Think car needs new suspension
13' FRS with 130k on it.
LOVED the way the car handled when i bought it, funnest car i've owned to date. Unfortunately now, the ride is much bumpier, harsher, weird sounds here and there.. i think it's time for the suspension to get refreshed (i did brakes last year) Catch is.. i don't like aftermarket. I want to do a whole OEM rebuild and hopefully get the car to feel how it did when i bought it Reason i don't like aftermarket is I drive ALLOT (DD) and aftermarket from my experience doesnt have the same longevity as OEM. Can someone let me know what I should replace? I know springs/struts/shocks in the back are standard. But what other suspension components should i replace while everything else is already being replaced? Any reccomendations from you suspension guru folks? Again, I want OEM feel, daily driver comfort, and longevity. LAstly, I don't trust myself to do suspension work. How many hours would a reputable body shop typically need for a job like this? Thank you very much for your help! |
I can't imagine everything needing to be replaced...something must be going but I wouldn't get all new suspension... I'm guessing you are at 130k km not miles since you are in Toronto?
I suggest buy someone's OEM coilovers that were swapped early plus there might be a bushing or two that can be refreshed if necessary.
Lots of good shops in GTA depending where you are. Check the Toronto Subaru Club website for list of popular/recommended Subie shops. Who knows hours these days that's why go to a reputable shop. My Toyota dealer charged me 3 hours @$130 to swap (no diagnoses needed) a starter.lol |
struts/shocks/springs will be replaced for sure can you elaborate on what you mean by everything? I'm not too concerned about the cost.. i just want to keep the ride smooth and have it driving nicely for another 130k with OEM feel :) Anything that should be replaced, will be replaced. I just dont have the suspension knowledge to know what other parts to buy |
Shocks start wearing day one and it is so gradual most don't notice or care until it is a sloppy mess. Finding someone with "like new" stuff should be easy. The newer the better, even at 20K there is some wear. There have been a couple valving and spring rate changes too, right? Try to research which you ight like the best, or go with something from 17-18 to have the latest gen.
If all else fails I'm sure someone knows the manufacturer, Toyota didn't make them. Chances are they are Tokicko, Sachs, KYB, Showa or something similar right? |
Sloppy BJs can also make it feel loose
Might consider that. But if you have suspension clunking its better to find the cause then throw parts at if |
also move mountains, start wars, incite 6 shooter showdowns and instigate rebellion. |
Bilstein B6 are a significant improvement over OEM 2013 shocks. Unfortunately, everything from Bilstein is backordered forever and ever. Skip the basic KYBs. Koni Yellow sports are fine but maybe not the best choice for you.
I would recommend OEM 2017 struts/shocks/springs. Get the Performance Pack parts if you want a little more "sport". Inspect your suspension bushings...front control arm and rear upper control arm especially. Swaybar bushings too. Inspect front and rear endlinks. Inspect rear subframe cradle bushings. Inspect ball joints and do a wheel bearing check. Look for torn CV boots. Get a good alignment. Check your brake pads and bleed your brake fluid while you're feeling productive. :) - Andrew |
Replace the dampers. Replace any spherical joints that have leaked (torn boots) or otherwise clunk. Replace the stabilizer bushings. Inspect all the other rubber joints and replace those showing signs of dry rot or have torn. Check the link for the service manuals in my sig line. |
Get a lightly used set of 2017 OEM dampers, and call it a day.
They frequently go for $100 here. |
I just swapped out the Koni Yellows on my car for OEM '17 suspension. It feels a fair bit better than the OEM '13 suspension. That's likely your bets bet for the money and your goals.
He's also in the rust belt. I grew up just south of Toronto. Shit just rots. |
The 86 rubber suspension components are pretty spectacular. After 105k miles I can’t find any wear on the supporting suspension components, including all 4 sway bar endlinks.
Compare that with my old BMWs which needed front control arm, “guibo”, F and R top hats, and differential bushings at 100k. |
| All times are GMT -4. The time now is 09:20 PM. |
User Alert System provided by
