S Monogram
spherical bearings make noise. That's part of why the oem's use rubber to keep things quiet.
BECAUSE RACECAR
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
Roadcone is offline   Reply With Quote
The Following User Says Thank You to Roadcone For This Useful Post:
Hyper4mance2k (06-26-2018)
Old 06-25-2018, 02:18 PM   #21
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Aside from a few minor issues (upper spring perch rub on plate, loose top nut [user error on that one], and the occasional spring pop that went away) my camber plates have been perfect, almost imperceptible impact to NVH when swapping onto stock suspension (no confusion with the impact of installing coilovers and linear springs) and for the nearly 40k miles since (including a new set of coilovers, several spring swaps, track, autox, and shitty roads).
Maybe I got a set that was perfectly in tolerance but for this car I'd be disappointed with any camber plate that a passenger could notice. Not trying to trash anybodies brand, nor hawk any wares, I've talked to a few people not as lucky with the same camber plates that I have who couldn't tolerate them.
I'll be swapping suspension soon, it'll be interesting to try a different plate, but if they're noisy, my old ones will go back on or I'll buy a new set of the same brand.
ineedyourdiddly
Old 06-26-2018, 03:55 AM   #22
churchx
churchx's Avatar
Drives: 2014 GT86
My experience with plates (not Velox's though) on stock shocks was way different NVH wise. Bad enough to uninstall them. Issues were noticeable by everybody in car, both me & passenger, and i even had to adjust driving style/paths when meeting those road imperfections that caused worst NVH issues/loud hits heard in cabin.
Old 06-26-2018, 12:13 PM   #23
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
I had a clickity clack that was very reminiscent of a bad spherical bearing. I thought mine were bad (after being hit by a dump truck) so I bought new ones from Verus. In the accident, the strut was bent, the lower control arm was bent, the knuckle was broken, the ball joint broke in half, but the bearings in the strut hats were fine. I ultimately found the knock was coming from the swaybar endlinks.
Also, your video doesn't sound like a bad spherical bearing at all. When they're bad it is usually a clickity clack, and a loud slapping sound. (My Rx7 Track car would eat them in the rear lower control arms)
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
Old 07-22-2018, 02:33 AM   #24
botbs
botbs's Avatar
Drives: 18 BRZ tS, 27 GRMN 86
Any updates on your car? I have exactly the same issue with this camber plate and from Vancouver, BC as well.
I am planning to replace it with the group-N one as this is super annoying. Every expansion joint on oak street bridge, I can hear the clunk noise (that's like every 100m?)
botbs is offline   Reply With Quote
Old 07-22-2018, 07:10 PM   #25
7c8
I'd be interested to hear your noise as well. Mine seems to come and warm temperature seems to be when it happens.
7c8 is offline   Reply With Quote
Old 08-03-2018, 02:26 AM   #26
BRZ.604
BRZ.604's Avatar
Drives: Project BRZ
Hi sorry, I have been busy with work and my go kart so I put my car on the side. I ordered up some coilover isolator to see if I could dampen down the noise.
The Following User Says Thank You to BRZ.604 For This Useful Post:
botbs (08-03-2018)
Old 08-03-2018, 02:31 AM   #27
BRZ.604
BRZ.604's Avatar
Drives: Project BRZ
I did all kind of combinations with the coilovers. Ohlins + velox top mount = no noise. Ohlins + oem top mount = noise. Velox + oem shocks = the noise also disappear but there's still that light clunking but very hard to tell. At this point Ohlins and velox is not a good combination.
Old 08-13-2018, 09:18 PM   #28
TRAKRAVN
Drives: 2015 Scion FRS - Raven
With all those combinations that you have tried I wonder if it’s a bad end link.
TRAKRAVN is offline   Reply With Quote
Velox vs Raceseng Camber Plates ChrisSC300 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 46 09-21-2021 02:00 PM
OEM dampers with RCE yellows and Velox camber plates Joesurf79 Brakes, Suspension, Chassis 8 03-19-2018 06:50 PM
FS: FT86speedfactory/Velox Camber Plates sebastiansim Brakes, Suspension, Chassis 2 08-09-2017 06:17 PM
FS: Velox Camber plates - Hotchkis Springs - OEM Struts Takumi788 Brakes, Suspension, Chassis 3 04-20-2017 12:58 PM
KW V3- 7k Swift Springs, Velox Camber Plates byun Brakes, Suspension, Chassis 3 10-05-2016 01:20 AM
