Old 06-13-2018, 02:29 AM   #3809
Ryan GT86
Ryan GT86's Avatar
Drives: 2019 Toyota 86
Originally Posted by churchx View Post
"Depends".
How you will drive? DD or track or autox?
Will you go for built engine/high boost/lots of power? Then i'd probably look for wider tires. Though going for much wider tires may ask for wider wheels too.
For NA build or mild boost 225/45/R17 might be ok. Of grippier tire model then stock primacies though.
I'd drive it for track days at Sonoma Raceway and Laguna Seca along with the windy back roads that dot the East Bay. I'm planning keeping the engine stock and using the GReddy's T518Z turbo kit for stock engines.
And it would be my daily driver.
Ryan GT86 is offline   Reply With Quote
Old 06-13-2018, 03:42 AM   #3810
churchx
churchx's Avatar
Drives: 2014 GT86
I don't intend to go FI so haven't gathered info/not familiar with this turbo kit aswell, but possibly with FI & tracking i'd go for a bit wider. Of course square wider tires, not staggered wider in rear only.
Old 06-13-2018, 04:25 AM   #3811
Ryan GT86
Ryan GT86's Avatar
How much wider? Like a 235/45R17?
Old 06-13-2018, 05:34 AM   #3812
churchx
churchx's Avatar
Drives: 2014 GT86
That's a bit subjective thing and of tires chosen. Some track slicks or cheater tires like RE71 may grip well even in lower widths, less track specialised tires like PSS/AD08 maybe wider. Also depends on wheel width you have, as there are optimum tire widths per wheel widths. On stock wheels something too wide will have too much sidewall flex.
Also remember, as sidwall profile is in % of width, unlike for 225/45 which is not that far from stock, 235 and up with same 45% sidewall will be of noticeably larger diameter, so worth dropping down a notch, eg. for 235-245-255 i'd go for /40, for 255-265 - for /35
Ryan GT86 (06-13-2018)
Old 06-13-2018, 06:03 AM   #3813
Ryan GT86
Ryan GT86's Avatar
So would a 245/40R17 tire (Bridgestone Potenza S-04) and a 8 inch or 9 inch wide rim need modification to work with the Toyota 86 clearance and turning? It says the tire can handle rim widths of 8 to 9.5 inches.
Rim offset is 45 mm.
Old 06-13-2018, 06:57 AM   #3814
churchx
churchx's Avatar
Drives: 2014 GT86
I see no reason for such sized tires or wheels to have clearance issues. x8 should be ok for 215-245 tires, x9 for 235-265. Those that go for very meaty looks or for widest wheels they can fit often have wider/bigger setups then that.
Old 06-14-2018, 05:50 PM   #3815
Leonardo
Country Boy 4 Life
Leonardo's Avatar
A 17x9 +45 is not going to work on a stock car. You will need a slightly lower offset, a spacer, or coilovers. You will either be 1mm from the spring perch or touching it.
+35 17x9 will work with springs. And will give enough room to add camber bolts.
A 17x8 +45 will not rub at all, even with a 245/40/17.
I have had these sizes with the same size tires at stock height and lowered 1". (with and without camber bolts too)
I LIKE TIRES!
The Following 2 Users Say Thank You to Leonardo For This Useful Post:
chaoskaze (06-23-2018), Ryan GT86 (06-14-2018)
Old 06-14-2018, 06:38 PM   #3816
Ryan GT86
Ryan GT86's Avatar
Huh, looks like the 17x8 will still hold then when I switch to wider tires for a turbo.
The Following User Says Thank You to Ryan GT86 For This Useful Post:
Leonardo (06-14-2018)
Old 06-17-2018, 08:41 PM   #3817
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Have staggered PTR56-18130 PTR56-18131 TRD wheels. 7.5 inc rear and 7 inch front width. Got em as a killer deal brand spanking new at dealership for $749.99.
Can I run square 215 40R18 even-though rear is .5 inch more? Any foreseeable problems?
The Following User Says Thank You to Packofcrows For This Useful Post:
Leonardo (06-19-2018)
Old 06-19-2018, 02:26 PM   #3818
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Yes. Square 215/40 will fit no problems on 18x7 & 18x7.5. Though TRD suggests 215/40 front and 225/40 rear. But, I don't see any real advantage to the mini stagger; other than looks. The stretch will look even with the mini stagger.
Cool wheels! Great deal! Please post pics when you get them installed!!!
I LIKE TIRES!
Old 06-19-2018, 07:54 PM   #3819
Packofcrows
Thanks, next 2 weeks ill swap em out from stock wheels to those 215 40 18's then.
chaoskaze (06-22-2018)
Old 06-21-2018, 07:39 AM   #3820
HachiRokuX
Drives: 2017 Toyota 86
Hey guys, I actually went ahead and ordered 4x 18x8.5 +38 Work Emotion Kiwami Wheels. Would 225/40/18 tires stretch on a wheel this wide and are there any safety risks with stretching a tire?
I was also thinking about going 235/40/18 all around but wasn’t sure if it would rub on TRD springs at full lock (like doing a U-turn).
HachiRokuX is offline   Reply With Quote
Old 06-21-2018, 12:15 PM   #3821
carlovestela
Drives: 2015 Firestorm FRS
I have 17x9+38 with 245/40/17 using trd springs
No rubbing
carlovestela is offline   Reply With Quote
The Following User Says Thank You to carlovestela For This Useful Post:
HachiRokuX (06-23-2018)
Old 06-21-2018, 12:47 PM   #3822
DarkSideFRS
Drives: 2013 pearl white FR-S
No rubbing
how much camber u running?
DarkSideFRS is offline   Reply With Quote
The Following User Says Thank You to DarkSideFRS For This Useful Post:
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
