Old 05-14-2018, 02:56 PM   #15
CSG Mike
CSG Mike's Avatar
Originally Posted by MarkR171 View Post
Still, that's a solid amount. Just saw your thread comparing the 13-16 and 17 as well. Probably will end up with a '17 or an '18 if the pricing makes sense. I intend to occasionally street drive it as well, but will probably aim for TT5 in 2019.
Unless you're paying cash, the 18 will probably make more sense with promo financing.
Compare base model vs PP, as you do need to factor in BTM trim.
Old 05-14-2018, 03:03 PM   #16
MarkR171
MarkR171's Avatar
Drives: '05 Elise
I was leaning towards a base car anyway for this very reason. I don't think anything in the PP is worthwhile when it's going to be changed anyway (shocks/springs/wheels/tires.) Brakes are probably not worth the whole package.
My Miata isn't exactly track prepped (it's an autox STR build), and doesn't even have a roll bar, but I took it out at PittRace during a track night in America event before the '18 SCCA Match Tour and the non-brembo base brakes did just fine (with pads and fluid swap.)
'05 Lotus Elise
'19 BMW M2C
'22 Subaru WRX
ex '15 Scion FR-S
MarkR171 is offline   Reply With Quote
Old 05-14-2018, 03:39 PM   #17
CSG Mike
CSG Mike's Avatar
The base brakes will work "just fine" for lighter duty, but the bbk is really about cost reduction than performance gains.
The PP itself is totally worth it, but not worth it when you also have to get the limited trim, IMO.
Old 05-14-2018, 03:58 PM   #18
ajh88
Drives: 2013 Firestorm FR-S
Sounds like a '13 car with a '17+ engine is an economical way to go if you feel like doing the swap.
2013 Firestorm FRS
1995 Alpine Silver Supra Turbo
Toyota Lexus Club of Pittsburgh
ajh88 is offline   Reply With Quote
Old 05-14-2018, 04:04 PM   #19
CSG Mike
CSG Mike's Avatar
Sure isn't, because it's nowhere near as simple as dropping an engine in.
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
JohnJuan (05-15-2018), Summerwolf (05-14-2018), Tristor (05-14-2018)
Old 05-14-2018, 04:12 PM   #20
ajh88
Other than the engine and accompanying ECU what's the difference?
2013 Firestorm FRS
Old 05-14-2018, 04:24 PM   #21
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Buying an 86 for track use
Crank position plate, fuel rails, a host of connectors. It's not trivial.
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
ajh88 (05-14-2018)
Old 05-14-2018, 04:28 PM   #22
CSG Mike
CSG Mike's Avatar
The Harness for one.
At that point you've already exceeded the cost of an old car + swap, vs buying a new 17, and the new 17 has zero miles.
ajh88 (05-14-2018), Tristor (05-14-2018)
Old 05-14-2018, 05:15 PM   #23
ZDan
ZDan's Avatar
Drives: '23 BRZ
I was only interested in Limited trim anyway. Only question was with or without Brembos. Ease of swapping pads + looks made PP totally worth $1200 If I didn't want leather, I probably would have gotten a used FR-S...
CSG Mike (05-14-2018)
Old 05-14-2018, 05:32 PM   #24
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
It's definitely a luck issue, go with 17+ if you are worried, from 17+ onward they shot peening the cylinder wall & the cam gears alone with some added reinforcement on the rear of the block or somthing. can someone varify?
Old 05-14-2018, 08:42 PM   #25
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
I have had great luck with my 2013 with around 15k track miles on it. However, if I could swap it out for a 2017, I would. Unless you can get a KILLER deal on a perfect 2013-16, buy a 2017.
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
Is buying a used brz more beneficial then buying a new one? Jcas BRZ First-Gen (2012+) — General Topics 60 10-20-2017 12:15 AM
MVP Track Time 2013 Great Lakes/Midwest Track Dates Feffman Great Lakes 5 09-07-2013 01:39 PM
buying salvage twin for track worth it? WATCHMEHEAL Tracking / Autocross / HPDE / Drifting 15 09-03-2013 02:31 PM
Track Day: Upcoming Joey G Open Track Day for ADVANCED Drivers, Aug 20 NJMP Lightning AZP Installs NY / NJ / CT / PA 11 08-20-2012 11:31 PM
Track Day: Upcoming Joey G Open Track Day for ADVANCED Drivers, Aug 20 NJMP Lightning AZP Installs Tracking / Autocross / HPDE / Drifting 0 08-14-2012 06:46 PM
