Old 06-25-2016, 01:50 PM   #1
ChrisSC300
Drives: 2014 SWP BRZ
Velox vs Raceseng Camber Plates
Been toying with the idea of adding camber plates to my car. The -1.5 from camber bolts just isn't doing it for me anymore. I have the SPC bolt on the bottom, I know I can add the crash bolt to the upper lobe, but this isn't a route I really want to take.
Just wondering if anyone has had any experience with the Velox/ft86SF plates. I know the Raceseng plates are top notch and add caster adjustment. I just don't think I will ever adjust caster. Is the approx $300 price difference worth it if all I'm doing is adjusting camber?
The car is a 1x per month autoX and maybe 2x a year track day.
Thanks In Advance.
ChrisSC300 is offline   Reply With Quote
Old 06-25-2016, 02:37 PM   #2
churchx
churchx's Avatar
Drives: 2014 GT86
They both are fine.
I bought raceseng due reasons like 1) i'm buying it once, why not get something offering most, even if i don't need it right now; 2) i liked customisation options for broad range of coilovers if/when i'll switch. But 1) no caster adjustment on velox's .. that might be also good point, as one less thing to fail/stronger construction; 2) price difference really is significant enough for many, not just few dollars less. Hmm, though then again, if budget matters a lot, why not go with camber bolts & slotting struts?
Go with whichever by whatever reasons matter more to you, they both should do the job and are quality products. Imho no need to go for lengthy discussion of why one may be slightly better and by what slightly worse then another.
Old 06-26-2016, 11:19 AM   #3
thunderlights
Racerxfab makes front lower control arm that has camber and caster adjustment. Might be a better solution for you
Sent from my SM-G850W using Tapatalk
thunderlights is offline   Reply With Quote
Old 06-26-2016, 11:55 AM   #4
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
The Raceseng plates do both for less $$$
drewbot is offline   Reply With Quote
The Following User Says Thank You to drewbot For This Useful Post:
Cole (06-26-2016)
Old 06-26-2016, 12:36 PM   #5
Infinity
Drives: 2016 Scion FR-S
I see 2 on the Racer-X site:
http://racerxfabrication.com/frs-brz...r-control-arms
One is $550, one is $680. I'd say they are both within the range of the Raceseng plates. Not sure if there would be any advantage in going for these instead of camber plates.
The Raceseng plates only actually give 1 degree of positive caster over stock. I know this can be an advantage in auto-x, not sure about the track. Not really sure how much of a difference just 1 degree of positive caster actually makes, though.
Both are supposed to be great quality, but the Raceseng is basically twice the price. I would say the only reason the Raceseng may be worth it to you is because you are doing monthly auto-x events. Assuming you care about competing, not just going for fun, etc.
Infinity is offline   Reply With Quote
The Following User Says Thank You to Infinity For This Useful Post:
bhmax (06-22-2021)
Old 06-26-2016, 03:57 PM   #6
ChrisSC300
Im going to to do plates over Front LCA because I like having the adjustability. I would like front camber to be around -2 for Daily Driving and bump it up to around -3 on autocross days. Plates are quick and easy to adjust.
Its not about being competitive, I'm not on that level. I just want the car to behave the way I want it to when doing runs.
I will probably get the Raceseng plates. I don't need caster adjustment now, but maybe later. Im all about having something I can grow into and doing it right the first time.
I make my purchase next month and check back in to let ya know which one I went with. Along with a review.
Thanks Everyone.
Old 06-26-2016, 07:08 PM   #7
wparsons
wparsons's Avatar
Thanks Everyone.
Keep in mind that changing camber will definitely change toe, so you might want to have a way to accurately measure toe so you don't end up driving around with toe daily.
You'd be better off with -3* of camber and zero front toe than -2* and some toe for daily driving tire wear.
flickr
Old 06-26-2016, 09:00 PM   #8
strat61caster
strat61caster's Avatar
IMO the big advantage to Raceseng is adaptability to different suspension packages.
If you're not planning on changing dampers or spring sizes in the future save the $$$ and try the Velox.
ineedyourdiddly
Old 06-26-2016, 10:07 PM   #9
churchx
churchx's Avatar
Drives: 2014 GT86
Well, Velox's has listed compatibility with B6/8/14/16 Bilsteins, V1/3 KWs, RCE Zero &2, stock, ST, Konis Yellow, so imho versatility wise Velox camplates are fine too.
Old 06-28-2016, 04:19 PM   #10
swift996
swift996's Avatar
I can't speak to Velox but have ran Eibach's that were integrated to my R2s and Raceseng's. Camber is super important on the FRS/BRZ, that alone is likely worth the difference. Raceseng's quality is top notch, all the component parts are of the highest grade. If you want a total solution, Raceseng is the way to go. If you're budget conscious, I'm sure the Velox ones will do enough for the money.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
The Following User Says Thank You to swift996 For This Useful Post:
ChrisSC300 (06-29-2016)
Old 06-28-2016, 05:14 PM   #11
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
OEM top hats are also compatible with those too.
CounterSpace Garage is offline   Reply With Quote
Old 06-28-2016, 05:15 PM   #12
CounterSpace Garage
Thanks In Advance.
Contact @Racecomp Engineering for their camber plate option.
The Following 2 Users Say Thank You to CounterSpace Garage For This Useful Post:
ChrisSC300 (06-28-2016), Racecomp Engineering (06-28-2016)
Old 06-28-2016, 06:24 PM   #13
Infinity
Did you mean caster?
Old 06-28-2016, 06:47 PM   #14
strat61caster
No, not at all. It's camber that's the most important for the front struts, big improvements to grip during cornering will be found as you move past 2.5 degrees.
He may have been talking about caster, but I will take the ideal amount of camber over the ideal amount of caster any day of the week.
ineedyourdiddly
FS (NY): Bilstein B16 (PSS 10) + Raceseng camber plates + Raceseng B16 spring perch dp1 Brakes, Suspension, Chassis 7 05-01-2016 11:28 PM
FS: Raceseng Cascam Camber Plates bombardius Brakes, Suspension, Chassis 0 04-12-2016 07:55 PM
FS: Raceseng Camber Plates (for KW/Tarmac coilovers) Sportsguy83 Brakes, Suspension, Chassis 2 01-21-2015 05:24 PM
HVT vs Raceseng Caster Camber Plates? Phaedrus29 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 40 12-22-2014 06:34 PM
F/S: Raceseng Front Camber Plates ExxelDistributions Brakes, Suspension, Chassis 6 10-25-2014 04:02 PM
