Old 05-14-2018, 08:33 PM   #197
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
I went with the 86 because I didn't like the mustache of the BRZ. I would be all over this mod if I went the brz route. Good work!
SuperTom is offline   Reply With Quote
Old 05-17-2018, 08:55 AM   #198
lbrixey
Drives: 2013 Subaru BRZ
@BirdTRD thank you for the detailed write up! I will be doing this to my black Brz and will post my results!
I'm sure the JB Weld is sufficient, but I'm going to see if there is a way to mechanically fasten the grill to the bumper, for extra security.
lbrixey is offline   Reply With Quote
Old 05-17-2018, 10:47 AM   #199
juliog
juliog's Avatar
Drives: 86
This large grill mod will cause extra drag and decrease the efficiency of any heat exchangers (radiator, aftermarket oil coolers..). You're essentially making you car slower.
juliog is offline   Reply With Quote
Old 05-17-2018, 11:10 AM   #200
JustSomeGuy
A Nobody
JustSomeGuy's Avatar
Drives: FRS
i would like to see this on the new models with the updated look, think that would be cool but this also gives me an idea to maybe replace the frs grill with something different
JustSomeGuy is offline   Reply With Quote
Old 05-18-2018, 08:05 AM   #201
BRZen
I don’t know if that’s true. My engine doesn’t seem like it’s suffering from the extra air at all. I’m about to boost my car too so the extra air for the intercooler and oil cooler should help feed the turbo and keep things cool.
BRZen is offline   Reply With Quote
Old 05-18-2018, 08:55 AM   #202
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Not to be a d1ck but, honestly, I couldn't care less about that (even if it's true). My car is plenty fast enough and I did it for aesthetic reasons.
BirdTRD is offline   Reply With Quote
The Following User Says Thank You to BirdTRD For This Useful Post:
Brink (05-18-2018)
Old 05-18-2018, 09:42 AM   #203
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
Originally Posted by BirdTRD View Post
Finally took the plunge. Lots of work but worth it. Thanks @BRZen for the inspiration!
got any pictures in better lighting? from the front and from the side with the bumper installed? the black grille is kinda blending in. I'd like to see it with some nice lighting! thanks!
nvm.. i realized i commented earlier with your other pictures..
pgranberg11 is offline   Reply With Quote
Old 05-18-2018, 09:58 AM   #204
BRZen
Hard to get good photos of the mesh. Here's a side-on and a more well lit photo of mine.
The Following 2 Users Say Thank You to BRZen For This Useful Post:
BirdTRD (05-18-2018), pgranberg11 (05-18-2018)
Old 05-18-2018, 11:50 AM   #205
juliog
juliog's Avatar
Drives: 86
It's just physics. You will be making your intercooler and oil cooler far less effective if you open up the whole grille area.
Up to you, it's your own car.
Old 05-18-2018, 11:53 AM   #206
Drambeenie
Drambeenie's Avatar
Drives: Black 17 BRZ LT MT PP
Is there a performance discrepancy between the BRZ and FRS/86? I don't think there is, and the FRS/86 has the mesh grill.
Drambeenie is offline   Reply With Quote
Old 05-18-2018, 11:57 AM   #207
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
I think this is actually a great idea. As long as you can direct the air flow. I'll most likely be doing this and using foam like how ATL BRZ did with his car. The JDL intercooler goes all the way up behind the crash bar so I don't see how this would be reducing efficiency if you can properly route the airflow...
Old 07-23-2018, 07:50 AM   #208
Drambeenie
Drambeenie's Avatar
As promised.
How did you get rid of this notch?
Old 07-23-2018, 09:48 AM   #209
BirdTRD
Simply Forgotus
BirdTRD's Avatar
I drew a line (red line) and cut it there, which works but makes more of a compound curve for the mesh to have to make. If I were to do it over, I would cut more material (green line) which looks like how @BRZen did it which would allow the mesh to lay in there nicer.
Old 07-24-2018, 02:05 PM   #210
xkalelx
xkalelx's Avatar
Drives: 2013 BRZ black
Im in. Just bought my eBay mesh. Thanks to all the contributors!
xkalelx is offline   Reply With Quote
swap brz front end with fr-s? koyv90 Scion FR-S / Toyota 86 GT86 General Forum 17 02-07-2012 03:23 AM
Subaru BRZ Front End...is...ugly? hybrid4g BRZ First-Gen (2012+) — General Topics 65 02-04-2012 11:33 AM
215/40-17 front, 225/40-17 rear? ZDan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 01-21-2012 02:08 PM
Comparing front end of the FR-S/FT-86 to BRZ DIG1992 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 66 11-21-2011 05:26 PM
Buy this front bumper for G37 Coupe? WhatIs86For Other Vehicles & General Automotive Discussions 12 02-26-2011 02:24 AM
