go_a_way1
Old 05-12-2018, 08:27 AM   #10641
WNDSRFR
Drives: FR-S,GTI
Cool
Looks like this might be for real. I like how they put it on the Subaru with the oversized turbo to eliminate lag. I don't know about having lithium batteries under my hood though.
Old 05-18-2018, 02:44 PM   #10642
ecologymagnet
Drives: NB2 1.6
Hello,
I am interested in this type of turbos.
What size of motor and turbo are you using?
Thank you very much.
ecologymagnet is offline   Reply With Quote
Old 05-18-2018, 02:46 PM   #10643
ecologymagnet
Drives: NB2 1.6
Originally Posted by Stormalong View Post
For sale: Rev 1.5 Phantom Supercharger (about 4 years old)
I believe the controller is damaged. Probably someone good with electronics could fix it. Everything else is in working condition.
Includes Procede controller (which is awesome BTW)
Includes OpenFlash Tablet for tuning
Includes battery pack (1.5 dump pack plus PC680 starter) if you want it, although it might be expensive to ship.
Considered just discarding it since its damaged, but that seems like a waste, maybe someone can use the parts or something.
Make an offer.
PM me or email stormalong@gmail.com
MP
Old 07-11-2018, 01:07 AM   #10644
BlOody_BoOger
BlOody_BoOger's Avatar
Drives: Hot lava FRS Monogram Charizard
How well does the openflash tablet do at reading boost? I was doing some pulls with my car and noticed i'm only producing about 3.9psi max....I'm running the new battery configuration w/out the procede. Im wondering if with a little tweaking shiv can bump that number up a bit?
Sent from my SM-G935T using Tapatalk
BlOody_BoOger is offline   Reply With Quote
Old 07-11-2018, 03:24 AM   #10645
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
That seems a little low. What rpm were you at? Is the compressor perfectly strait in line with the throttle body?
I don't know if this will work, but I have my runs up on datazap that I recorded with the proceed and I topped out at 4.79lbs at 2991 rpms.
https://datazap.me/u/target70/esc-du...1&zoom=504-691
Phantom ESC, OFH, OFT, K&N Drop in
Target70 is offline   Reply With Quote
Old 07-11-2018, 02:56 PM   #10646
86TOYO2k17
Drives: 2017 toyota 86
The torqamp does seem very interesting, on the 2L Honda it was still making 1.3bar at 5k, would probably make 1.2 at 7k for us. However it’s 3400$ not counting shipping. About 1400$ more then the phantom esc, but this comes with the battery and everything looks pretty simple and plug n play. Should make 7psi tapering to around 2.5-3psi at redline. A bit better then the phantoms 5 tapered to 1.5psi. Hopefully someone will bite the bullet and post up their results for us.
Old 07-12-2018, 03:04 AM   #10647
BlOody_BoOger
I was hitting 3.9psi right at around 3500rpm, this could be to the fact that I have the throttle switch all the way back so I have to really go full throttle to engage...I have to confess when installing the batteries they did accidentally make contact with eachother, and one time I left the lights on in the car and it died for a second but i was able to start the car up again without a jump start by just letting it sit for 30min.
Old 07-12-2018, 05:31 AM   #10648
Target70
Target70's Avatar
It still seems a little low, but then again I was/am running two sets of the original batteries in parallel, dubbed dump 2.0. And I sparked mine once on install too. Not sure, there are a number of factors to account for. Is you intake filter dirty? intake leaks? batteries cold? controller too hot? compressor not aligned perfectly.
Or is the display refresh rate too slow to catch the max readings. I would suggest you do a run and record it, then check the data to confirm.
Old 07-12-2018, 10:23 AM   #10649
BlOody_BoOger
I have noticed that the refresh rate is a lil slow im not running an auxillary charger, and when I hit boost it does start to climb right back up but it'll take a good min. Before it gets back up to 28.4 thats where it normally sits for me.
Old 07-12-2018, 10:23 AM   #10650
BlOody_BoOger
Anybody selling an auxillary charger?
Old 07-12-2018, 03:18 PM   #10651
Target70
Target70's Avatar
sorry, I was talking about the refresh rate of the OFT display. In the 1 second you are under boost and still under 3500 rpm, it will probably only cycle 2 or 3 times, so your boost could peak above what you are seeing, and drop down again before it displays it.
Old 08-13-2018, 08:18 PM   #10652
BlOody_BoOger
Does anyone know if we can go to like autozone to check if our batteries are still good?
Old 09-01-2018, 02:27 PM   #10653
vfrqqq
Ultra Senior Member
vfrqqq's Avatar
Drives: 2014 BRZ Premium, WRB
Has anyone had cause to replace the controller for the Phantom ESC? I did a dummy move and arced my wrench across the battery terminals and got some sparks and smoke from the controller before I could break the connection. Other than that, been going strong with the Phantom ESC for four years now and loving every second of it!
vfrqqq is offline   Reply With Quote
Old 09-01-2018, 02:30 PM   #10654
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
There's a good chance you destroyed the controller. Does it still work?
Installed Mods:
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 05:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 07:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 08:07 AM
