#58 | |
The Stig's German cousin
Let's face it, if you panic brake on ice, you are probably screwed. The lesser of evils at that point is to retain control of the car so you can do something to avoid/mitigate harm. If the wheels are locked your fate is decided. The fact that the system activates on the race track is because you're operating outside the design basis of the system. If you have serious aero, brakes, suspension, tires, etc. you need to have serious ABS to go with it. |
#59 | |
Also, locking up the wheels is the safest thing one can do if one looses control of the car. For example, many people crash inside of a turn, because they don't lock up the wheels after they lost the rear. For lack of a better example: [ame="https://www.youtube.com/watch?v=k_E5OnkSHys"]COURSE DE COTE 2012 St.Ursanne - CH - CRASH- Race aside 2012 St.Ursanne - CH - CRASH - YouTube[/ame] I'm not saying the guy in the video didn't lock up the wheels, but this is the kind of crash one gets to see when people don't lock up the wheels after loosing their rear. |
#60 |
OT: A very competitive car up to 1.6 l at our slalom events is the Citroën Saxo & Peugeot 106 Rallye. A few of them were sold without ABS. None of the competitors are driving the version with ABS.
| The Following User Says Thank You to rx3 For This Useful Post: | CSG Mike (06-03-2015) |
#61 | |
The video is not a great example. The car starts to go before the rear tires leave the road, and it's theoretically able to be saved at this point. When his rear tire drops off the grass he has less than a second before he's shooting into the inside embankment; by the time he's back on the pavement, he's already headed inside even if he locks his brakes. Really tough to make the right call there when it happens that fast and your first thought is "I can save this." |
#62 |
I agree that this guy had probably not really a chance to save the situation. But I just needed a short video showing an inside turn crash after loosing the rear.
#63 |
Drives: AVO Turbo Subaru BRZ / Subaru WRX
Encountered multiple Ice mode throughout the day even after doing the pedal dance during gymkhana. Need to jab at the brakes to transfer the weight to the front in order for the car to rotate, but the Ice mode kicked in causing the car to plow straight.[ame="http://youtu.be/WVckzOiFwV8"]http://youtu.be/WVckzOiFwV8[/ame]
AVO Turbo|Essex AP Sprint Kit|AVO Overpipe|HKS Hi-Power Spec L Catback|Cusco Engine Mounts|Whiteline Bushings|KW Clubsport|Defi Advance ZD|AEM Wideband Failsafe Gauge|Greddy ProFec Boost Controller|Tomei 2Way LSD|AEM Water/Meth Kit|PBM Angle Kit + Kunckles|Flatwell LCA|HKS Oil Cooler|Greddy High Cap. Diff Cooler|Sard ATF Oil Cooler|CSF Radiator|
#64 |
Drives: 2017 BRZ
In my experience, ice mode is easier to get with pedal dance, and aggressive brake pedal use is a sure way to do so. I've not yet adjusted my driving at autocross where its beneficial to PD. It may never be, it I'll keep experimenting here and there.
#65 |
Squeeze, not stab.
| The Following 3 Users Say Thank You to CSG Mike For This Useful Post: |
#66 |
I need sudden weight transfer for gymkhana layout. Its not possible because the distance is too small and at full speed is still in 1st gear.
#67 | |
Up to you. Or, disable your ABS completely, and see what stabbing will do when the aids aren't covering up your driving error. |
| The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | cjd (05-22-2018), strat61caster (05-22-2018) |
#68 |
Drives: 2014 FR-S
Idk. That looks like you tried something that the car/tires just wasn't gonna do. I would suggest that better-separated inputs would have resolved what you experienced. You're putting in lots of (and increasing) steering as you get heavier on the pedal (:07-:09). I'd kind of expect to overwhelm the front tires and plow forward with that combo of inputs. More so if either the front or rear tires are way differently hot. Which, a 360-degree donut-to-slideways exit would do a pretty good job of.
Btw, what was the failed element supposed to be? Another 360? 90-right? Stop box? A less selectively edited video would be helpful. If the next (failed) element is another 360 like the first one, the problem is that your hand is on the gearknob, not the parking brake.
-Mike
#24 CS/CSR |
| The Following User Says Thank You to TrqlessWonder For This Useful Post: | CSG Mike (05-22-2018) |
| Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS | Redline360 | Brakes, Suspension, Chassis | 12 | 01-05-2013 10:20 PM |
| Rattle from the middle of the car | brichard0625 | Issues | Warranty | Recalls / TSB | 11 | 10-05-2012 07:04 PM |
| Odd brake pedal feel, fade? | yomny | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 27 | 09-11-2012 12:29 PM |
| First Whiteout 86 in the Middle East | i_giado | Member's Car Journals | 26 | 07-09-2012 05:30 AM |
| Anybody near Middle Indiana | AX_FRS | Tracking / Autocross / HPDE / Drifting | 17 | 06-01-2012 11:16 PM |
