#4691 |
Drives: 2014 FR-S SSC
Yes
-Eric K - Milwaukee Region SCCA - 2014 FR-S
#4692 |
Drives: 987S, e46, mkv, frs
You can only swap if it was an option on your model year. If it was an option that is standalone, then you can swap only that part. If it came as a package with other crap, other crap needs to be swapped out too to make it legal.
#4693 |
Drives: '13 FRS - STX
Fancy calipers were first offered on the 'Series.Blue' BRZ's in 2015, that guy has a '14 so no-go unless he sells the car.
No advantage other than looks though I think they're heavier than the stock cast calipers too... Which now that I think about it, his car is in DS now, not CS, no TRD parts available, all '13-'16 BRZ's have been in DS.
#4694 |
Drives: 2016 FRS RS 2.0
My FRS is being delivered Friday. I've never driven one myself(been in plenty) but looking forward to running it in CS.
#4695 |
Drives: 2013 WRB BRZ Limited
what front sway bars are people using for their CS setups? Im debating the 19 or 22mm perrin front bar for my setup.
-B |
#4696 |
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
#4697 |
#4698 | |
I still have a Strano Bar BNIB for sale. (If you decide you want to go that route) http://www.ft86club.com/forums/showthread.php?t=123705 |
#4699 |
Drives: 2017 86 6-Speed
How happy were you with the ST bar on soft? Would you have gone a little softer if you could? I just ran my first event with the TRD setup with a TRD rear and Strano front sway (because I already had it). Car was understeering pretty badly mid corner and exit, both under neutral throttle and acceleration. Front tires were getting a lot hotter than the rear tires too. Considering picking up the ST bar or the Perrin 19mm. Perrin is 25/72% stiffer than stock, ST is 41/76%
2017 86 set up for CS STX autocross
#4700 | |
I was very happy with the ST front bar on soft (And the TRD bar on the rear). It felt "just" right for me. I would go with that same bar set up again. |
| The Following User Says Thank You to Twinz For This Useful Post: | dutchman1 (02-19-2018) |
#4701 |
Drives: 17' BRZ - PP
So I originally had hopes of taking this car to the national stage but after driving a friend's Miata in some fun runs following an event last weekend I definitely see how our cars are well outclassed in CS. Within 2 runs in his car I had bested my BRZ's best time by a full second and there was tons more time out there to be had in the Miata still.
Of note I already have my car setup with: Whiteline 20mm 2-way-adjustable front bar (set stiff) / Koni yellows / OEM crash bolts with max neg camber and custom alignment / 17x7.5 RPF1 w/ 245/40/17 Rival S 1.5 / spec-d catback / hawk street-race pads (front and rear). The friend is willing to let me co-drive his Miata for national events, which will be great. I just had higher hopes for the car, but this may push me over the edge to STX and pursuing Time Trials at least. Anyone have any ideas on how we can bring down the mighty miata? |
| The Following User Says Thank You to doctor_driver For This Useful Post: | strat61caster (05-12-2018) |
#4702 |
I hope the 17+ 86's will close some of the gap with wider wheels and lower gearing, but the ND is a lighter and more nimble starting point.
#4703 | |
Custom User Title
LOCUST 2015 FR-S (STX) and 2012 Evo X MR Instagram: LocustAutoX Sponsors:DSGPerformance Drift Office Evil Apex Racing |
#4704 |
Drives: Whiteout FRS- autocross ready
HAve you looked into SSC class. You are part way there with your setup and it looks like a popular and fun setup.
Dont go STX unless you are willing to spend lots of money. And know that there are many great drivers in that class and competition is very very tough. |
| Cinco De Mayo SCCA SOLO | Ryeong86 | NY / NJ / CT / PA | 0 | 04-23-2013 05:22 PM |
| Koni Sports in SCCA SOLO | Ryeong86 | Tracking / Autocross / HPDE / Drifting | 4 | 04-22-2013 12:58 PM |
| 2013 Preliminary SCCA SOLO and PRO SOLO National Schedule | Scooby South | Tracking / Autocross / HPDE / Drifting | 13 | 12-05-2012 08:08 AM |
| Houston SCCA Solo #9 - 5 FRS, 1 BRZ | hankster | Tracking / Autocross / HPDE / Drifting | 0 | 10-09-2012 01:35 PM |
| SCCA Solo Car Class for the FR-S/BRZ? | MrVito | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 06-15-2012 10:03 AM |
