#71 | ||
Drives: 2014 BRZ Limited
Neither of which would be physically possible to heel-toe. Even if your foot were big enough, the brake pedal was so much higher than the gas pedal that your ankle would have to be double jointed, and your foot would have to have a right angle bend in the arch. You would startle children and little old ladies if you walked down the street with that. |
| The Following User Says Thank You to extrashaky For This Useful Post: | humfrz (07-08-2017) |
#72 | |
Many of my cars could not be heel and toed even if I had wanted to. My 58 Ford had no cover on the clutch pedal so it was about an inch wide piece of steel about 8 inches from the gas.
#73 | |
![]() ![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Tcoat (07-08-2017) |
#74 |
Drives: Neptune GR86
You don't know how to drive manual if you can't heel toe clutch and gas.
#75 |
Lol brake pedal. i apparently had clutch in my mind. Suppose you could clutch with the heel of one foot and toe of the other and the term would still be technically accurate.
| The Following User Says Thank You to Tcoat For This Useful Post: | humfrz (07-08-2017) |
#76 |
FR-S Hill Assist
If you do not have a car with hill assist on it and you really need one. Do it the old way. While stopped on a hill when ready to take off, pull up the hand brake give the car some gas and just before the clutch releases all the way, then release the hand break. That is what I use to do when I had my 2013 FR-S.
#77 | |
![]() Yep, the old handbrake technique still works - fer sure ..... ![]() humfrz |
#78 |
Drives: Legacy
I’m trying to turn my hill start off. I turned it on to try it out but it’s not for me. It can cause me to stall because I’m used to driving normal, backing up slight hill very little throttle and it’ll stall because of the hill start.
But I did the exact same thing as turning it on, hold the button for a minute or so until both lights go out then push button again and it won’t turn off. Is there a trick about when and how long to hold the button the second time in order to disable? Sorry if this is the wrong forum I have a 2018 BRZ but I’m assuming they are all the same. |
#79 | |
| The Following User Says Thank You to Tcoat For This Useful Post: | extrashaky (05-23-2018) |
#80 |
Drives: 17 Asphalt 86
I turned mine and on and then off again following the same procedure as per the bullet point posts above.
I only found it useful on hills that are steep enough to require the hand brake otherwise. |
#81 |
Drives: 2019 Toyota 86
So for learning manual would be better to leave hill assist off?
#82 | ||
I'd recommend trying both ways so at least you know how to use the e-brake without assist. Personally I use the hill start assist and haven't had any problems. Yesterday I was on a steep ass hill behind a car that decided to partially crest it to the stop sign, and then not go at all despite it being his turn, so I was stopped on what was probably a 60+ degree hill. Worked fine.
Instagram: @spike.grc
| The Following User Says Thank You to spike021 For This Useful Post: | humfrz (06-08-2018) |
#83 | |
| The Following User Says Thank You to humfrz For This Useful Post: | spike021 (06-08-2018) |
#84 | ||
I think this is the one I mentioned: https://www.google.com/maps/@37.7579...7i13312!8i6656
| Anyone planning HAC (Hill Assist) retrofit? | Zardoman | Engine, Exhaust, Transmission | 28 | 06-06-2017 11:52 PM |
| Question regarding Hill-start assist control | rkaywhodat | Scion FR-S / Toyota 86 GT86 General Forum | 17 | 09-30-2016 05:47 AM |
| Tuner Battlegrounds 2015 - Need an assist! | protpibe | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 07-08-2015 05:51 PM |
| Cusco Jack Assist Ramp Set | Evasive Motorsports | Mechanical Maintenance and Tools | 0 | 04-17-2015 01:40 PM |
| Car randomly doesn't start on slight hill | Craig | Issues | Warranty | Recalls / TSB | 7 | 02-01-2013 01:48 PM |
