Old 03-23-2016, 07:45 PM   #183
L3P47
L3P47's Avatar
Drives: Firestorm FR-S
Originally Posted by stockysnail View Post
Thanks for the info. Good thing I returned it and decided to do the flexfuel at a later date or maybe never. I'm guessing if I go with the larger Sprintex 335 supercharger, even if I run 92oct, that I'll need to get the fuel pump and injectors even without flexfuel.
With boost you need the fuel pump otherwise your performance is going to suffer. I recommend either AEM or Full Blown. I'm running AEM now.
Sent from my SM-G928V using Tapatalk
Chattanooga Scikotics MFIC
Red Robin Build
L3P47 is offline   Reply With Quote
Old 03-28-2016, 02:19 AM   #184
stockysnail
Just the tip
stockysnail's Avatar
Installed RCE Tarmac 2 coilovers today. I'll give more info and add them to my first post after I actually get a chance to drive on them and also after getting a corner balance alignment. Not sure where I'll go for the alignment yet.
Old 03-29-2016, 12:28 AM   #185
stockysnail
Just the tip
TRD steering wheel installed and added to the bottom of the first post.
Old 04-17-2016, 11:12 PM   #186
stockysnail
Just the tip
PlastiDipped my hood where I louvered it. Added pics to the first post.
Old 04-20-2016, 02:20 AM   #187
stockysnail
Just the tip
Alignment post Tarmac 2 install added to the first post with specs.
Old 08-08-2016, 12:50 AM   #188
stockysnail
Just the tip
Updated bottom of first post with:
I haven't posted in my build thread in a while as I haven't bought any parts in a while. My turn signal relay I had still installed from when I had Tom's Tails finally quit working all together. My signal was stuck on all day at work and my battery was drained. I do not recommend any of the Tom's tail lights based on my issues and many other's issues or with any of the Depo's taillights (Buddy Club, etc...).
Ordered a new relay and red turn signals for the rear. Installed them tonight and they work great.
In other news I dropped out of the top 10 most modded cars on Wheelwell. ;(
Old 09-18-2017, 12:53 AM   #189
stockysnail
Just the tip
Changed my spark plugs today. It was pretty crappy but I got it done in around 4 hours. No engine lifting, just the proper tools to go around corners (elbow ratchet pieces) and the correct sized socket's, extensions, etc. Tight fit but got it done. Started it and it was misfiring so I turned it off, checked all the plugs by pushing then in more and the stupid water pump splitter from the supercharger intercooler that plugs into the fuel injector. It started working fine after all that. I'm not going to like doing this again at 120k miles. Better than spending hundreds on labor alone I suppose.
Old 11-29-2017, 05:00 PM   #190
stockysnail
Just the tip
My car is up for sale. It's time for the next chapter in my life. If interested message me or see the for sale thread.
Old 12-03-2017, 08:43 PM   #191
LimPShoT
Drives: 2017 86 6MT
Interested to see what you get next. Have any idea?
LimPShoT is offline   Reply With Quote
Old 12-04-2017, 11:19 AM   #192
stockysnail
Just the tip
No idea yet.
Old 06-23-2018, 07:15 PM   #193
stockysnail
Just the tip
Purchased today:
4 Centric premium rotors for the front aka 2 sets (I still have 2 sets of spare rears)
Carbotech 1525 front and rear pads
Motul MBF500 fluid
K&N HP-1004
Old 06-24-2018, 02:24 PM   #194
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
Sssooooooooo..... I take it you decided not to sell then?
Lol
Old 06-25-2018, 04:52 PM   #195
stockysnail
Just the tip
Lol
I'm going back and forth. I may sell it to the right person/price. Unfortunately Californians won't be able to get it to pass emissions since it doesn't have the header cat, only the front pipe cat. Passes Oregon and I assume all others aside from Cali.
Old 06-30-2018, 09:39 PM   #196
stockysnail
Just the tip
Maintenance day. Replaced oil, oil filter, Sprintex supercharger oil, in cabin air filter, drive belt, brake pads, brake rotors, and brake fluid.
When will I get an electric sports car so I don't need to do all this maintenance? As soon as an affordable one is available! Probably won't happen until I retire.
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
EOJ (Not much of a Build) Thread jonbatz01 Member's Car Journals 41 07-31-2013 07:34 PM
No Limit's DGM BRZ limited build thread No Limit Motorsport Member's Car Journals 10 05-10-2013 12:09 PM
Jdmitr BRZ Limited journal/build thread jdmitr Member's Car Journals 18 10-01-2012 12:50 AM
SD: Lightning Red BRZ Limited 6MT tastefully modded epson1 Cars for Sale/Trade 2 09-24-2012 12:56 PM
