Old 06-17-2018, 08:38 PM   #15
incutebus
Drives: Boosted
It's a really good question and it's nearly impossible for me to explain in words. Luckily, it's easy to demonstrate using one's own hands while considering the high school physics thing about friction, work, and heat.
The object is to minimize the total amount of heat energy transferred through the clutch with each operation so that, as it's operated over time, the amount of heat dumped into it doesn't exceed its ability to shed it through the pressure plate and flywheel. This rate of heat over time is called power. Horsepower, KiloWatts, Joules per second, whatever.
If hands are rubbed together lightly enough, they never get too hot no matter how long they are rubbed.
Next, rub them together with medium force 20 times, stop, and hold.
How long does it take for your hands to cool down.
Rub them together again but this time really hard. See where I'm going?
You can launch but give your clutch a chance to cool. That's why I cringe whenever I hear the sound of throttle being applied before clutch is fully engaged. Sloppy upshift is a horrible waste.
Woo, class is in session. Yes, I remember my physics classes lol.
Long story short, fully let go of clutch before use of gas and don't use the gas to slip the clutch even if it makes it more smooth. This is one of those times where I'd wish my clutch wasn't so soft lol.
So as long as I don't glaze the clutch i.e hold it at the friction point for 2-3 seconds I should be fine?
incutebus is offline   Reply With Quote
Old 06-17-2018, 08:52 PM   #16
Brakes are to hold the car still, not the clutch. Brakes are cheap and easy to replace. Blah blah...
But it is a consumable. Just use it for it's intended purpose and enjoy exploring the limits. You'll feel it get hot way before you smell it. If it gets mushy on engagement, it's
too
fucking
hot.
Old 06-17-2018, 08:56 PM   #17
incutebus
Drives: Boosted
too
fucking
hot.
Any extra tips on high performance clutches or are they kinda more or less the same?
Old 06-17-2018, 09:02 PM   #18
I suggest this thread where I explore that same frustration. It leads into my DIY which is a beginner mod that transforms the operation of the clutch. Unlike the spring removal one, this actually changes the throw ratio.
Old 06-17-2018, 09:06 PM   #19
I hear that some can be tricky to modulate and prone to chatter. Chatter is awful for this transmission in particular.
Old 06-17-2018, 10:01 PM   #20
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Just to clarify...
Use the bolded technique only when shifting. The clutch is designed to slip on startup from a stop. It's fine (and recommended) to modulate to clutch when you start the car moving as long as you apply a low amount of power until the clutch hooks up.
Might be obvious, but had to make that clarification just in case.
Old 06-17-2018, 11:30 PM   #21
incutebus
Drives: Boosted
Just to clarify...
Wow, I've been driving manuals wrong then. I can't really feel the engagement of my clutch unless I'm barefooted. What I normally do is clutch in, shift up, move clutch to engagement point and add a slide bit of gas while getting go of the clutch. Is this wrong even with using a 1.5l engine and a Honda clutch with a cdv? No matter how smooth I let go of the clutch, it will jerk unless I add some gas.
Old 06-17-2018, 11:40 PM   #22
@incutebus
push clutch in
start car
put in gear
let clutch out and press on gas ….. (both at once)
drive car
press in clutch let off gas (both at once)
take car out of gear
just do all of the above, in that order, without thinking about it …..
Now, if you come back before you practice that ……. I'm ah gonna hafta ya.
Old 06-17-2018, 11:44 PM   #23
incutebus
Drives: Boosted
@incutebus
push clutch in
start car
put in gear
drive car
I think I'm gonna remove my CDV lol. Second manual I owned. My first M/T was a 92 passat and it wasn't as notchy shifting as this civic :p. It may just be me not used to having a delay in a shift.
Old 06-18-2018, 12:48 AM   #24
Well, if you can't get used to it, you can always take it out.
It doesn't look that hard.
It would be easy for me …. just drive up to the local auto shop, tell the guys to take out the CDV and be sure to bleed the system. Have a cup of coffee and a smoke, tell a couple of back-in-the-day stories, pay them, drive home and take a nap.
Old 06-18-2018, 07:58 PM   #25
incutebus
Drives: Boosted
Guess deleting my cdv did it 👌👌👌
Brake and Clutch fluid questions ducky106 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 8 03-04-2019 08:58 AM
I keep breaking lug studs!!! Guff Issues | Warranty | Recalls / TSB 59 12-30-2015 12:34 AM
Clutch install questions wootwoot Engine, Exhaust, Transmission 25 12-29-2014 04:18 PM
Breaking-Bad SWP Build mwjcyber Member's Car Journals 7 02-17-2014 08:12 PM
exedy clutch questions ft86me Engine, Exhaust, Transmission 8 02-13-2014 09:58 PM
