Old 02-12-2014, 12:43 AM   #1
ft86me
ft86me's Avatar
Drives: 2013 FRS
exedy clutch questions
can i have some input between stage 1 and stage 2 exedy clutches for a 350hp goal? do the kits come with a lightened flywheel? I'm having a difficulty deciding between the two.
some things to keep are that my car is a daily and i do encounter stop and go traffic on a daily basis and would like something close to the stock feel. I am sure there are some sacrifices with upgrading a clutch, but input on where I would be sacrificing and what i could or should possibly go with would be great.
thanks everyone!
ft86me is offline   Reply With Quote
Old 02-12-2014, 01:03 AM   #2
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
I have an exedy stage 1 clutch. Its amazing as far as feel. I would say you wouldnt really be able to tell the difference between the stage1 and the stock clutch. Personally, i think the exedy actually feels just a bit better, but barely. And only because i know its there can i say its different. Hard to explain, but it feels better, yet stock at the same time. Very easy to daily drive.
I would say your wtq goal is probably even more important than your whp goal. What is it? I am around 350whp, but around 320wtq....and that is more than the stage1 really can handle. It is working fine, but there have been a few spots where i catch it slipping under hard driving/shifts...so in the end, i will need a new clutch soon, as i bump my power up.
if you are like most and running a bigger turbo, with less wtq, then the stage one will probably work for you, as 350whp on those setups usually runs like 250-280 wtq, which i am sure this stage1 would handle fine. I see you are running a sc, and those really seem to be running lower tq numbers, so yeah, probably would work.
Cant tell you much about the stage 2, as i have only tried the stock and exedy stage1 on this car.
Hope that helped a bit.
gdrider77 is offline   Reply With Quote
Old 02-12-2014, 01:09 AM   #3
ft86me
ft86me's Avatar
Drives: 2013 FRS
I would say your wtq goal is probably even more important than your whp goal. What is it? I am around 360whp, but around 320wtq....and that is more than the stage1 really can handle. It is working fine, but there have been a few spots where i catch it slipping under hard driving/shifts...so in the end, i will need a new clutch soon, as i bump my power up.
if you are like most and running a bigger turbo, with less wtq, then the stage one will probbbly work for you, as 350whp on those setups usually runs like 250-280 wtq, which i am sure this stage1 would handle fine.
appreciate the great input. to be honest i'm not going to go more than 350 but the wtq deal is a great question. i guess there is a blank there in the equation that i need for the answer. i may be running a t4 and trying to attain 350hp so i'm not sure where that would put the wtq at. seems for what i'm trying to do or interested in for the matter is around 180-270wtq
thank you for the input though!!
Old 02-13-2014, 09:36 PM   #4
KONVERTER
KONVERTER's Avatar
If you want a close to stock feel, go with something that is a copper organic clutch disc. Don't go Ceramic or Metallic or you will be miserable.
KONVERTER is offline   Reply With Quote
Old 02-13-2014, 09:37 PM   #5
ft86me
ft86me's Avatar
Drives: 2013 FRS
Can anyone tell me how their experience is with an act 6 puck clutch that's sprung?
Old 02-13-2014, 09:42 PM   #6
KONVERTER
KONVERTER's Avatar
basically the clutch is going to instantly grab. The sprung disc is just going to reduce the jarring shake from the clutch / flywheel engagement. The disk will squeak if the disc is sliding against the flywheel, if you hear this you are killing your clutch disc life.
certainly not in the "stock feel" category.
Old 02-13-2014, 09:43 PM   #7
ft86me
ft86me's Avatar
Drives: 2013 FRS
Well hmm which route to go
Old 02-13-2014, 09:46 PM   #8
KONVERTER
KONVERTER's Avatar
Copper Organic disc with higher clamping force then stock with a light weight flywheel.
OR light weight crank pully for a similar effect.
Old 02-13-2014, 09:58 PM   #9
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
What sucks with organic disks is if they got hot, you are screwed
Exedy Clutch KAR Engine, Exhaust, Transmission 28 01-03-2016 07:27 PM
Exedy super twin clutch boostedfrs Transmission and Driveline 0 01-31-2014 12:48 PM
Exedy stage 1 clutch/flyweel - Flywheel weight? wparsons Engine, Exhaust, Transmission 5 01-03-2014 11:58 AM
**Unbeatable Prices** ACT/Exedy/Spec/CC/Kartboy/Clutch Masters Performance Driven Parts Transmission and Driveline 24 12-09-2013 08:36 PM
NEW PRODUCT EXEDY HYPER TWIN CLUTCH! D2BD Motorwerks Transmission and Driveline 4 05-15-2013 03:09 PM
