Old 05-31-2018, 09:40 PM   #1
dstrout
dstrout's Avatar
Track hubs?
I have gotten to the point where I need to replace all of the wheel studs. Two have broken so far and I suspect the others are not far behind, so it’s time for a set of good studs all around.
The car has 55K miles on it and is really only used for the track. My thought is that if I am going to pull the hubs off to replace the studs, I may as well replace the hubs too. Are there heavy duty / “track spec” hubs, or should I just go OEM? What do you think of third party hubs, like duralast or moog?
dstrout is offline   Reply With Quote
Old 05-31-2018, 10:02 PM   #2
ZionsWrath
Thanks
ZionsWrath's Avatar
You dont need to pull the front to replace studs
Rear you remove the wheel bearing
ARP extended studs work great
The Following User Says Thank You to ZionsWrath For This Useful Post:
Leonardo (06-01-2018)
Old 06-01-2018, 05:24 PM   #3
dstrout
dstrout's Avatar
Ok, fair enough, you don’t have to, but I guess what I meant was I may as well just pull the hubs and replace them after what will be by then 60k very hard miles. My question is, is there anything better than OEM hubs out there?
Old 06-01-2018, 11:26 PM   #4
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
No.
Just browse CL for wreaked cars being parted out and pick up a spare if you are worried. I had my right front go at a little before 60k, I keep a spare.
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post:
dstrout (06-02-2018), Leonardo (06-03-2018), wparsons (06-04-2018)
114.3 hubs Nigelr32 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 20 03-16-2017 03:49 PM
How do you get rusted hubs/bearings off? ZionsWrath Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 50 07-01-2016 10:51 AM
Wisefab track kit plus 114.3 hubs Nigelr32 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 05-09-2016 10:59 PM
Subaru Hubs Nigelr32 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 03-27-2016 12:11 PM
USB Hubs / Splitters wahsaihin Electronics | Audio | NAV | Infotainment 2 06-14-2014 02:02 PM
