Old 11-08-2017, 08:53 PM   #169
Cheve
Cheve's Avatar
Drives: 2017 BRZ Premium
I´m planning to attempt something similar with a plastic honeycomb grill too. Did you curve it? The one I already bought is flat, so I´m not sure how it will fit and look.
Cheve is offline   Reply With Quote
Old 11-09-2017, 12:36 AM   #170
BRZen
Hi mate. Yes, I had to create a jig and heat mould the mesh over the jig.
BRZen is offline   Reply With Quote
Old 11-09-2017, 11:18 AM   #171
Cheve
Cheve's Avatar
Oh, very well executed. I don´t have the means to do that, but mine is supposed to sit a bit further inside. I guess I´ll have try and see how it looks first, and then do something like you if it looks too crappy.
Old 11-09-2017, 11:40 AM   #172
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
That's the first mustache-delete that looks good, now it just needs a fat intercooler behind it lol.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 11-30-2017, 06:35 PM   #173
lbrixey
Drives: 2013 Subaru BRZ
I'm dying to know what was involved to do this, BRZen. Looks amazing. If this can be done without modifying the actual metal bumper, I'm doing it ASAP!
lbrixey is offline   Reply With Quote
Old 11-30-2017, 06:40 PM   #174
lbrixey
Cheve, did you attempt this yet? I would like to do this myself, but do not want to modify the actual metal bumper itself.
Old 11-30-2017, 08:06 PM   #175
NRXRaptor
Would you mind sharing how you made that jig? Dimensions and stuff? Your setup looks really good
NRXRaptor is offline   Reply With Quote
Old 12-01-2017, 10:01 PM   #176
Cheve
Cheve's Avatar
I just got a Dremel from Black Friday to start working on it. Fortunately, I believe the plastic grille I got is flexible enough to follow the original curvature without heating. I'll write a tutorial, but I'll probably do it in 2-3 weeks.
Old 12-02-2017, 04:48 AM   #177
BRZen
It will be hard to give dimensions because I moulded the piece on the shape of the cutout, and my cutout might be slightly different to yours. I'll post some pics that outline the process in my next post. Hope they help!
In saying that, it may be possible to just bend the plastic mesh into place and use some heavy weights to set the mesh while the glue dries.
Also - no need to modify any of the chassis/crash beam/metal pieces beneath the bumper. I painted the crash beam black to make it less visible under the mesh, but that's it. That's worked really well for me.
Old 12-02-2017, 04:57 AM   #178
BRZen
As promised.
Old 12-04-2017, 05:16 PM   #179
lbrixey
Wow, thanks so much for the additional info and pics. I'm going to do this for sure. I can't believe more people haven't done this!
Old 12-04-2017, 05:48 PM   #180
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Where did you get the black plastic mesh from?
BirdTRD is offline   Reply With Quote
Old 01-30-2018, 07:13 AM   #181
BRZen
Old faithful, eBay.
Old 05-07-2018, 07:45 PM   #182
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Finally took the plunge. Lots of work but worth it. Thanks @BRZen for the inspiration!
swap brz front end with fr-s? koyv90 Scion FR-S / Toyota 86 GT86 General Forum 17 02-07-2012 03:23 AM
Subaru BRZ Front End...is...ugly? hybrid4g BRZ First-Gen (2012+) — General Topics 65 02-04-2012 11:33 AM
215/40-17 front, 225/40-17 rear? ZDan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 01-21-2012 02:08 PM
Comparing front end of the FR-S/FT-86 to BRZ DIG1992 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 66 11-21-2011 05:26 PM
Buy this front bumper for G37 Coupe? WhatIs86For Other Vehicles & General Automotive Discussions 12 02-26-2011 02:24 AM
