Old 05-22-2018, 07:04 AM   #1
leevanf
leevanf's Avatar
Drives: 2014 BRZ Limited A/T
Does shifting at low RPMs really hurt the engine?
Hi guys, i have an AT and my daily drive is PURE traffic. My "average speed" reading on the gauge is usually just around 20kph.
So i tried experimenting on different shift styles, shift points, sport mode D on off etc, and such and the most significantly economical fuel saving i get is driving this way -
(1) featherlight throttle - never past 1600 rpm (unless uphill i let it go 2000, you can feel it anyway when the car needs more)
(2) driven in M mode - I shift when the arrow comes up which i recorded to be at 13kph to 2nd, 27.5kph to 3rd, 38kph to 4th, and 52kph to 5th. (i never reach 6th because of traffic)
Result, I normally get 15L/100km instead of the usual 18. So i get to travel about 260km before fuellin up rather than 215km.
Q.. i dont really "feel" the engine lugging, and if it DOES lug, like when going uphill, i give it more gas and let it hit 2k rpm. Point is i just accelerate really slow since its traffic anyway.
Is this in anyway "bad" for the engine or transmission long-term? Because i noticed my manual shift points are even earlier than D with sport mode off and an eased throttle.
leevanf is offline   Reply With Quote
Old 05-22-2018, 07:53 AM   #2
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Why is your fuel consumption so high? My BRZ is manual, but my Forester is auto and I usually get 11-11.5L/100km in PURE traffic.
About shifting points, I would just leave it in the D mode.
Old 05-22-2018, 08:36 AM   #3
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Shifting at low RPM in and of itself isn't bad for anything. The only thing bad in what you describe would be if you are lugging the engine at low RPM (basically below 2k). However, if you're very gentle on the throttle at those low RPMs, then that isn't an issue either. In heavy traffic, I often keep the car in 2nd, which has the engine well below 2k RPM, but it is either just idling along, or I'm using light throttle, so it doesn't matter.
Low RPMs aren't bad for anything. Lugging the engine at low RPMs is.
Also does 15L/100km really translate to 15 MPG (US)? If so, something is horribly wrong with your car. I can't even get that low mileage in a day of autocrossing and towing a tire trailer. You should be getting closer to 25 MPG (10L/100km) in traffic, especially in how you're trying to drive efficiently.
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
The Following 2 Users Say Thank You to Stang70Fastback For This Useful Post:
ermax (05-22-2018), Ganthrithor (05-23-2018)
Old 05-22-2018, 09:22 AM   #4
How are you calculating that mileage? I can not imagine any possible way to get that bad even in traffic. Fuel would almost have to be pissing out.
Ganthrithor (05-23-2018), Tristor (05-22-2018)
Old 05-22-2018, 09:29 AM   #5
ermax
ermax's Avatar
I get 28.3mpg (according to the gauge) in stop and go. Takes 1 hour to go 22 miles to work and an hour to go 22 miles home. That translates to 8.311469 L/100KM.
The Following 2 Users Say Thank You to ermax For This Useful Post:
Tcoat (05-22-2018), Tristor (05-22-2018)
Old 05-22-2018, 09:41 AM   #6
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Unless he is checking instant mileage consumption and not average ...
Old 05-22-2018, 09:49 AM   #7
That is why I asked where he is calculating it. Wouldn't be the first to do that.
nikitopo (05-22-2018)
Old 05-22-2018, 10:44 AM   #8
ZionsWrath
Thanks
ZionsWrath's Avatar
If you have an auto why are you trying to manual shift it. Just let the car do the work. Else buy a stick shift.
I had a Honda accord. Drove in traffic a lot and idled it a lot to charge phone or run heat/air con. Averaged 19-20 MPG in it. On highway trips though it will easily hit 35 mpg.
I wouldn't worry about shit MPG in poor driving conditions with a lot of idling...
Actually I just did a few trips in my BRZ and getting around 32 mpg doing 70-80 on the highway. But my "average" is 17mpg.
The Following User Says Thank You to ZionsWrath For This Useful Post:
Old 05-22-2018, 11:21 AM   #9
leevanf
leevanf's Avatar
Hi guys, thanks for the input on as long as acceleration is gentle (not lugging) that definitely helped as thats what I do.
And to those who ask about mileage, the local version of our car comes in kph and L/100km in the indicator (not mpg). translated to KM/Liter, I get about 5.6-6.2.
Similar to our yaris and even our 1998 land cruiser lol!
I dont think you guys have the same understanding of traffic as we do in the Philippines. Check out "Philippine traffic" on youtube. We dont stop and go. We just pretty much STOP 90% of the time and crawl to a go. There is no GO. theres just stop and crawl.
The Following User Says Thank You to leevanf For This Useful Post:
Old 05-22-2018, 11:23 AM   #10
leevanf
leevanf's Avatar
The literal crawl and go traffic in my country (philippines) begged for an auto.. I never hit the highway too
Old 05-22-2018, 11:25 AM   #11
leevanf
leevanf's Avatar
yeah i am super gentle with the accelerator and would also do the same 2nd gear you do thank you for the answer! yes 15l/100km translates to 15.6 mpg
Old 05-22-2018, 11:25 AM   #12
JustSomeGuy
A Nobody
JustSomeGuy's Avatar
Drives: FRS
couldnt the type of gas being used cause the more frequent fill ups and bad mileage? but that being said i have an AT as well and just leave it in AT when driving, i dont find the need to be in its "manual" mode and especially in the city where its stop and going but thats just me. i also average 600km a tank
JustSomeGuy is offline   Reply With Quote
The Following User Says Thank You to JustSomeGuy For This Useful Post:
Old 05-22-2018, 11:26 AM   #13
leevanf
leevanf's Avatar
exactly tcoat! take a look at philippine traffic on youtube. thats literally 99% of the road i commute in everyday. no freeways/highways too.
Tcoat (05-22-2018)
Old 05-22-2018, 11:31 AM   #14
mazeroni
Drives: 2013 Scion FR-S Series 10
Don't lug the engine.
Basically, you have a slow moving piston but a fast and power explosion. That force of combustion has to go somewhere. You want it going to the wheels, but lugging results in combustion that can't effectively push down the piston and you just waste fuel and wear the engine.
Besides, the optimal operating range for our engine is somewhere in the 2,500~3,000 range, right? It sure seems that ways to me. If you're doing anything other than coasting on flat ground, I'd downshift and keep it over 2,000 until you want to coast again, then go to the highest gear.
mazeroni is offline   Reply With Quote
Did I damage or hurt my engine ? tonychet2 Engine, Exhaust, Transmission 32 03-11-2015 07:35 PM
I hurt my FRS. Zelica Scion FR-S / Toyota 86 GT86 General Forum 36 07-19-2014 07:48 PM
4.88s didn't hurt me at all Lunatic Scion FR-S / Toyota 86 GT86 General Forum 9 07-18-2014 10:50 PM
Check Engine light on @5.7k miles and engine stalling at 4,000 rpms? djdrugga24 Issues | Warranty | Recalls / TSB 3 06-25-2014 06:06 AM
Crawford's BRZ got hurt StarsGarrador BRZ First-Gen (2012+) — General Topics 93 11-04-2012 08:40 PM
