Old 05-24-2018, 02:00 PM   #1
RickyRacer
RickyRacer's Avatar
Drives: 13 FRS
Think car needs new suspension
13' FRS with 130k on it.
LOVED the way the car handled when i bought it, funnest car i've owned to date.
Unfortunately now, the ride is much bumpier, harsher, weird sounds here and there.. i think it's time for the suspension to get refreshed (i did brakes last year)
Catch is.. i don't like aftermarket.
I want to do a whole OEM rebuild and hopefully get the car to feel how it did when i bought it
Reason i don't like aftermarket is I drive ALLOT (DD) and aftermarket from my experience doesnt have the same longevity as OEM.
Can someone let me know what I should replace?
I know springs/struts/shocks in the back are standard. But what other suspension components should i replace while everything else is already being replaced?
Any reccomendations from you suspension guru folks? Again, I want OEM feel, daily driver comfort, and longevity.
LAstly, I don't trust myself to do suspension work. How many hours would a reputable body shop typically need for a job like this?
Thank you very much for your help!
RickyRacer is offline   Reply With Quote
Old 05-24-2018, 02:29 PM   #2
dobbrz
Drives: RB v1 FRS
I can't imagine everything needing to be replaced...something must be going but I wouldn't get all new suspension... I'm guessing you are at 130k km not miles since you are in Toronto?
PROPΔGΔNDΔ
DRIVEN TO INFLUENCE
instagram: @andrewdobbie93
dobbrz is offline   Reply With Quote
Old 05-24-2018, 02:29 PM   #3
wbradley
Sarcastic SOB
wbradley's Avatar
I suggest buy someone's OEM coilovers that were swapped early plus there might be a bushing or two that can be refreshed if necessary.
Lots of good shops in GTA depending where you are. Check the Toronto Subaru Club website for list of popular/recommended Subie shops.
Who knows hours these days that's why go to a reputable shop. My Toyota dealer charged me 3 hours @$130 to swap (no diagnoses needed) a starter.lol
The Following 2 Users Say Thank You to wbradley For This Useful Post:
SCQTT (05-24-2018), venturaII (05-25-2018)
Old 05-24-2018, 02:35 PM   #4
RickyRacer
RickyRacer's Avatar
Drives: 13 FRS
yes 130k km.
struts/shocks/springs will be replaced for sure
can you elaborate on what you mean by everything?
I'm not too concerned about the cost.. i just want to keep the ride smooth and have it driving nicely for another 130k with OEM feel
Anything that should be replaced, will be replaced. I just dont have the suspension knowledge to know what other parts to buy
Old 05-24-2018, 02:43 PM   #5
SCQTT
ZWEI KOLBEN
SCQTT's Avatar
Drives: 2017 86 Halo 6MT
Shocks start wearing day one and it is so gradual most don't notice or care until it is a sloppy mess. Finding someone with "like new" stuff should be easy. The newer the better, even at 20K there is some wear. There have been a couple valving and spring rate changes too, right? Try to research which you ight like the best, or go with something from 17-18 to have the latest gen.
If all else fails I'm sure someone knows the manufacturer, Toyota didn't make them. Chances are they are Tokicko, Sachs, KYB, Showa or something similar right?
SCQTT is offline   Reply With Quote
The Following User Says Thank You to SCQTT For This Useful Post:
RickyRacer (05-25-2018)
Old 05-24-2018, 02:46 PM   #6
ZionsWrath
Thanks
ZionsWrath's Avatar
Sloppy BJs can also make it feel loose
Might consider that. But if you have suspension clunking its better to find the cause then throw parts at if
Old 05-24-2018, 02:49 PM   #7
SCQTT
ZWEI KOLBEN
SCQTT's Avatar
Sloppy BJs can
also move mountains, start wars, incite 6 shooter showdowns and instigate rebellion.
Old 05-24-2018, 02:54 PM   #8
Racecomp Engineering
Bilstein B6 are a significant improvement over OEM 2013 shocks. Unfortunately, everything from Bilstein is backordered forever and ever. Skip the basic KYBs. Koni Yellow sports are fine but maybe not the best choice for you.
I would recommend OEM 2017 struts/shocks/springs. Get the Performance Pack parts if you want a little more "sport".
Inspect your suspension bushings...front control arm and rear upper control arm especially. Swaybar bushings too.
Inspect front and rear endlinks.
Inspect rear subframe cradle bushings.
Inspect ball joints and do a wheel bearing check. Look for torn CV boots.
Get a good alignment.
Check your brake pads and bleed your brake fluid while you're feeling productive.
- Andrew
The Following 5 Users Say Thank You to Racecomp Engineering For This Useful Post:
JMon85 (05-24-2018), RickyRacer (05-25-2018), strat61caster (05-24-2018), Tristor (05-25-2018), wparsons (05-25-2018)
Old 05-24-2018, 02:59 PM   #9
Originally Posted by RickyRacer View Post
yes 130k km.
Unless the springs are rusted, keep them.
Replace the dampers.
Replace any spherical joints that have leaked (torn boots) or otherwise clunk.
Replace the stabilizer bushings.
Inspect all the other rubber joints and replace those showing signs of dry rot or have torn.
Check the link for the service manuals in my sig line.
Leonardo (05-24-2018), strat61caster (05-24-2018)
Old 05-24-2018, 03:46 PM   #10
CSG Mike
CSG Mike's Avatar
Get a lightly used set of 2017 OEM dampers, and call it a day.
They frequently go for $100 here.
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
RickyRacer (05-25-2018), Ultramaroon (05-24-2018), wparsons (05-25-2018)
Old 05-24-2018, 04:02 PM   #11
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
I just swapped out the Koni Yellows on my car for OEM '17 suspension. It feels a fair bit better than the OEM '13 suspension. That's likely your bets bet for the money and your goals.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
The Following User Says Thank You to Shark_Bait88 For This Useful Post:
nikitopo (05-24-2018)
Old 05-24-2018, 05:56 PM   #12
That's where I wanted to leave it but, since OP asked...
He's also in the rust belt. I grew up just south of Toronto. Shit just rots.
Old 05-24-2018, 09:32 PM   #13
I got to spend some quality time inspecting under my car when it was getting the tire change a while back. I was very impressed with how it has stood up under there. After 3 winters and 120,000 miles (190,000 kilometers) the only things showing even surface rust was the unpainted nuts and bolts. Even they were not bad. All rubber boots and bushing were still pristine. The struts showed no issues at all even on my lowering springs. My poor exhaust has taken a shit kicking from whacking against speed bumps but that was abut all.
RickyRacer (05-25-2018), Ultramaroon (05-25-2018)
Old 05-24-2018, 10:44 PM   #14
norcalpb
norcalpb's Avatar
The 86 rubber suspension components are pretty spectacular. After 105k miles I can’t find any wear on the supporting suspension components, including all 4 sway bar endlinks.
Compare that with my old BMWs which needed front control arm, “guibo”, F and R top hats, and differential bushings at 100k.
The Following 2 Users Say Thank You to norcalpb For This Useful Post:
RickyRacer (05-25-2018), Tcoat (05-25-2018)
Looking for OEM suspension and Rear Suspension Lateral Link Rod jprules Want-To-Buy Requests 1 01-05-2018 11:43 PM
OEM suspension and Rear Suspension Lateral Link Rod jprules Want-To-Buy Requests 3 10-04-2017 06:56 PM
Suspension Super Sale ISC Suspension | KW | Tein | Cusco and More OCRaceShop.com Brakes, Suspension, Chassis 14 08-26-2015 10:43 AM
Squeaking / Creaking rear suspension with low ride height? Suspension pros welcome! mothespaceman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 08-14-2015 05:06 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
