Old 05-23-2018, 09:46 AM   #1
pcguru2000
pcguru2000's Avatar
Drives: toyota 86 2017
Lug nuts have a sloppy fit in 19mm socket.
There is a lot of slop in all the 19mm sockets I tried on the lug nuts. I'm concerned if the lug nuts are ever over tightened that the lug nut may get rounded when trying to loosen them. Have you guys experienced this. Should I be concerned? Any tricks I can do to tighten the socket to lug nut fit?
pcguru2000 is offline   Reply With Quote
Old 05-23-2018, 09:48 AM   #2
jasonojordan
Drives: 2013 satin white brz limited
Stock lugs or aftermarket? Is it possible they are aftermarket and need a key not just a 19mm.
jasonojordan is offline   Reply With Quote
Old 05-23-2018, 10:01 AM   #3
pcguru2000
pcguru2000's Avatar
Stock
Old 05-23-2018, 10:18 AM   #4
jasonojordan
Have you tried a different 19mm socket to see if it is your socket? 12pt or 6pt
The Following User Says Thank You to jasonojordan For This Useful Post:
pcguru2000 (05-24-2018)
Old 05-23-2018, 10:40 AM   #5
This^ There shouldn't be any slop.
Old 05-23-2018, 10:42 AM   #6
ZionsWrath
Thanks
ZionsWrath's Avatar
6 point 19mm or 3/4"
Try the trunk wrench to see how it fits vs your socket
The Following User Says Thank You to ZionsWrath For This Useful Post:
Old 05-23-2018, 07:19 PM   #7
MuseChaser
Feeling like thinking....
MuseChaser's Avatar
Are you using impact sockets or regular? My impacts fit just a tad looser.. if you look at them closely, you'll see that each of the six faces has a slight curve to it.
Drive like everyone's life around you depends on it...
MuseChaser is offline   Reply With Quote
Old 05-24-2018, 11:46 AM   #8
Gunman
Drives: 2019 Mazda Miata RF
Most specs say the wrench should be .20mm larger than the nut/bolt. A nut/bolt on the low end of the tolerance, and a wrench on the high end, would have more slop.
brand of wrench will cause the tolerance(ie quality) to vary too.
Old 05-24-2018, 06:55 PM   #9
pcguru2000
pcguru2000's Avatar
Genius! I'll try and see.
Both in regular socket. 6pt in impact.
both. I didn't know about the curve. Purpose of this?
Interesting specs...didn't know this either. Thought a standard was a standard.
Old 05-24-2018, 07:06 PM   #10
Gunman
ASME, DIN, SAE, JIS, etc., they can all vary a bit.
The Following User Says Thank You to Gunman For This Useful Post:
JazzleSAURUS (05-31-2018)
Old 05-25-2018, 06:17 PM   #11
pcguru2000
pcguru2000's Avatar
Tried the trunk wrench...same amount of slop. I think I'm good! Great suggestions!
The Following User Says Thank You to pcguru2000 For This Useful Post:
ZionsWrath (05-26-2018)
Old 05-30-2018, 10:02 PM   #12
Joon525
Joon525's Avatar
Drives: 2016 BRZ
It's to move the point of contact more on the flat edge of the nut and away from the corners to prevent rounding.
Joon525 is offline   Reply With Quote
The Following User Says Thank You to Joon525 For This Useful Post:
pcguru2000 (05-31-2018)
Old 05-30-2018, 10:08 PM   #13
dutchman1
Drives: 2017 86 6-Speed
If you're really concerned about it, buy a decent brand name socket. As already mentioned, they grab the flats of the nut rather than the corners. They will also be made out of harder material (less flex) and to a tighter tolerance. Some good tool brands are SK, Snap-on, Armstrong, Wright. There are more, those are just a few examples.
2017 86 set up for CS STX autocross
dutchman1 is offline   Reply With Quote
The Following User Says Thank You to dutchman1 For This Useful Post:
rvoll (05-31-2018)
Old 05-31-2018, 01:01 PM   #14
pcguru2000
pcguru2000's Avatar
I didn't have to use the impact wrench. I just extended the 19MM drive socket wrench to get leverage and they came right off my wife's forester which has the same lug nut size as the 86.
FS: 20 Black Wheel ACORN LUG NUTS and 5 Lock Nuts 12x1.25 and 19 MM Socket w/Sleeve neilvosko Wheels and Tires 14 06-18-2018 09:47 PM
Shifter is obnoxiously sloppy Takumidesh Engine, Exhaust, Transmission 14 04-25-2017 02:58 PM
Sloppy throttle pedal allowe Engine, Exhaust, Transmission 23 11-02-2016 02:11 PM
17mm Socket on 19mm Lug Nut ZionsWrath Off-Topic Lounge [WARNING: NO POLITICS] 5 06-02-2016 06:54 PM
Can't torque my lug nuts socket too shallow :( chenshuo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 27 07-25-2013 10:25 AM
