Old 05-13-2018, 10:12 AM   #1
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Tilton master clutch
What have you guys done to use this master clutch? The rod does not have the same thread as the stock one.
Old 05-13-2018, 11:19 AM   #2
gtpvette
Drives: 2015 FRS - FFR GTM
I drilled mine out and welded a new correct sized nut on the inside.
http://www.ft86club.com/forums/showt...is#post2972448
2015 FR-S - One Day I'll Finish The Swap
gtpvette is offline   Reply With Quote
The Following User Says Thank You to gtpvette For This Useful Post:
Sportsguy83 (05-13-2018)
Old 05-13-2018, 06:00 PM   #3
wrxdriver2002
Drives: 2015 Subaru BRZ
I ordered a new clevis with the correct thread. I got it from Www.pegasusautoracing.com
https://www.pegasusautoracing.com/pr...sp?RecID=10263
https://www.pegasusautoracing.com/pr...p?Product=3555
Clevis is first link and a longer rod is the second link. The stock rod that comes with the master cylinder was not long enough for my application. The 6.2 was too long so I shortened it to where it needed to be.
wrxdriver2002 is offline   Reply With Quote
The Following User Says Thank You to wrxdriver2002 For This Useful Post:
Old 05-14-2018, 12:07 AM   #4
Sportsguy83
Drives: Limited BRZ
Perfect I’ll go this rout thanks!
Old 05-15-2018, 02:52 PM   #5
Sportsguy83
Drives: Limited BRZ
Did you get a master rebuild kit in order to replace the rod or since it was all brand new you just cut the longer rod and replaced it?
Old 05-17-2018, 10:34 PM   #6
wrxdriver2002
I just took it apart and replaced it. It wasn’t destructive to any component to replace. It was also really easy.
Sportsguy83 (05-17-2018)
Any clutch master cylinder options that are more compact? Clash0901 Engine, Exhaust, Transmission 3 07-22-2018 07:32 PM
Clutch Master FX400 Disengagement issues? deedz Forced Induction 15 08-13-2016 10:42 PM
FS: OEM Clutch Slave Master Cylinder MicheleAbbate Transmission and Driveline 3 05-09-2016 05:48 PM
Clutch master stage4 anyone Djen Engine, Exhaust, Transmission 24 08-13-2013 06:42 PM
Aftermarket Clutch Master and Slave? Yruyur Engine, Exhaust, Transmission 5 07-27-2013 11:22 AM
