Old 05-25-2017, 10:47 PM   #1
TheBRZsKnees
TheBRZsKnees's Avatar
Drives: 2014 BRZ
Car won't start after EFI CTRL short
Hey all, I really appreciate any advice here. I was on my way home earlier this week when my engine cut out. My car is 2014 AT with an FBM turbo kit.
After having it towed home, I found that the EFI CTRL fuse was blown. I replaced it, and it blew again immediately. After hours of searching, I found that my downpipe had partially melted the wire to my passenger-side cam sensor. The fitment of the downpipe is terrible (actually up against another sensor). I heat wrapped it, but this wire had melted on one of the bungs that poked out from the heat wrap.
I wrapped the wire in electrical tape and pulled it to the side. During this process, the battery had died (my battery is crap). I had my roommate jump me, but still no start. However, the fuse didn't blow this time either. I do hear a clicking sound at some points.
For some reason, the key fob doesn't unlock anything anymore, and my stereo doesn't start when I go into Aux. I still get the green key light on the dash when in the car though. I've rechecked all the fuses. I confirmed that it's not a steering lockout issue. I'm still combing through the forums, but I'm running out of things to try =[
TheBRZsKnees is offline   Reply With Quote
Old 05-25-2017, 11:49 PM   #2
TheBRZsKnees
Drives: 2014 BRZ
Hah, I guess this post was premature. After checking this thread, I gave it another jump. It look a few tries, but as I as lamenting to my girlfriend the fact that the car wouldn't even go into AUX, the dash lit up and the car when into AUX. I gave it another shot and she started right up.
I still have a CEL and the sound of the ratchets and bolts rolling around since I dropped several into the engine bay during my investigation, but she starts up consistently now.
Old 05-26-2017, 04:55 AM   #3
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
I'll bet the CEL will clear after a few run cycles. Check the code though and make sure it's not for another issue.
Old 05-26-2017, 09:36 AM   #4
Glad you got it fixed and actually resolved the root cause (unlike soooo man others)
That is a great roommate but I am not sure I would have taken time out for that while may car was broken.
Old 05-29-2017, 02:18 PM   #5
exE36M3
FWIW - When fuses blow I usually check one of two things:
1. Bad ground wire - sometimes I forget to either tighten it down (after seating the nut by hand). Common issue if you've done an all day install and you are crazy tired.
2. Or bad quality wiring (happens) - you can see the outer insulation cooked/browned/even blackened. Also a burning plastic smell.
I get that the car starts BUT... I'm personally anal about stuff like electricals because when they decide to fail, it's great when it's at home in the AM, but SUCKS when you are nowhere and the car decides to die.
exE36M3 is offline   Reply With Quote
The Following User Says Thank You to exE36M3 For This Useful Post:
Tcoat (05-29-2017)
Old 05-29-2017, 02:35 PM   #6
I wish I had a dollar for every person that said "I changed the fuse and all was OK again" without even attempting to find what blew the fuse. Fuses don't just blow randomly for no reason (well not most of the time at any rate).
You missed number 3 - Somebody installed something wrong or that required great power than the fuse was rated at.
Old 05-31-2017, 10:22 AM   #7
exE36M3
Ha, no lie brother. I personally cringe whenever I see guys working their cars with watches, bracelets, or rings. They are in for a red and rude awakening if they hit any live electrical lead. :\
They should have NEVER cut autoshop from the schools.
We have too many smart kids now who are absolutely clueless when it comes to fixing even the most basic things on their car.
(Not picking on anyone on this board but, the schools screwed you guys in the name of STEM.)
Tcoat (05-31-2017)
Old 05-31-2017, 10:24 AM   #8
They cut it from your schools? Not here. Thank goodness. In fact you can actually start the education for an apprenticeship with some of the advanced High School shop classes.
Old 05-31-2017, 10:36 AM   #9
jasonojordan
Drives: 2013 satin white brz limited
Hopefully you are getting that battery replaced soon as well.
jasonojordan is offline   Reply With Quote
Old 05-31-2017, 11:22 AM   #10
exE36M3
Yep, California cut it from public schools in the 90s as well as driver's ed.
Removing the ability to both fix and pilot the car. :\
dead, efi ctrl, fuse, short, start
Car won't start (EFI ctrl fuse keeps blowing) Books Issues | Warranty | Recalls / TSB 7 04-22-2025 09:35 AM
Car won't start. Limited with push to start. uEih Issues | Warranty | Recalls / TSB 22 01-06-2017 11:54 AM
Pushed start.. didnt start im_topher Engine, Exhaust, Transmission 86 11-29-2015 09:57 AM
Pop-Start with Push-Button Start cmspooner BRZ First-Gen (2012+) — General Topics 5 03-22-2013 02:45 PM
Push Start Rough Engine Start Up joergasm Engine, Exhaust, Transmission 3 12-12-2012 03:44 AM
