Old 05-30-2018, 02:56 PM   #1
Phothiraj
Drives: Lightning Red BRZ
Do I need rear toe arms?
Currently i am running BC extreme lows and i'm also thinking about getting parts by max rear control arms. I am dropped 4 inches all around and wondering would I need to purchase adjustable toe arms as well prior to installing the control arms?
Phothiraj is offline   Reply With Quote
Old 05-30-2018, 03:58 PM   #2
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
I want to see a pic of your car with it 0.9" ground clearance.
shiumai is offline   Reply With Quote
The Following 2 Users Say Thank You to shiumai For This Useful Post:
kch (07-18-2018), Turbo (07-17-2018)
Old 05-30-2018, 03:59 PM   #3
How are you currently dropped 4" with stock control arms?
Turbo (07-17-2018)
Old 05-30-2018, 03:59 PM   #4
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Camber for daaaayyyyssssss! Lol.
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
Old 05-30-2018, 04:07 PM   #5
Phothiraj
According to the specs, i've maxed out my coils and it gives a 4inch drop all around. i can be wrong but i'm going according to specs.
Old 05-30-2018, 04:08 PM   #6
Phothiraj
I've replaced my rear axles once already and a year later i'm looking to replace them again, is why i'm looking to get control arms and toe arms. But i'm not 100% sure if i'll need toe arms.
Old 05-30-2018, 04:09 PM   #7
With a 4" drop, I don't think it matters …… you can't drive it on roads anyway ……
I'm sorry ……. it's ma med/nap time ……
Old 05-30-2018, 04:12 PM   #8
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
No, you need Jesus.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 05-30-2018, 04:13 PM   #9
Phothiraj
i mean i've been dailying for the past 4 years this low. Now that I've finally paid my car off, I have a few extra bucks to start buying car parts
Old 05-30-2018, 05:07 PM   #10
churchx
churchx's Avatar
Drives: 2014 GT86
humfrz: oh, one CAN drive on roads with 4" drop. On trailer.
Phothiraj: 4" drop from 4.9" stock ground clearance? Yeah, you gonna need car parts to replace damaged ones
At least you will save $ on struts/springs/coilovers (as i guess you have welded suspension, haven't you?)
humfrz (05-31-2018)
Old 05-30-2018, 05:25 PM   #11
Phothiraj
I'm actually on stock suspension. No mods to it besides Coilovers. But this must mean i'm not dropped 4". I was just saying 4" because that's what the specs read for when maxed. Car drives fine, by no means am I tracking it, but I have been doing a drift event once a year when I have the time. Other than that it's been reliable for the past 85k miles.
Old 05-30-2018, 05:52 PM   #12
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
The Following User Says Thank You to x808drifter For This Useful Post:
smg1138 (05-30-2018)
Old 05-30-2018, 05:59 PM   #13
You need to measure how much of a drop you really have before anybody can help with telling you what you need for parts. I am only at a bit over an inch and a half drop and have totally maxed out the stock suspension. Find a smooth, level surface and measure the distance from the ground to the underside of the rocker panel.
Old 05-30-2018, 06:28 PM   #14
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
If you've been dropped and properly aligned with stock control arms the only reason you'd need aftermarket toe arms is if you wanted to adjust outside of their current available adjustment.
Crawl under and take a picture of the cam bolts on each side of the car, post them up, someone here should be able to tell you if you have any adjustment left on the factory control arms.
Also specify what you want out of your alignment, -2 degrees of camber, probably no problem, -20 degrees of camber you'll need aftermarket.
Edit: you're looking for this bolt that has a bunch of tick marks on it, try to look at it as straight on as possible.
ineedyourdiddly
cjd (05-30-2018)
FS: SPL rear lca, trailing arms, toe arms - SOLD Agent_D Brakes, Suspension, Chassis 0 04-29-2018 11:31 PM
Megan racing rear lower control arms , toe arms, rear traction arm fcdrifter20 Brakes, Suspension, Chassis 11 01-03-2016 08:11 PM
SPL Arms - Brand New! - Rear Lower Control Arm + Rear Toe Arm w/ Eccentric Lockout quiet-k Brakes, Suspension, Chassis 8 03-22-2014 10:17 PM
GTSPEC rear control arms & toe arms review Jesse Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 08-23-2013 03:20 PM
