| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
#15 | |
Drives: 2014 BRZ Limited A/T
| The Following User Says Thank You to leevanf For This Useful Post: | Ultramaroon (05-22-2018) |
#16 | |
A.K.A. Starlord
Drives: 2015 Series.Blue
This car makes a very unique (read: terrible) tractor noise below 2,000 RPM when you're lugging it. That's a good audible way to tell that you're being too aggressive with the throttle at low RPMs.
![]() Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos! You can also find me on Instagram, and on Facebook. Last edited by Stang70Fastback; 05-22-2018 at 01:13 PM. |
| The Following 3 Users Say Thank You to Stang70Fastback For This Useful Post: |
#17 | |
Drives: 2013 Scion FR-S Series 10
You say that manually controlling shifts gives you better fuel economy. It could be that the ECU wants to keep you in lower gears for the sake of the engine, and thus you are seeing worse fuel economy. Or it could be it wants the car to feel sporty. But a lot of this is subjective. I don't really know what "gentle" throttle means and am not entirely familiar with you commute.... When crawling in traffic, I'm typically above 2,000 and use engine braking to slow to a near stop. I don't like the engine being under 2K because to my ears it sounds unpleasant. |
| The Following User Says Thank You to mazeroni For This Useful Post: | Tristor (05-22-2018) |
#18 |
I don't even let my car idle because I'm so afraid of it dropping below 3000rpm.....
leevanf, you are fine, keep doing what you are doing. If it doesn't sound like a tractor you are fine. I leave mine in second sometimes and just start in 2nd because I get sick of the 1-2-1-2-1-2 crap. Just be gentle. There is no mistaking the sound it makes when it's actually lugging. Don't ignore it if it is though because it really is hard on the engine. |
| The Following 2 Users Say Thank You to ermax For This Useful Post: | Stang70Fastback (05-22-2018), why? (05-25-2018) |
#19 | |
#20 |
Reformed
Drives: '23 GRC, '11 Prius, '04 RAV4
yea I'm not sure why OP needs to go into manual mode during stop & go traffic especially considering how delayed & sluggish gear changes are at low RPMs, not sure what the point is with that. I would just keep it in D with Sport mode turned off so that it upshifts whenever possible if fuel consumption is really a concern and lugging the engine should never be an issue in auto mode, it'll downshift into 1st if it feels like it is required..
| The Following User Says Thank You to HKz For This Useful Post: | Tcoat (05-22-2018) |
#21 |
Lugging the engine can cause timing chain failure, and our boxer motors fire both cylinders on one bank before the other bank has a chance to fire. Great balance at high rpm, miserable balance at low rpm.
#22 |
The Gunshine State
Drives: '14 BRZ Limited
Is this the same effect on an inline 4?
![]() Current DD: M235i |
#23 |
Depends if the engine has a timing chain or timing cover.
An inline 4 will be more balanced at lower rpm but the consequence is an engine that is much bigger in length and typically much taller. But I’m not sure why Subaru chose a boxer design over what porsche did with the flat(?) crankshaft. Either way never lug your engines and they will never lug you. |
#24 | |
Does shifting at low RPMs really hurt the engine?
Flat, boxer opposing, all the same thing. Not really sure what you are referring to with regards to the crank being flat. The Porsche’s are laid out the same as ours. Both engines will have half the cylinders at TDC at the same time. Our firing order is 1324 just like the 718. |
#25 | |
Drive upgrades. Don't buy them.
#26 |
I’ve got more time cleaning all the FIPG than pulling and disassembling. I got both pans cleaned, the timing cover cleaned and one head cleaned. Just need to clean the other head and then make a parts list and place an order. Toyota South East’s warehouse is right here in my home town so I should be able to get parts fast. I’ve got a hookup on pricing and the short block should cost me 1840. The problem is work has been nuts so I haven’t had the motivation to work on it on week nights so it’s been a slow project. I suspect I will have it back on the road this weekend or next. I want to replace my DI seals but need that tool that is made out of pure gold. My seals actually don’t look bad but as cheap as they are I figure I may as well do them. |
| The Following 2 Users Say Thank You to ermax For This Useful Post: | Tcoat (05-23-2018), Ultramaroon (05-23-2018) |
#27 |
Drives: 2013 FR-S Series 10
do the ATs really not force a downshift if you are lugging? Only time ive ever lugged an AT car is when i accidentally put it in 2nd instead of "D" (not all AT cars will even let you do that anyway)
never driven an AT twin though. |
#28 |
Reformed
it will but the OP goes into M (manual mode) instead of letting D do its thing to manage the proper gear...in that mode it will only automatically downshift when revs are very, very low, below 1k rpms..
| Did I damage or hurt my engine ? | tonychet2 | Engine, Exhaust, Transmission | 32 | 03-11-2015 07:35 PM |
| I hurt my FRS. | Zelica | Scion FR-S / Toyota 86 GT86 General Forum | 36 | 07-19-2014 07:48 PM |
| 4.88s didn't hurt me at all | Lunatic | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 07-18-2014 10:50 PM |
| Check Engine light on @5.7k miles and engine stalling at 4,000 rpms? | djdrugga24 | Issues | Warranty | Recalls / TSB | 3 | 06-25-2014 06:06 AM |
| Crawford's BRZ got hurt | StarsGarrador | BRZ First-Gen (2012+) — General Topics | 93 | 11-04-2012 08:40 PM |
