Old 11-07-2016, 03:58 PM   #1
BAD ROD
Drives: 2014 BRZ
V8 Swap in California
Anyone done an engine swap in California? Advice? As I understand it here, in California, as long as we use an engine of the same year of the car, or newer, and maintain the new engines emission system, we can legally (as in smog legal) swap in a new engine, even a V8.
Any experience with smog legal swaps in California?
Michael
BAD ROD is offline   Reply With Quote
Old 11-07-2016, 04:10 PM   #2
Drambeenie
Drambeenie's Avatar
Drives: Black 17 BRZ LT MT PP
One of the forum members said his ABS stopped working when he did a swap.
Drambeenie is offline   Reply With Quote
Old 11-07-2016, 04:40 PM   #3
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
I believe you could use one of the E-Rod Crate engine. Comes with all of the Emissions needed.
LS3 E-Rod @ SummitRacing
@Drambeenie
ABS will be disables unless you address the CAN situation. MRS Electronics currently has the fix for this in the works.
DustinS is offline   Reply With Quote
Old 11-07-2016, 05:00 PM   #4
ILLSMOQ
Drives: 2017 WR BLUE BRZ
@Drambeenie
I looked into this too but as I understood it, the Erod engines are only carb legal in a pre-obd2 vehicle which means pre 1996/1997.
Also to use the Erod, you need to install the cats (not sure about the intake or other components) that comes with the engine package and I'm not sure you could make those things fit with out some serious work.
ILLSMOQ is offline   Reply With Quote
Old 11-07-2016, 05:02 PM   #5
BAD ROD
Drives: 2014 BRZ
Oh yeah, the E-Rod Crate engine. That could be a great option. Thanks.
EDIT: ILLSMOQ, your right, looks like E-Rod is allowed for "pre-1996 vehicles" only.
Old 11-07-2016, 07:17 PM   #6
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
With such a new platform, you have to ask yourself the obvious question(s):
What do I want out of a V-8 that a boosted FA20 can't give me?
Do I want to pay for all the secondary wiring, fabrication, and certification to make the swap work?
What is my wallet made of and can I replicate it in a Starfleet replicator?
https://www.bar.ca.gov/Industry/Engi...uidelines.html
Don't forget, you also have to have this signed off at a BAR station. The inspection is trivial but you'll spend enough money to buy another used FRS/BRZ before you're done.
-alex
Old 11-07-2016, 07:41 PM   #7
BAD ROD
Drives: 2014 BRZ
Alex,
Great points for sure. I drove a small block as a daily driver for 15 years prior to selling and getting my BRZ. After a year and a half with the BRZ, while I still love the car, I totally miss driving a V8 everyday. To be sure, what I really miss is the power and sound.
You know what I need to do is get a ride in a boosted BRZ/FRS and see what happens. If I could get fulfilled with boost, that I can install over the weekend, I would be up for that.
Any Sacramento/Roseville area E-Force owners listening?
Old 11-07-2016, 07:46 PM   #8
ILLSMOQ
All the hoops you'd have to jump through to make this a California carb legal swap makes it a looser of a deal...just not worth it.
Old 11-07-2016, 07:49 PM   #9
BAD ROD
Drives: 2014 BRZ
Yeah, seems like the cost/effort is a bit high.
Old 11-07-2016, 10:09 PM   #10
Zer0
Drives: 2015 frs
Michael
Im going to Do a LS3 swap I live in northern California. Find a ref to work with throughout the whole process and don't switch. They will tell you what they need to pass it. It doesn't need to be carb legal it just has to meet that refs interpenetration of what needs to be on the car to make it leagal.
I was shooting for March but a car crash and changing employers has set it back a bit, probably will be the last part of the new year a 6 month set back. I will go talk to a Ref later this month and document what he tells me I need to make it pass. I will post it to help end the speculation.
If you need any help PM me
Zer0 is offline   Reply With Quote
Old 11-08-2016, 12:41 AM   #11
mav1178
mav1178's Avatar
So if a ref interprets it as "whatever legal V8 from a model year car older than your chassis", that's okay?
Just because someone interprets it one way doesn't make it legal. The last thing you want is for someone to interpret his/her way, and your swap goes down the tube later down the road.
I've been involved in this process many times... the first part is the engine needs to be same model year or newer than the vehicle it is going into. And yes, the whole "interpretation of what needs to be on the car" is basically meeting the legal requirements of the California ARB, i.e. "CARB legal"..
-alex
Old 11-08-2016, 09:50 AM   #12
ILLSMOQ
I hope you can pull it off and it works out like you say. That would be awesome.
Old 11-08-2016, 10:51 AM   #13
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
loser...
I'm sorry but I have to be a grammar nazi here. IT is a LOSER of a deal, it would only be a looser of a deal, if you could have a tighter deal...
Jaden
Jaden is offline   Reply With Quote
Old 11-08-2016, 10:57 AM   #14
irax
irax's Avatar
Drives: 2015 Subaru BRZ WRB
Here are the things that the ref will look for to meet Carb approval.
Fuel system
Headers
Catalytic converters
Intake
Actual emissions test.
Fuel System:
Does it have a working and proper EVAP/Purge/Canister/Recirc.VS.Returnless fuel that meets the emissions standards of the body of the car or the engine.
Headers:
Are they OEM or C.A.R.B. approved
Catalytic converters:
Are they OEM or C.A.R.B. approved for that engine family
Intake
Does the intake have all the proper vacuum/evap that meets OEM standards.
Does it have the factory throttle body for that vehicle class (Can't put a truck throttle body on a sedan)
Does it have OEM or C.A.R.B. approved intake manifold
Emissions test
Does it actually pass a smog check.
irax is offline   Reply With Quote
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
California 86 Shirts FR-Shred Miscellaneous 21 05-23-2016 03:43 AM
Question from California Cjymiller EUROPE 3 08-18-2015 02:33 PM
California 91 mike the snake Engine, Exhaust, Transmission 16 03-12-2014 06:46 AM
California.. VenomRush Southern California 92 11-16-2013 09:25 PM
