Old 05-29-2018, 03:38 AM   #1
Trap63
Trap63's Avatar
Drives: Brz WRB - Europe LHD
Exclamation SB17-067 Leakage countermeasure for VALVE ASSY OIL CTRL 2013-2017
SB17-067 Countermeasure for VALVE ASSY OIL CTRL 2013-2017
Solving Internal oil leakage with new 10921AA241
Check part as described.
I changed the lower drive side one thus had a oil leakage generating some VVT code.
Trap63 is offline   Reply With Quote
Old 05-29-2018, 04:49 AM   #2
Ricepuddin
Get a Bowl
Ricepuddin's Avatar
Drives: 2017 BRZ PP
Is this a preventative thing, or a will repair thing ?
Sent from my Pixel XL using Tapatalk
Ricepuddin is offline   Reply With Quote
Old 05-29-2018, 04:54 AM   #3
Trap63
Trap63's Avatar
it's a countermeasure, "IF"
Old 05-29-2018, 05:30 AM   #4
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
Is this the cause of all the ignition coil codes?
Old 05-29-2018, 05:48 AM   #5
Trap63
Trap63's Avatar
sometimes may occour VVT DTC code if conductivity is poor. I got VVT DTC code and solved this way, you need ring and back ring too when change.
Old 05-29-2018, 06:22 AM   #6
Trap63
Trap63's Avatar
NO, it doesn't affect ignition, only VVT system
Old 05-31-2018, 07:07 AM   #7
BRZnut
Drives: BRZ DGM Limited
what exact code did you get?
Old 06-01-2018, 01:39 AM   #8
Si_Chris
Drives: 2016 ISM BRZ Limited, 2000 Civic SI
I noticed my left hand side upper OCV sensor has this oil contamination in the electrical plug connector.
I haven't gotten a CEL yet, and it's been roughly 3,000 miles since I noticed.
I bought a spare OCV sensor to have on hand, should I change it out now? Or wait till a CEL to eventually come on to replace the sensor?
On a side note, I always use dielectric grease on all my engine harness connectors to prevent corrosion from the elements (if they don't have a rubber/silicone weather seal in the plug), wouldn't this oil contamination have the same effect as dielectric grease?
Si_Chris is offline   Reply With Quote
Old 06-01-2018, 02:01 AM   #9
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
@Sigh-on-Rice I think this warrants being added to the sticky
Old 06-01-2018, 10:43 AM   #10
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
I had this replaced without a TSB a few years back. I had no check engine light or any drive-ability issue. I only saw an oil leak seeping out.
N1rve
Old 06-03-2018, 11:33 PM   #11
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
Thanks for letting me know.
Thanks also to OP for posting this.
The TSB thread is updated with this bulletin.
Car won't start (EFI ctrl fuse keeps blowing) Books Issues | Warranty | Recalls / TSB 7 04-22-2025 09:35 AM
Help! Brake line leakage after steel braided line install. ysu Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 02-09-2020 10:38 PM
2017 M/T, 29k miles, requiring valve adjustment Mr. Kurtz Issues | Warranty | Recalls / TSB 19 03-06-2019 01:08 PM
SB17-118 SERVICE BULLETIN CABIN EXHAUST GAS NOISE Trap63 Issues | Warranty | Recalls / TSB 18 04-23-2018 11:11 PM
Car won't start after EFI CTRL short TheBRZsKnees Electronics | Audio | NAV | Infotainment 9 05-31-2017 11:22 AM
