Old 05-14-2018, 03:18 PM   #1
Neos
Drives: 86
Help with e85 oft - ltft is very high
Let me start off by saying I'm a complete noob in this area and any help is appreciated.
Switched to E85 this week. All seemed well up until yesterday. Ran down my first tank of e85 - ltft at this stage was +/-10%. Filled up with a fresh batch of e85 and my ltft are extremely high. 10%+, sometimes even below 20%. I took it to the exhaust shop to check for leaks and there was a small leak from the headers which was fixed. Fuel trims stayed the same - above 10%. I then tried reflashing... no luck.
Both tanks were from United e85 from different stations.
Here are some data logs:
https://datazap.me/u/neos/log-152628...og=0&data=1-11
Data logs were done after 50+kms of cruising - no WOT. This was also after the reflash.
I have a K&n drop in air filter and am not sure if this changes ltft especially this drastically.
I am definitely a beginner when it comes to fiddling with ecu - at this point I'm scared to drive the car.
And yes, I double checked to see if I'm running the correct tune. UEL E85 stage 2.
Neos is offline   Reply With Quote
Old 05-14-2018, 08:06 PM   #2
CSG Mike
CSG Mike's Avatar
Get a flex fuel kit.
Old 05-15-2018, 06:59 AM   #3
steve99
Drives: FT86
In Australia we are lucky our E85 from United petroleum is quaranteed 85% ethanol mixed with high grade petrol it never varies straight from pump.
You dont need flex kit, nice to jave but not needed, different in usa though with variable ethanol content
https://www.unitedpetroleum.com.au/fuel/e85/
CSG Mike (05-15-2018)
Old 05-15-2018, 07:01 AM   #4
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
High positive LTFT, looks to me like you either have a problem with a vacuum leak or air is getting into the engine post-MAF. It could be the PCV, a catch can leak or brake booster etc. OR, more likely- the exhaust place did not fix the exhaust leak. You need to put a new gasket on the header every time it is removed. If they only torqued the bolts down, they didn't do squat. Also, the connection to the OP, FP and MP all need to be checked.
If the gaskets weren't replaced or if problems are found, take it all apart and replace all the gaskets. You can do it yourself.
IMHO, a FFK in this case would just cover up the problem. I think a FFK is a great thing but if you have a hardware issue, you need to take care of that.
guybo is offline   Reply With Quote
Old 05-15-2018, 07:25 AM   #5
steve99
Drives: FT86
Ok as usa e85 is generally averaged arround 70% or so that what the tune is set up for.
In australia united e85 is 85% hence you running high positive fuel trims to compensate for the higher ethanol content of australian fuel.
If you run united all the time you can just tweak the tune and it will be fine.
Its not going to blow up but it can run better, its running mid 11 afr sgould be mid 12 and high trims but its easy fix.
Just message me
e85, ethanol, ltft, oft, stft
High negative STFT and LTFT 86TOYO2k17 Issues | Warranty | Recalls / TSB 22 09-30-2025 04:10 PM
Diagnosing high positive LTFT Tectoniic Software Tuning 22 05-03-2022 03:24 AM
LTFT high/low? Sel_brz17 Software Tuning 3 05-08-2018 07:48 PM
high ltft while running e85 with oft flat4_86 Software Tuning 4 01-22-2017 01:47 AM
high ltft at idle, my how to fix it(not fixed yet) trdric Software Tuning 16 06-18-2015 11:27 PM
