#99 |
Show the math or GTFO!
I have extensively tested this thread by comparing it to another one that was similar. I have been published in the forums over 45,000 times and am an expert on wasting energy.
| The Following 6 Users Say Thank You to Tcoat For This Useful Post: | churchx (05-14-2018), Icecreamtruk (05-14-2018), Spuds (05-14-2018), Ultramaroon (05-14-2018), weederr33 (05-14-2018), wparsons (05-14-2018) |
#100 | |
Drives: brz 2017 hksv2
because there is nothing i m aware of in the ecu tune that causes the engine to produce more torque witb higher gears |
#101 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
Hey! Hey! Hey! I'm the only one to publish scientific analysis with our cars! I tested the effects of weighted (flossy knob) versus lightweight (TRD) on the force requirements of the glenohumeral joint of those with rotator cuff tendonitis. My study showed that the lightweight actually required less initial force production in scapular protraction due to not having to move a 500g knob. After that, which is where the heavy weight matters, the 500g actually helped. But it would be irrelevant since it's that initial demand which further aggravates the shoulder joint. Boom.
| The Following User Says Thank You to weederr33 For This Useful Post: | SuperTom (05-14-2018) |
#102 | |
| The Following User Says Thank You to Tcoat For This Useful Post: | weederr33 (05-14-2018) |
#103 |
#104 |
Drives: 2013 frs red
5th gear is 1 to 1 or close to it. So if i wanted I could do a baseline in 4th, add my parts, run it in 5th and show an improvement.
#105 | |
Drives: BRZ 2018
If so although it isn't accurate, we use it as a pre-post modifications comparison and reference point during mapping, I have more than 40-50 cars dynoed this way on the same road usually on 4th-5th gear, never on 2nd-3rd. Back to your "dyno" results you can't calculate acceleration using different parameters than the actual parameters of your car (has the app the correct BRZ parameters, CF, frontal area, gear ratios etc?) and should use >=4th gear. More important weight should be from yours not from a heavier US car otherwise your figures are "optimistic", why not use then a US car final drive ratio to balance results? |
| The Following User Says Thank You to JIM THEO For This Useful Post: | wparsons (05-14-2018) |
#106 | |
Drives: Boosted 2017 BRZ PP. GT2860RS, JDL.
#107 |
Drives: frs
Group control (stock)
Group experimental (mods) Which page was posted? |
| Basic/Easy/Cheap mods? | Lakitu | Scion FR-S / Toyota 86 GT86 General Forum | 75 | 02-08-2017 03:08 PM |
| Useful/Frequent mods: a BRZ/FRS/GT-86 basic ! | Simon99 | BRZ First-Gen (2012+) — General Topics | 104 | 10-10-2016 12:45 PM |
| Basic Mods | jarviz | Scion FR-S / Toyota 86 GT86 General Forum | 16 | 05-09-2016 03:00 PM |
| 2013 Scion FR-S(basic mods) $19,500 | RavenFR-Sowner | Cars for Sale/Trade | 0 | 09-14-2015 11:46 AM |
