Old 05-29-2018, 04:38 AM   #1
Trap63
Trap63's Avatar
Drives: Brz WRB - Europe LHD
Exclamation SB17-067 Leakage countermeasure for VALVE ASSY OIL CTRL 2013-2017
SB17-067 Countermeasure for VALVE ASSY OIL CTRL 2013-2017
Solving Internal oil leakage with new 10921AA241
Check part as described.
I changed the lower drive side one thus had a oil leakage generating some VVT code.
Trap63 is offline   Reply With Quote
The Following 6 Users Say Thank You to Trap63 For This Useful Post:
Bonburner (05-29-2018), davidsn_670 (05-29-2018), RallySTI (05-29-2018), Sigh-on-Rice (06-04-2018), Tcoat (05-29-2018), Ultramaroon (06-04-2018)
Old 05-29-2018, 05:49 AM   #2
Ricepuddin
Get a Bowl
Ricepuddin's Avatar
Drives: 2017 BRZ PP
Is this a preventative thing, or a will repair thing ?
Sent from my Pixel XL using Tapatalk
Ricepuddin is offline   Reply With Quote
Old 05-29-2018, 05:54 AM   #3
Trap63
Trap63's Avatar
it's a countermeasure, "IF"
The Following User Says Thank You to Trap63 For This Useful Post:
Ricepuddin (05-29-2018)
Old 05-29-2018, 06:30 AM   #4
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
Is this the cause of all the ignition coil codes?
Old 05-29-2018, 06:48 AM   #5
Trap63
Trap63's Avatar
sometimes may occour VVT DTC code if conductivity is poor. I got VVT DTC code and solved this way, you need ring and back ring too when change.
Old 05-29-2018, 07:22 AM   #6
Trap63
Trap63's Avatar
NO, it doesn't affect ignition, only VVT system
Old 05-31-2018, 08:07 AM   #7
BRZnut
Drives: BRZ DGM Limited
what exact code did you get?
Old 06-01-2018, 02:39 AM   #8
Si_Chris
Drives: 2016 ISM BRZ Limited, 2000 Civic SI
I noticed my left hand side upper OCV sensor has this oil contamination in the electrical plug connector.
I haven't gotten a CEL yet, and it's been roughly 3,000 miles since I noticed.
I bought a spare OCV sensor to have on hand, should I change it out now? Or wait till a CEL to eventually come on to replace the sensor?
On a side note, I always use dielectric grease on all my engine harness connectors to prevent corrosion from the elements (if they don't have a rubber/silicone weather seal in the plug), wouldn't this oil contamination have the same effect as dielectric grease?
Si_Chris is offline   Reply With Quote
Old 06-01-2018, 03:01 AM   #9
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
@Sigh-on-Rice I think this warrants being added to the sticky
The Following 3 Users Say Thank You to FRSBRZGT86FAN For This Useful Post:
davidsn_670 (06-01-2018), Sigh-on-Rice (06-04-2018), Trap63 (06-01-2018)
Old 06-01-2018, 11:43 AM   #10
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
I had this replaced without a TSB a few years back. I had no check engine light or any drive-ability issue. I only saw an oil leak seeping out.
N1rve
Old 06-04-2018, 12:33 AM   #11
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
Thanks for letting me know.
Thanks also to OP for posting this.
The TSB thread is updated with this bulletin.
The Following 2 Users Say Thank You to Sigh-on-Rice For This Useful Post:
Trap63 (06-04-2018), Ultramaroon (06-04-2018)
Car won't start (EFI ctrl fuse keeps blowing) Books Issues | Warranty | Recalls / TSB 7 04-22-2025 10:35 AM
Help! Brake line leakage after steel braided line install. ysu Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 02-09-2020 11:38 PM
2017 M/T, 29k miles, requiring valve adjustment Mr. Kurtz Issues | Warranty | Recalls / TSB 19 03-06-2019 02:08 PM
SB17-118 SERVICE BULLETIN CABIN EXHAUST GAS NOISE Trap63 Issues | Warranty | Recalls / TSB 18 04-24-2018 12:11 AM
Car won't start after EFI CTRL short TheBRZsKnees Electronics | Audio | NAV | Infotainment 9 05-31-2017 12:22 PM
