Old 12-11-2014, 01:02 PM   #1
snidd111
snidd111's Avatar
Drives: Scion FR-S
OFT with JDL EL Headers
Hey guys,
I've been reading all the posts about the OFT and EcuTEK. Lots of back and forth between the two, pros and cons, etc.
I'm interested in being able to control my maps, although it would be quite the learning curve.
My question is this, does anyone have any experience with the stage 2 OTS tunes for the OFT and JDL headers? I can feel stutters when I'm just barely shifting to the next gear (have the auto) and I definitely need to get a tune of some sort at this point. I'd like to be in control of the tune and be able to flash fully back to stock. My understanding with the EcuTEK is that even when flashed back to stock the ECU still stores the license and it can be problematic at the dealership.
My engine related mods are:
JDL EL catted headers
Nameless Performance OP/FP combo + axle back 2.5" exhaust with cat
Perrin all lightweight pulleys
Perrin 2.75" intake
snidd111 is offline   Reply With Quote
Old 12-11-2014, 01:51 PM   #2
steve99
Originally Posted by snidd111 View Post
Hey guys,
Perrin 2.75" intake
Their is no real drama with ecutek its just if the dealer flashes an update over you "stock" ecutek rom you will need to renew your licience, just an inconvenience.
Pick the system that suits your needs and budget, now and in the future.
snidd111 (12-11-2014)
Old 12-11-2014, 02:42 PM   #3
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
I tuned a UEL JDL header stage 2 car months ago on E85. Ended up with a map similar to the standard OTS Stage 2 E85 map but with some revised VVT settings. I could port those settings over to the pump gas maps and provide a pretty good map for you.
UEL JDL set-up running E85 (standard OTS Stage 2 map vs Custom Tuned map):
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
Old 12-11-2014, 03:57 PM   #4
snidd111
snidd111's Avatar
Drives: Scion FR-S
Thanks for the quick replies. I'd finally found a mention about being able to get licensing renews buried in another thread. But the reassurance is great.
Also thanks for the heads up Shiv. I'm looking at potentially going to a local shop my friend uses. I really like the results for his FI setup and he's had very good experiences there. But I also really like the options that the OFT has.... No one said this would be easy
I saw another thread in here from a Software Engineer who was practically in the exact same boat as me. Also a SWE and the more time I spend in here the more I'd like to try and find a development job where I could combine both worlds. I love programming and I love cars. Working with both would be fantastic.
@shiv
You said you worked with the JDL UEL headers, but those only come catless don't they? Wouldn't there be a bit of a difference with catted EL headers even if they're high flow?
Old 12-11-2014, 04:08 PM   #5
Shiv@Openflash
Drives: 2013 FRS
@shiv
Yes, the catless UEL will be very different from the catted EL so the custom maps I have probably wont be of much use. Better off using the OTS UEL maps instead then.
If you want to jump on the open source development effort, shoot a PM to td-d. I know there are a few people (including him) who are working on some advance functions (speed density, etc,.) for this ECU. It may be a good gateway for you if you want to apply your know-how to fun car stuff
The Following 2 Users Say Thank You to Shiv@Openflash For This Useful Post:
snidd111 (12-12-2014), steve99 (12-11-2014)
Old 12-11-2014, 04:39 PM   #6
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
@shiv I could use the pumpgas map for my new JDL UEL header. Currently using your stage 2 UEL 93.
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
Old 12-11-2014, 04:57 PM   #7
Shiv@Openflash
Drives: 2013 FRS
Sure, just email me. I'll email you the custom Stage 2 JDL UEL E85 map I developed on the dyno. All you will need to do is copy and paste the VVT mapping data over to your current Stage 2 UEL 93 map.
Old 12-11-2014, 04:58 PM   #8
Apoc
Apoc's Avatar
Cool thanks
“The World is Flat”
[||•]=(86)=[•||]
Old 12-11-2014, 05:15 PM   #9
Shiv@Openflash
Drives: 2013 FRS
oops... I can't find the custom JDL tune fie I did months ago. Must have done some housekeeping my computer. I've emailed the customer and hopefully he has a copy (he has since moved on to a turbo kit).
Old 12-11-2014, 05:41 PM   #10
Shiv@Openflash
Drives: 2013 FRS
Customer pulled through
I've gotten a few emails asking for the custom maps. But between the different calibration IDs and v1 and v2 XML files, it's probably better if I just post a screen shot of the VVT tables and have you guys edit the maps yourself:
The Safe and Normal tables are identical.
If anyone is truly adverse to making these changes themselves, I can do it for $25 via Paypal (hey, I got xmas gifts to buy!). Just email me your current Stage 2 UEL tune file (shiv@openflashperformance.com) and I'll cut and paste the day for you.
The Following 3 Users Say Thank You to Shiv@Openflash For This Useful Post:
DocWalt (12-13-2014), sav (02-28-2017), Wepeel (12-18-2014)
Old 12-18-2014, 01:56 AM   #11
ssyed
ssyed's Avatar
Drives: 2013 Frs
@shiv, I am running the JDL UEL on 93oct. Do you have a tune for that specifically or am I perfectly fine with using the UEL 93 OTS maps?
ssyed is offline   Reply With Quote
Old 12-18-2014, 05:20 AM   #12
steve99
the Stg 2 UEL Map will work fine with jdl uel but if you copy in the vvt changes specifly for jdl uel header shiv posted a couple of posts back it will be better.
Old 12-18-2014, 05:39 AM   #13
ssyed
ssyed's Avatar
Drives: 2013 Frs
From my understanding that's for e85 and not 94 octane. Are you sure I can run those vvt changes?
Old 12-18-2014, 05:48 AM   #14
steve99
couple of posts earlier than mapping setting shiv says ok on pump gas with thosexvvt settings see link below
http://www.ft86club.com/forums/showp...45&postcount=3
http://www.ft86club.com/forums/showp...37&postcount=7
frs headers vitopell Engine, Exhaust, Transmission 6 07-10-2014 06:44 PM
LOOKING FOR OEM HEADERS cj1pilot246 Northern California 0 01-21-2014 08:54 PM
Injen SES Headers/ Agency Power headers Choong86 Engine, Exhaust, Transmission 10 12-27-2013 09:51 PM
UEL headers pepe Engine, Exhaust, Transmission 43 11-12-2013 10:40 PM
Headers tdoggy57 Engine, Exhaust, Transmission 10 01-13-2013 05:09 AM
