#15 | |
Drives: Q5 + BRZ + M796
#16 |
Rust bucket enthusiast
Well, to be frank, adding a turbo does not change the clearances in the block or other things they may have fine tuned with our unique high compression fa20 block. Could really just be because Toyota had a say and wanted better emissions, it's likely something far less worth our speculation than we could imagine. As I had said, the FA20 was far different than the EJ motors and maybe they just decided to try a light oil
#17 | |
#18 |
Drives: 2017 BRZ
#19 |
Drives: Late 2014 Subaru BRZ
all turbo subarus run 5w30 all NA subarus run 0w20
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe |
#20 | |
#21 | |
Drives: FR-S Turbo
I've read (but I can't remember where) that oils tailored to perform better at temperature extremes break down faster. ie That a 0W-50 oil fill breaks down to be something more like 10W-30 pretty quickly due to long-chain hydrocarbons shearing. So I wonder if Subaru's thinking is along these lines - that a 5W-30 has greater longevity than a 0W-30? |
| The Following User Says Thank You to Turbo For This Useful Post: | Irace86.2.0 (06-22-2018) |
#22 | |
Drives: FR-S Turbo
This graph is quite interesting. One thing I see is that in addition to the pressures at high RPM/high temp being too low (under the target of 10psi/1K RPM) the pressures at lower RPMs with lower oil temps seem to be excessively high. From what I've read, my guess is that dropping to a 0W-40 oil (that has a comparable 100 deg C viscosity) will drop the low temp data points to a more acceptable level. I'm also a bit shocked that pressures were recorded in the 75-90 psi range. I figured the stock oiling system would have a bypass valve that limited excess pressures, but perhaps it doesn't? In reality, these excess low temp pressures (on their own) would likely only be a concern on a street-driven or dual-use car. And even that could be mitigated by letting the car thoroughly warm up before driving. HOWEVER, changing oil weight to drop these pressures could also work in concert with a new gear/oil pump drive designed to provide greater oil flow, and therefore oil pressure. Hmmmm. |
#23 | |
Drives: Toyota GTS 86
The previous data was on a track with a min oil temp of 90C or so.
I'm having an engine built now and they'll modify the oil pressure relief valve to hold more pressure before it opens. |
#24 | |
Drives: FR-S Turbo
Do you mean modify it to have it hold more pressure or less? I do not think the relief valve opening is limiting your pressure on track. My thinking is that having the relief valve open SOONER would allow you to run -50 or -60 weight oil, boosting high-temp high-RPM oil pressures while limiting pressures at the colder temps. It would essentially help "flatten" the pressure vs RPM curve. In the reading I've done the last few days I did come across articles that talked about excess oil pressure 'washing' out the bearing surface. |
#25 | |
The 10psi per 1000rpm is a rule of thumb for minimum pressure, not a target. High pressure is not a problem. At cold temps those thick oils don't flow and allow engine wear. Even with a lower pressure on the relief valve. You want the thinnest oil you can that holds sufficient pressure. My engine will be finished in two days and back in the car within a week. I guess we'll know for sure then. |
| The Following User Says Thank You to Hags86 For This Useful Post: | Turbo (06-24-2018) |
#26 |
Drives: FR-S Turbo
Looking forward to seeing the results !
| Any recommendations for shops to install turbo kit? | Junbug | Northern California | 6 | 03-31-2018 07:04 PM |
| How many quarts of engine oil for cars with oil coolers | toby714 | Engine, Exhaust, Transmission | 8 | 12-11-2014 07:16 PM |
| future engine configurations...and the cars they go into | cdrazic93 | Other Vehicles & General Automotive Discussions | 1 | 10-07-2014 11:42 PM |
| Engine Swaps and Kit Cars! | merlin2111 | Other Vehicles & General Automotive Discussions | 27 | 01-27-2012 05:18 PM |
| 1.6L DI TURBO ENGINE | quik1987 | BRZ First-Gen (2012+) — General Topics | 39 | 11-30-2011 06:01 PM |
