Old 01-21-2018, 11:13 PM   #43
BAD ROD
Drives: 2014 BRZ
I think its 8 years or 80,000 miles, which ever comes first.
BAD ROD is offline   Reply With Quote
Old 01-22-2018, 02:14 AM   #44
Zer0
Drives: 2015 frs
This is what I found
Zer0 is offline   Reply With Quote
Old 01-22-2018, 01:17 PM   #45
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
How many miles are on your car?
I think if I wanted to do a v8 swap then Synergy or Voodoo. I like the LS/LT motors too, but I would rather stay NA and have the revs. I would buy a dedicated track car though. This will be awesome if you get a CARB sticker. I’m waiting for Harrop to get their SC CARB approved. Having driven modified “illegal” cars in the past, I love the idea of legal mods like this. I hope this all works out.
Old 01-22-2018, 06:06 PM   #46
Zer0
Drives: 2015 frs
2800 miles. Yeah I had a jdm s14 I sold it to go the legal route. Hope it pans out.
Old 05-31-2018, 06:37 PM   #47
BAD ROD
Drives: 2014 BRZ
Any update?
Old 05-31-2018, 09:07 PM   #48
Zer0
Drives: 2015 frs
Ordering all the major parts at the end of June. It took a little longer than I wanted to stack up the funds.
The Following User Says Thank You to Zer0 For This Useful Post:
BAD ROD (06-03-2018)
Old 06-01-2018, 01:49 AM   #49
Zer0
Drives: 2015 frs
Anyone know where to get a stand alone harness for a 2015 LT4 with all the emission control electronics supported? I sent out a email to Speartech to see if I can have one made. Hopefully I hear back from them soon.
Old 06-01-2018, 06:32 PM   #50
MRS-Colin
Drives: 2001 Impreza 2.5 RS
SpearTech should be able to do this.
The biggest issue you will run into will be evaporative emissions as the tank size and float isn't the same usage, so there will always be one monitor that will never clear.
Colin Beck
MRS-Colin is offline   Reply With Quote
Old 06-03-2018, 05:46 AM   #51
Zer0
Drives: 2015 frs
They confirmed they can build the harness for me. @MRS-Colin Do you know how to get that issue resolved for the evaporitive emission monitor? Hopefully without swaping in a Chevy fuel tank.
Old 06-03-2018, 09:49 PM   #52
BAD ROD
Drives: 2014 BRZ
Thanks for the update Zer0. Great project.
Old 06-04-2018, 04:07 AM   #53
Zer0
Drives: 2015 frs
Thanks. Hopefully everything goes well. Lol it never does, but hopefully I achieve my goal. I will start a swap thread after I get the parts ordered so people can see the process I go through.
Old 06-06-2018, 01:56 PM   #54
MRS-Colin
Essentially PCM calculates estimated fuel usage and also looks at the resistance level of the float in the tank.
The estimated fuel usage needs to line up with the amount the fuel level resistance negative change over time based on the size of the fuel tank.
I don't think this value is allowed to be calibrated anywhere so you might need to rig up some sort of resistor matrix to get the value properly from the BRZ sender.
Colin Beck
The Following User Says Thank You to MRS-Colin For This Useful Post:
Zer0 (06-06-2018)
Old 06-30-2018, 12:33 AM   #55
Zer0
Drives: 2015 frs
Ordered the Oem catalytic converters, exhaust manifolds, and air filter housing with intake tube. Should be ordering the engine and supporting parts in the beginning of July. Once I get that I will be starting the work.
BAD ROD (06-30-2018)
Old 06-30-2018, 04:52 PM   #56
BAD ROD
Drives: 2014 BRZ
Zer0, I’ve started my swap fund, to follow in your footsteps.
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 11:54 PM
California 86 Shirts FR-Shred Miscellaneous 21 05-23-2016 04:43 AM
Question from California Cjymiller EUROPE 3 08-18-2015 03:33 PM
California 91 mike the snake Engine, Exhaust, Transmission 16 03-12-2014 07:46 AM
California.. VenomRush Southern California 92 11-16-2013 10:25 PM
