Old 04-10-2018, 05:02 AM   #29
febrz
Drives: silver brz 2013 lmtd
Originally Posted by PuslarBrrrz View Post
Who bases their tune on sound? Is the power good? Does it knock at all? This is what is most important. Everything else can be worked through with exhaust mods. Despite what people thing the oem front pipe isn't the least raspy option out there...
Sorry, the raspyness is just the tip of the iceberg that overall set it off for me. I didn't write a thorough comment. There is high knock, IAM has dropped to .56, AFR is not hitting targets it should be... full WOT is like 13:1 instead of 11-12:1, I thought the basemap wouldn't need so much change and tweaking, but it seems it does. What front pipe do you recommend?
febrz is offline   Reply With Quote
Old 05-17-2018, 11:21 PM   #30
neilvosko
neilvosko's Avatar
Drives: Hyper Blue BRZ
why not just copy the VVT tables from OTS 2.076 tune which had EL specific maps
neilvosko is offline   Reply With Quote
Old 05-23-2018, 01:57 PM   #31
neilvosko
neilvosko's Avatar
Can these tables be used on a CATTED JDL UEL ?
Originally Posted by Shiv@Openflash View Post
Customer pulled through
I've gotten a few emails asking for the custom maps. But between the different calibration IDs and v1 and v2 XML files, it's probably better if I just post a screen shot of the VVT tables and have you guys edit the maps yourself:
The Safe and Normal tables are identical.
If anyone is truly adverse to making these changes themselves, I can do it for $25 via Paypal (hey, I got xmas gifts to buy!). Just email me your current Stage 2 UEL tune file (shiv@openflashperformance.com) and I'll cut and paste the day for you.
Old 05-23-2018, 03:39 PM   #32
tomm.brz
Drives: brz 2017 hksv2
i wouldn t use that for EL map... use the one for EL in v2 tunes..they are better for EL for the dip
Old 05-23-2018, 08:58 PM   #33
steve99
Drives: FT86
Use the V4 tune stage 2 thats for catted uel header was developed on the ft86speedfactory catted uel.
stege 2 + is for catless
Old 05-23-2018, 10:29 PM   #34
neilvosko
neilvosko's Avatar
I meant the VVT tables shiv posted earlier in the post?
so i tried these JDL specific VVTs and i get quiet a drone at 2800 - 3000 RPM.
I tried the VVTs from V4.0 and the car was a lot more toned down, so this 4.0 UEL tables are based on catted
http://www.ft86speedfactory.com/ft-8...l#.WwYS9GgvxD8
which are actually a bit different from the JDL, the JDL have longer runners
http://www.ft86speedfactory.com/jdl-...l#.WwYTwmgvxD8
thanks @steve99
Old 05-23-2018, 11:43 PM   #35
neilvosko
neilvosko's Avatar
curios on what are @Wayno UEL VVTs based on? JDL ?
Old 06-18-2018, 05:51 PM   #36
Lakitu
Lakitu's Avatar
Drives: 2017 Halo 86
Does anyone else have issues with trying to install RomRaider? Getting a blank page after clicking the Next button on the page that shows you'll be installing the Base and Source Files, along with space required. Ran in Admin privileges, no antivirus running, Windows. Re-downloaded again, same thing. Weird.
Build Thread / Daily Driver
OFT Stage 2+, GrimmSpeed CAI, JDL Ultra Quiet FP, Perrin 2.5" Resonated CBE, Enkei 18x8.5 +45, 245/35 Continental ExtremeContact
Lakitu is offline   Reply With Quote
Old 09-19-2018, 01:26 PM   #37
Michigan BRZ
Drives: 2017 WRB BRZ Limited PP
Do these JDL UEL cam timing values still apply for the 2017+ BRZ? Im currently using the stage 2+ V4.02 tune and the timing values are still noticeably different from the ones Shiv posted here.
Michigan BRZ is offline   Reply With Quote
Old 10-07-2018, 11:15 AM   #38
FISHBURGLAR
Drives: whiteout fr-s
Hey im wondering if i can upgrade to the latest version of oft for my frs. and still be able to use these values given by shiv for 93 octane uel catless jdl header.... 2013 frs btw. ?? Will it work? Shiv@openflash
FISHBURGLAR is offline   Reply With Quote
frs headers vitopell Engine, Exhaust, Transmission 6 07-10-2014 07:44 PM
LOOKING FOR OEM HEADERS cj1pilot246 Northern California 0 01-21-2014 09:54 PM
Injen SES Headers/ Agency Power headers Choong86 Engine, Exhaust, Transmission 10 12-27-2013 10:51 PM
UEL headers pepe Engine, Exhaust, Transmission 43 11-12-2013 11:40 PM
Headers tdoggy57 Engine, Exhaust, Transmission 10 01-13-2013 06:09 AM
