Old 05-24-2018, 11:28 PM   #15
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
I got to spend some quality time inspecting under my car when it was getting the tire change a while back. I was very impressed with how it has stood up under there. After 3 winters and 120,000 miles (190,000 kilometers) the only things showing even surface rust was the unpainted nuts and bolts. Even they were not bad. All rubber boots and bushing were still pristine. The struts showed no issues at all even on my lowering springs. My poor exhaust has taken a shit kicking from whacking against speed bumps but that was abut all.
Originally Posted by norcalpb View Post
The 86 rubber suspension components are pretty spectacular. After 105k miles I can’t find any wear on the supporting suspension components, including all 4 sway bar endlinks.
Compare that with my old BMWs which needed front control arm, “guibo”, F and R top hats, and differential bushings at 100k.
My front passenger sway bar bushing looks to be melting at 35k miles.
Just finished derusting the front subframe welds.
Rear subframe, differential, and suspension are showing surface rust. Obviously exhaust too.
But most everything else is in great shape.
Maybe I'm doing it wrong?
Old 05-25-2018, 12:26 AM   #16
……..and …….. maybe your new bride will find more useful things for you to do …..
Ultramaroon (05-25-2018)
Old 05-25-2018, 12:29 AM   #17
Originally Posted by RickyRacer View Post
13' FRS with 130k on it.
LOVED the way the car handled when i bought it, funnest car i've owned to date.
Unfortunately now, the ride is much bumpier, harsher, weird sounds here and there.. i think it's time for the suspension to get refreshed (i did brakes last year)
Catch is.. i don't like aftermarket.
I want to do a whole OEM rebuild and hopefully get the car to feel how it did when i bought it
Reason i don't like aftermarket is I drive ALLOT (DD) and aftermarket from my experience doesnt have the same longevity as OEM.
Can someone let me know what I should replace?
I know springs/struts/shocks in the back are standard. But what other suspension components should i replace while everything else is already being replaced?
Any reccomendations from you suspension guru folks? Again, I want OEM feel, daily driver comfort, and longevity.
LAstly, I don't trust myself to do suspension work. How many hours would a reputable body shop typically need for a job like this?
Thank you very much for your help!
How about replacing the tires …… and call it good …….
Old 05-25-2018, 12:32 AM   #18
Nah. You're doing it fine. Grease melts and spreads out over that bushing because it's close to the overpipe. As long as the bushing is supple, you're golden.
Spuds (05-25-2018)
Old 05-25-2018, 12:37 AM   #19
Spuds
The Dictater
Spuds's Avatar
Well, I'm not entirely sure how to respond to that...
Old 05-25-2018, 01:00 AM   #20
Oh, you will find out and it ain't what you were hoping for.
More like, things like ….. hang new curtains, paint every room in the house, help pick out new furniture, put new floor covering in the bathrooms, wash all windows (inside and out), clean off the roof, repair the back yard fence, save up for a new washer and dryer, ………… you getten the drift ?? …….
strat61caster (05-25-2018)
Old 05-25-2018, 07:47 AM   #21
ZDan
ZDan's Avatar
Drives: '23 BRZ
Doubtful that you need new springs...
When wife's '05 Mazda3 struts went out I went with new KYB's all around. I think they're fantastic, better (more) low-speed rebound damping but still soak up bumps very very well. MUCH better than the factory dampers (when they worked), which I thought were very good to begin with.
Can't speak about non-PP OEM, but the Sachs dampers are kind of a disappointment. Too little low-speed rebound damping, and way way too much high-speed compression damping.
I'd go with KYB's personally...
Old 05-25-2018, 09:15 AM   #22
Spuds
The Dictater
Spuds's Avatar
Yeah, I already do all that... Plus car maintenance. But this is OT AF. So back to... Suspension was it?
Old 05-25-2018, 09:29 AM   #23
wparsons
wparsons's Avatar
You're going to have to replace the front end links as well if you get new shocks, no chance they come off cleanly. Both links and all 4 nuts are like $60 cdn though, so hardly expensive.
I'd go with 2017+ shocks (and springs if it's a package), new upper mounts if the shocks/springs don't come with them and the front end links.
flickr
RickyRacer (05-25-2018)
Old 05-25-2018, 11:54 AM   #24
RickyRacer
RickyRacer's Avatar
Drives: 13 FRS
thank you very much everyone for your input.
I think this is what i will do
shocks/springs for all 4 courners
upper mounts
front end links
will probably have to buy new from Toyota as i don't see any for sale in Canadian forum
RickyRacer is offline   Reply With Quote
Old 05-25-2018, 12:08 PM   #25
upper mounts
front end links
I have a set of '14 stock springs with about 10 kilometers on them you can have for free if you can figure out how to pick them up. I truly doubt you need springs anyway but if you want to change them...
Old 05-25-2018, 12:30 PM   #26
RallySTI
Drives: 2013 Subaru BRZ
I just installed Koni Yellow's (not the inserts), group N F mounts and the Eibach Pro-plus kit (Pro Kit springs and 22/25mm bars) on my 13 BRZ. The mileage on the factory parts was 83,xxx miles. I commute from Toledo Ohio to Detroit 5 days a week and if you have been to this part of the country you know how rough our roads are.
I am very pleased with the new suspension parts. On full soft the ride is much more compliant than the factory parts and the reduced wheel gap is pleasing on the eye. I think the Eibach spring rate is stiffer than stock. Since 90% of the mileage on this car is commuting on I-75 I was very hesitant on using something stiffer than stock. After a few days of driving the car I am now asking why I waited so long to install these parts.
RallySTI is offline   Reply With Quote
The Following 2 Users Say Thank You to RallySTI For This Useful Post:
Tcoat (05-25-2018), Tristor (05-25-2018)
Old 05-25-2018, 12:43 PM   #27
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I have Eibach prokit springs too. They have a progressive spring rate, which makes them fairly comfortable.
I have been weighing the cost difference between the konis and the bilsteins... Thanks for sharing.
OP, If you are thinking about buying new parts form the dealership. I would price a set of konis and bilsteins to compare to the OEM parts...
I know you said you did not want to install the parts. But there is a great DIY to do so. I was able to follow it and install my parts in just a few hours. The springs/struts install is pretty novice level wrenching.
I LIKE TIRES!
RallySTI (05-25-2018)
Old 05-25-2018, 03:08 PM   #28
RallySTI
I cant think of any car that I have ridden in that had aftermarket Bilsteins installed however ever car that I have installed or ridden in with Koni's I have liked.
Looking for OEM suspension and Rear Suspension Lateral Link Rod jprules Want-To-Buy Requests 1 01-05-2018 11:43 PM
OEM suspension and Rear Suspension Lateral Link Rod jprules Want-To-Buy Requests 3 10-04-2017 06:56 PM
Suspension Super Sale ISC Suspension | KW | Tein | Cusco and More OCRaceShop.com Brakes, Suspension, Chassis 14 08-26-2015 10:43 AM
Squeaking / Creaking rear suspension with low ride height? Suspension pros welcome! mothespaceman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 08-14-2015 05:06 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
